BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      05-26-2009, 01:01 PM   #1
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
Nasty noise from steering wheel?
Hello. I own a 2008 E93 M3 and I have about 2000kms on it. I've started to notice a nasty squeaking or rubbing noise when I turn the steering wheel clockwise at low speeds.
Anybody have any ideas what could be causing this? Low power steering fluid?
      05-26-2009, 02:52 PM   #2
JCtx
Drives: No BMW yet
That'd be my first guess, so start there; it's easy enough to do, and one of the few fluid levels you can actually check on this car. Good luck.
      05-26-2009, 11:18 PM   #3
kmac1980
Drives: '19 540xi
had this in my e90 330i, they had to replace some bushing or something in the steering column, i think there was a service bulletin on it. not sure if it applies to 08s
      05-28-2009, 09:55 AM   #4
markymarc1979
2009 BMW E93  [0.00]
I took it in for my 2000K service and they say they found nothing wrong. Power steering fluid was full. I'm just going to leave it for now and see what happens.
I'm wonding if it could be the spring shifting around in the strut tower?
      05-28-2009, 11:15 AM   #5
JCtx
Drives: No BMW yet
There are problems with silver brake rotor plates (the ones behind the rotors), which you probably have, but they supposedly only make crackling noises while cornering aggressively, and they're probably not as loud as you described.
Your best bet is to find a way to duplicate them if they become more prevalent; otherwise you'd be wasting your time at a dealer. And yes, it's probably a part of the strut, but tech must confirm it. Good luck.
      05-28-2009, 11:35 AM   #6
markymarc1979
2009 BMW E93  [0.00]
Your probably right. I'm not going to stress it. This is probably one of the best engineered cars in the world. I'll wait it out and we'll see what happens. Of course I will be sure to report my findings back to the forum for everyone elses benefit.
m3post
