HD Radio Retro?
05-20-2009, 08:45 PM | #1 |
Rep 149
HD Radio Retro?
Did a little Search, but only found old info.
I have an 09 E90, Professional radio, Blue tooth, SOS, iPod MOST Is there an easy way to retrofit the HD radio option like there is the Sirrius?
05-20-2009, 10:10 PM | #2 |
Guest
36
Rep 611
Yes it is possible. You will need to purchase a receiver for it.
2006 Black BMW 330i, Black interior, ZSP, ZPP, Logic 7, Xenon, Ipod, Satellite Radio Preparation, Moonroof, 12'' 2 P2 subwoofers running on KAC-7204 amplifier, Hardwired Escort Passport 8500, Hardwired Garmin Nuvi 650 on Kuda Mount.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog |
05-21-2009, 06:31 AM | #3 |
Rep 149
Thanks! Any idea of the parts? I searched tischer and all I saw was Sirrius stuff. and I would assume I would have to flash the radio after install?
11-02-2009, 01:39 PM | #5 |
Rep 307
Did you ever figure this out ? my 328 coupe has hd-radio and i love it. But the new 09 e90 LCI does not. Can i swap the radio from the 328 to the 335 ? or is there a add-on reciever that will do the job ? TIA
03-06-2010, 05:41 PM | #7 |
Rep 13,001
There's no official HD Radio retrofit like there is for Sirius, although you can replace your OEM HU with the MY2010 OEM HU with HD Radio and Sirius tuners built in.
03-06-2010, 05:43 PM | #8 | |
2095
Rep 43,350
I figured there was an HD radio module but replacing the receiver is just as easy. Anyone know if these are plug and play? |
03-06-2010, 05:46 PM | #9 | |
Rep 13,001
Repalcing the radio could require coding depending of your sound system and options. |
07-11-2010, 11:42 PM | #10 |
Rep 745
Technic, further to this last post of yours, if I replace my 08 e90 L7 headunit with a 2010 MY2010 OEM HU which has the sirius and hd logos on the outside labels, see below:
(http://cgi.ebay.com/ebaymotors/10-20...fAudioQ5fVideo) it should be all that's needed to have HD and Sirius ready? Assume it needs recoding at the dealer, but nothing else, such as trunk sirius module, etc? Can this recoding be done by the Audiologic tool too? |
11-24-2012, 01:42 AM | #11 |
PPRSWCE
654
Rep 1,848
Did anyone ever confirm or try this? I too have an 09 e90 LCi, Professional Radio with HiFi speaker setup... Sirius is there but no HD. All I would need is a 2010+ Professional radio and do a basic swap?
Do i need to be careful to ensure that the radio came from an HiFi optioned car? |
11-24-2012, 07:11 AM | #12 |
Rep 5,450
It is the Head Unit that has the HD radio - it isn't a separate part, so you would need to get an entire head unit. I am pretty sure it doesn't matter if it is a hifi car or not, I think the hifi is all in the amps and speakers and the signal from the head unit is the same. The head unit doesn't specifically say hifi or logic7 right on it like it will say HDRadio on it, but don't quote me on it. When I replaced my Nav to upgrade from CCC to CIC, the only difference in head units was HDRadio or Not (as europe didn't get hdradio)
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-24-2012, 12:52 PM | #13 |
Rep 54
Actually, it depends on the model year. In the recent years, the tuners have been included in the head unit as the other guys have said. However, before 2009-10 there was separate IBOC HD radio tuner module. If it was an option at the time of purchase, you should be able to retrofit it easily.
I was in the same boat as you and bought a tuner actually. Never ended up installing it as I got a 2009 that had the tuner in the receiver. The tuner is up for sale here: http://www.e90post.com/forums/showthread.php?t=642548 I think all you would need after that is the mounting bracket, antenna splitter, an open fiber optic port, and programming of course. Remember, where there's a will there's a way. Good Luck! |
11-24-2012, 01:54 PM | #14 |
Rep 13,104
fyi
01-25-2013, 04:57 PM | #15 |
Rep 762
I just installed a professional radio from an 10 with HD built in and installed in my 06. Everything works fine except volume is very low. Other than that the HD works just fine with no coding.
01-25-2013, 07:54 PM | #16 |
Rep 13,104
FYI
01-25-2013, 08:09 PM | #17 |
Rep 13,001
01-25-2013, 08:57 PM | #18 |
Rep 13,104
Technic,Why would the volume be Low?
Since the only other possibility for analog output would be stereo which basically means a higher output voltage? Have you seen this before ? Do you use the same programming files or do you have to change the build date and use the newer ones after removing the old one? Or do you just do a simple parameter change inside the existing file? Just curious. Last edited by ctuna; 01-25-2013 at 09:43 PM.. |
12-27-2013, 08:30 AM | #19 |
Rep 132
I have a 2007 E90 with bluetooth and Logic 7, I was looking to upgrade to a newer stock HU with HD Radio and built-in USB. How would I know what radio will or wont work on my car?
UPDATE I just found this HU on eBay, might it work for my car?
2007 BMW 335i, My commuter car 2016 Jeep Cherokee Trailhawk, the other car Driving Fast and Unsafe Around The Bay Area. Last edited by Debacle of Mass Eruption.; 12-28-2013 at 06:36 AM.. Reason: Update |
12-27-2013, 10:13 AM | #20 |
Rep 13,104
It requires some complicated programming.
It needs to be done by a coder, BMW won't do it for a car in the year the radio wasn't issued or maybe even a US car. http://www.e90post.com/forums/showthread.php?t=687463 also something on it in last portion of this thread. http://www.e90post.com/forums/showthread.php?t=928243 like where to get one. If you get one for and L7 you need one with Most Bus. Last edited by ctuna; 12-27-2013 at 10:24 AM.. |
12-28-2013, 05:30 AM | #21 |
Rep 132
Thanks for the prompt response, ctuna
I know there are a few tutorials, but they don't really specify if the HU has HD Radio as well. The 2010 HU, from what I was told, came with HD Radio stock. Would you happen to know a model# so I can start searching online?
Please let me know if you can
2007 BMW 335i, My commuter car 2016 Jeep Cherokee Trailhawk, the other car Driving Fast and Unsafe Around The Bay Area. |
