E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - repairing curb rash on a 162 rim
      08-03-2006, 12:29 PM   #1
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
EDIT: Nov. 19, 2007 - pictures re-uploaded
This post is designed to complement the already excellent post on repairing curb rash on a Porsche wheel here. I am merely adding a few more photos, as well as proof - for those, like me, who need additional reassurance - that the process will work on BMW wheels, too.
Note that, unlike the OP, I removed the wheel to make the job easier and to avoid the risk of any paint going on my black bodywork. It DOES fly everywhere!
Here's the damage. Only cosmetic, fortunately, but it had to be repaired and the garages & bodyshops I contacted were quoting me $200 + 3-4 days w/o the car, as, of course, there's no spare wheel (great idea that, BMW!).
Shopping list (approx $30):
  • emery paper, 4 sheets (1 each of 180, 240, 400 & 600 grain)
  • white spirit/paint thinner
  • masking tape + adhesive tape
  • 1 small pot aluminium putty (you hardly use any)
  • grey primer spray
  • "alloy wheel" silver spray
  • clear varnish spray
Begin by thoroughly cleaning the affected area of the rim with the white spirit on a clean cotton rag. This is IMPORTANT.
Then, using the coarsest emery paper (180), wrap a strip around a knife handle to achieve a flat, yet manoeuverable tool. Finish off carefully with the paper around your finger, if necessary.
I was amazed how much better the rim looked already after just 2 minutes of rough sanding:
Cut some short strips of masking tape and mask off the tyre ready for the putty. Make sure the tape is pushed as far into the lip as possible between the tyre & the rim.
Mix the aluminium putty & hardener as per the instructions on the tin. It begins to harden after 60 seconds or so, which is why you should mask first.
The wheel should look something like this once the putty has dried.
The instructions on the tin recommended the putty be left to dry for 4-6 minutes, but I left it for 20 for good measure, then sanded it down using the next grade of emery paper (240) until it was smooth and looked like this.
The wheel should now look like this (alreay a lot better):
Now the scary bit - painting. Begin by masking the entire wheel, cutting a circular piece of newspaper to fit around the damaged area. Note this applies ONLY to the primer stage: do not make a hard mask line for the silver spray (more on this later).
Now spray the primer as SLOWLY as possible. I put on three coats, waiting 20 minutes between each application.
Now, using the 400 or 600 emery paper, lightly sand the primer to roughen it up and feather the hard edges.
Now mask the centre of the wheel again, but DO NOT create a hard edge on the rim, or else paint lines will build up during the spraying. I formed a slight inverted cone shape with the newspaper and stuck it to the centre of the rim in such a way that the edge (which I had 'traced' by pushing the original sheet around the tyre-rim lip) stood proud of the outer part of the rim. This avoids spraying the rest of the rim needlessly (and messily), while achieving an invisible feathered 'edge' to the paint.
I sprayed 4 coats of silver - be patient and spray as little as possible each time, allowing 20 minutes minimum for each successive coat to dry.
Repeat the process with the clear varnish (3-4 coats). Avoid the temptation to rush this part - leave plenty of time for each coat to dry and avoid spraying too much in a single pass!!
Hey presto, the finished wheel. Leave overnight then put it back on the car and give it a polish to buff out any remaining overspray, dirt, etc
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
      08-03-2006, 01:53 PM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
WOW Good Job man
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-03-2006, 02:25 PM   #3
toughluck
toughluck's Avatar
Drives: 2007 e92
      08-03-2006, 03:45 PM   #4
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
Damn good post! I want to do this next month when I have the time.
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      08-03-2006, 04:27 PM   #5
Hunter399
Hunter399's Avatar
323
Drives: F90M5
impressive!
      08-03-2006, 04:59 PM   #6
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
impressive. my friend hit my rear bumper on my old car (benz) i did about the same thing and now i looks brand spankin new! nice job
comment: might want to wet sand paper the rim after u bondo it and after u prime it help a lot rather than dry sandpaper.
      08-03-2006, 06:05 PM   #7
KL2DC
KL2DC's Avatar
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
Very well done, Paul
Admin, please add the DIY master list. Thanks
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      08-04-2006, 07:37 AM   #8
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
Thanks. I think the trick to getting a good finish is 'soft masking' the rim so that the spray paint is feathered. The job took all day from start to finish, but there was a lot of waiting around for the various layers of paint to dry.
      08-12-2006, 12:32 PM   #9
06E90Rostik
2006 join date crew
182
Drives: 2006 325i, 2011 335i
2011 335i  [10.00]
2006 325i  [0.00]
Defenetly Add to Master List
Thanks Paul Great job
      08-12-2006, 10:10 PM   #10
yamazaho
Wang D.D.S.
yamazaho's Avatar
Taiwan
185
Drives: 14' WRX, 15' W205
2006 325i  [7.76]
Oh wow~~~
Oh wow this DIY is definitely some of the best ones, I mean skill wise.... All I can really say is YOU THE MAN dude!!!!! Rock on!!!
      08-13-2006, 02:36 PM   #11
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
VERy impressive. Wheel looks great!
"Teach the ignorant. Ignore the stupid."
      08-13-2006, 03:06 PM   #12
Pretender
Pretender's Avatar
150
Drives: 06 330i, 07 328i, 16 X1, >17M2
06 330i  [0.00]
I'd like to see the up-closed picture of the finished product...Can you post?
It's a great time to be alive
      08-14-2006, 08:36 AM   #13
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
It's not that I don't want to, but honetly there's nothing to see. You'll just have to trust me; the wheel looks as good as new
      08-14-2006, 08:49 AM   #14
txusa03
Drives: TS330iPPSP6MT
Question on the clear varnish...when you applied the clear coat, do you applied the clear to the whole wheel? Very nice work.
      08-16-2006, 07:03 AM   #15
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
The varnish was applied to and around the damaged area using the soft masking technique explained above. I would say that no varnish went more than about 8cm in towards the centre of the wheel from the outer lip.
      09-16-2006, 12:15 AM   #16
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
Just to report - as requested - that 6 weeks and 4000km later, the repair is holding out: no putty or paint has peeled off the wheel
      09-16-2006, 12:43 AM   #17
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
can this be done for chrome wheels too?
cause my wife scraped one of her 22's on her SUV.......
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      09-16-2006, 10:01 AM   #18
jorgex
jorgex's Avatar
Portugal
64
Drives: F30 - E92, E90, E46 (Retired)
Bravo!!!!!!!!!!!!!!!!
Very well done! Just like a professional!
      09-16-2006, 10:29 PM   #19
EvanL
Drives: '07 335i, '23 330e
Very nice! I plan to do this on my scraped-up ZCP wheels.
-Evan
E92 335i/G20 330e
      09-16-2006, 11:10 PM   #20
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2018 BMW M3  [0.00]
2006 325i  [0.00]
That looks so so good! I think it looks like you never scraped it! Great work! Thanks
      09-22-2006, 01:08 AM   #21
Paul330d
Torque junky
Paul330d's Avatar
France
115
2006 330d  [0.00]
I suppose you could try, but I would imagine that replicating that mirror finish would require a lot of skill. I for one wouldn't feel comfortable attempting it, although I have seen chrome spray cans for sale.
      11-26-2006, 01:23 AM   #22
Safety2213
Safety2213's Avatar
Serbia
15
Drives: 2011 BMW 135i Manual M-Sport
I did this and wet sanded the clear coat with 1500 sand paper and buffed out with polishing compound to get the factory shine and smooth feel. The clear coat felt rough. I used Wurth's while in this post another brand was used. Not sure if it makes a difference. Thanks for the post.
e90post
