Parrot + 2connect + speaker + amp install pictures
04-17-2009, 02:16 PM | #1 |
Rep 2
Hi, I'm about to install a Parrot CK3000 Evolution with the 2Connect PPAR009 steering wheel adapter to my E90. I have the simple Business radio without an original amplifier, so I used the PPAR009 cables to splice in a Helix AAC line converter to connect the front lines an RCA cable to the trunk, where I have an aftermarket amplifier.
It was a lot of stuff to fit, so I eventually mounted everything onto the footwell cover under the steering wheel. Now its really easy to connect everything and the location is ideal to route the microphone, RCA with wake-up signal and radio cables. Here a picture of the parrot stuff + some from the actual audio installation as well. Cheers, Nikke Amplifier Eton 500.4: Steel adapters for midspeakers Eton 110 Pro: Mounting plate glued in place: Door panel: |
