DIY - BMW Performance Air Intake System (European)
04-07-2009, 11:04 AM | #1 |
Rep 1,166
Well, i just got my performance intake system and only found that mine version is for the european market. Well, after some search and couldnt find one from the board except the US version which is very different.
So, i think with this little DIY would help those european version (like mine) to install it with confidence. Enjoy! A quick look at the the 2 different filter, OEM is yellow. Tools you will need: -A screw driver -Torx 15, 20, 25 1. Remove the screws circled in red 2. Remove the intake channel and intake box cover. 3. Remove the old filter by pressing both the plastic tension pieces inwards to free from the catch and lift upwards. 4. Remove the 2 brackets in the upper right hand corner. Pull up the top bracket 5. Followed by the lower bracket which you need to unscrew it. This is a plastic screw, so be gentle and use the correct size of screw driver. 6. Install new filter. make sure the centre hole sits correctly towards the intake tunnel while pushing the filter forward to secure in place. 7. Install the new brackets. Its a tight fit so you need to make sure this big bracket sits there lining up the holes of the screw. Then, use the plastic screw which you removed in step 5 to secure it. 8. Install the new CF air channel. You can put back the 2 front screws to half secure it so you can adjust the intake box cover later to fit. 9. Slid in the new intake box top cover. Here, you have to press the top cover gently to fit in the lower box in the correct manner or you wont be able to locate the screw hole correctly. Once the screw holes aligned, screw them tight. 10. After making sure that there's no gap between the CF channel and the top cover, you can now tighten all the screws as in step 1. 11. Stand back and admire your new Performance CF Intake.
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
04-07-2009, 11:49 AM | #2 |
Rep 6,563
nice diy, how much does the euro version cost and you had any chance to drive the car and notice any improvement in performance?
under construction! |
04-07-2009, 02:15 PM | #3 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
so your saying that you don't really need to remove the air box at all... you just unscrew the tops and put on the new top... and the new ducts
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
Sge92x19.50 |
04-07-2009, 02:41 PM | #4 |
pull my finger to get your kinder® surprise
148
Rep 10,455
I hope it's way less than what we're paying here in North America. Looking at OP's pics and pics from Allan's installation of the NA-spec'd performance intake, it looks like there's not much difference between the regular OEM EU-spec'd intake and the performance intake. The shape of the airbox is the same and the filter is pretty much the same. With the NA-spec'd performance intake, it relaces the stock airbox and changes the filter.
04-07-2009, 02:43 PM | #5 |
148
Rep 10,455
for the Euro version yes. But for us in NA, the airbox is replaced with the performance one (which resembles the OEM EU stock airbox).
From Allan's DIY NA stock airbox and filter
04-07-2009, 05:20 PM | #7 |
boku no namae ha...
336
Rep 11,025
why's that?
04-07-2009, 06:50 PM | #8 | |
Rep 1,166
Drove the car a little, throttle felt more responsive. Will update more once i go on the open road!
04-07-2009, 06:51 PM | #9 |
Rep 1,166
yes. Its a lot easier than the US version.
04-07-2009, 06:53 PM | #10 |
148
Rep 10,455
seems like the Euro version is less restrictive in that with the euro version, more air can get in with the cone filter while with the NA ones, less air gets in due to the flat filter that we have (even with the performance version, the filter is still flat)
04-07-2009, 06:54 PM | #11 | |
Rep 1,166
It cost a little close to USD1100 But i think i paid mainly for the CF piece and the words (BMW Performance) on it
04-07-2009, 07:01 PM | #12 | |
Rep 1,166
But i think the US intake box is different due to that yours are 3l engine instead of 2.5l engine for the euro
05-18-2009, 03:28 AM | #15 |
Rep 230
That filter element looks a lot like the K&N drop in filter for the euro cars. I just ordered my filter and should have it in another few days, so I guess I can scratch off BMW performance intake off the list.
K&N part no E-2022, ordered from AutoAnything in Cali. |
08-20-2009, 04:51 PM | #17 |
Rep 941
Nice writeup, thanks. So apart from the filter, the duct to the windscreen, and some CF, its not much different to the normal euro intake. Good to know! I'm thinking of just trying the filter now if I apparently have 2/3 of the BMW performance intake already.
I'm also curious to know what the difference in sound and performance is like given that it's not such a radical change on euro cars as it is on US cars? |
09-30-2009, 12:46 PM | #18 |
Rep 129
¿Do you think I can just get the filter to put in my car (2008 Euro Spec 330i)?
¿Anyone have the part number for it?
2008 E90 330i TiAg / M-Tech Aero Kit / OEM Carbon Fiber Diffuser / M-Tech Suspension / M-Tech Steering Wheel / OEM Rear Deck Spoiler
01-03-2010, 08:30 PM | #19 |
Rep 20
Hi guys can anyone advice by doing this mod, will we void our warranty if the installation is by done by our own and also do we need to do some re-programming on for the ECU?
01-03-2010, 10:25 PM | #20 |
Rep 2,589
not sure where you can order euro spec performance intake in US.. not even the sponsors in this forum could get it.. plus you would have to order the housing too since it require part of standard euro intake housing
01-04-2010, 01:05 AM | #21 |
Rep 20
Sorry for the confusion. I am using this thread as example which I would want to find out if I am ordering the US version from Trisher as a DIY; would my current warranty be void and also any re-programming for the ECU is required?
