      04-01-2009, 11:04 PM   #1
theanhdy
theanhdy's Avatar
93
Drives: 135i
DIY: JB+/SSTT Skinny man install
How to install JB+ on a 135i without removing the stock air box!!!
Don't even try this if you have massive forearm, ask your girlfriend to do it.
Tools:
8mm ratchet wrench
Flash light
USB cable
Skinny arm
Remove the two 8mm nuts securing this fluid reservoir
Lift the fluid reservoir and bracket out of the way to expose enough space to reach the TMAP sensor
DO NOT attempt to do this while the engine is HOT or you'll burn yourself!!!
Reach down with your hand and get a feel of where the TMAP sensor is (If this space is too small for you to work with then you're better off removing the stock air box). Be very careful not to break the plastic clip securing the stock harness onto the TMAP sensor. Gently slide in the USB to undo the plastic clip and pull out the stock harness at the same time (Hint: under and up reach around method). Connect JB+ and enjoy!!!
      04-02-2009, 12:38 AM   #2
Alext
Drives: B M W
Good post. You have to do this all with one hand I assume???
      04-02-2009, 12:57 AM   #3
theanhdy
theanhdy's Avatar
93
Drives: 135i
Yup all one hand and mostly by feel
      04-02-2009, 08:20 AM   #4
jtsherri
jtsherri's Avatar
Drives: TBD
2008 135i  [10.00]
Now that's impressive... having done it quite a few times now, I'm sure I could pull it off, but have never dared try. Well done, sir!
      04-02-2009, 08:27 AM   #5
Citizen Z
Alpine Master
Citizen Z's Avatar
Drives: '08 135i AW Sport
I dunno, man. I found the SSTT to be a pain in the ass to install, even with the airbox removed.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727
      04-02-2009, 10:03 AM   #6
theanhdy
theanhdy's Avatar
93
Drives: 135i
It takes me longer to put on my shoes than to install SSTT
      09-29-2009, 01:14 PM   #7
Jcrewsn
Drives: 2009 BMW 135i
2009 135i Sport  [0.00]
Do any of you know if the install for the SSTT and SSTT2 are similar/same? I just purchased the SSTT2 and am hoping I won't have any trouble with the install...
      09-29-2009, 05:13 PM   #8
jibaholic101
Drives: women wild
what happened to the diy?
some italian, german, and japanese ones; and on order more of the same
      10-07-2009, 02:22 PM   #9
Simon_135i
Collecting dust!
Simon_135i's Avatar
55
Drives: 135i
2008 E82/135i  [0.00]
Help with the DIY?
      10-07-2009, 02:28 PM   #10
Jcrewsn
Originally Posted by Simon_135i View Post
Help with the DIY?
If installing the SSTT2 I suggest you just go to the splitsec website and follow their instructions. I did it and although I did not find it easy I got it done.
There is also a DIY on here which tells you how to take the airbox out. follow that and then go to the splitsec.com and follow their instructions on the install
      11-03-2009, 03:36 PM   #11
theanhdy
theanhdy's Avatar
93
Drives: 135i
i put it back up
      11-12-2009, 09:07 AM   #12
Jcrewsn
attempting this this morning... hope all goes well, got my first visit to the service dep.
1addicts
