Transmission question
03-21-2009, 03:30 PM | #1 |
Rep 75
Hi Guys
Got my car today. 335 i Xdrive, coupe, sports package, paddles etc.great. it had 2 miles on it. drove it for 120 miles in the highway AMAZING ! I think though there is a problem : when I start going from a stand still (automatic transmission ) there is a bump i feel and the gear shifts is just not right/smooth. it only happens on very low speed just at the very beginning, not when I am on higher speeds. again, it feels like the transmission gets stuck and than continues, it does not feel normal to me ,Any suggestions/ experience with this ? Thanks |
03-21-2009, 03:56 PM | #2 | |
Rep 274
Known (now thanks to these boards) software issue. SI B 24 03 08 Automatic Transmission January 2009 Technical Service This Service Information bulletin supersedes SI B24 03 08 dated July 2008. designates changes to this revision SUBJECT E9x, E6x with 6HP19TU - Jolt and Delay when Pulling Away MODEL E90, E92, E93 (335i) with N54 and 6HP19TU from 03/07 E60, E61 (535i) with N54 and 6HP19TU from 03/07 E60 (528i) with N52K and 6HP19TU from 03/07 SITUATION The customer may complain of a delayed engagement and a harsh jolt when accelerating from a stop. The situation occurs only during the engine warm-up phase (cold engine), and cannot be reproduced in the Sport Mode. CAUSE EGS software (unfavorable NIC – Neutral Idle Control) calibration SOLUTION On a customer complaint basis only, check the vehicle's integration level. If the integration level is: On E9x vehicles - E89x-07-06-520 or lower On E6x N54 vehicles - E060-07-09-530 or lower On E60 N52K vehicles – E060-08-03-550 or lower Reprogram and recode the complete vehicle with a current Progman version (target levels are E89x-07- 09-518; E060-08-03-510; and E060-08-09-520, respectively, for E9x, E6x N54 and E6x N52K vehicles). Important Note: The NIC (Neutral Idle Control) feature disengages the torque converter from the transmission when the vehicle is stationary in the Drive position; the service brakes are applied; and the engine is still in the warm- up phase. The NIC function eliminates engine load when vehicle is stopped, reducing fuel consumption. Although the EGS software changes (as listed above) are improving transmission comfort feel while still providing the benefits of the NIC feature, they still may not be acceptable for the most discriminating customers. In such a case, on a customer complaint basis only, deactivate the NIC function by performing the "Converter lockup clutch" retrofit, using the current Progman/ISTA P version. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code: 24 00 33 98 00 Labor Operation: Labor Allowance: Description: 61 00 801 7 FRU Programming coding modules without CAS 61 00 811 8 FRU Programming coding modules including CAS [ Copyright © 2009 BMW of North America, LLC ] |
03-21-2009, 04:54 PM | #6 | |
Rep 75
I gues I need to print this out, schedule appointment with the service department and get there asap. BTW : it happened to me when I had been driving for an hour, the engine temp was ~ 250, so I guess the warming-up phase had already been passed yet, I still had this problem. Is there any concern for damage ? Thanks |
03-21-2009, 05:04 PM | #8 |
Rep 13
I just got a new e90 LCI 335xi 6AT too. It's one week old. The first day I also felt a clunk from the transmission, but it disappeared the next day. I haven't noticed it since (I drive it daily to work and back, but only 100 km total so far)
Current: 2011 e93 M3 ind Azurite Black/Rust Brown/DCT/220M 2009 e90 335 xdrive TiAg/Black/6AT/ZSP Gone but not forgotten: 2008 e93 335i AW/CR/Gray poplar/6MT/ZSP/Style 230 |
03-21-2009, 05:15 PM | #9 |
Rep 75
Got back from another ride. this time I kept the car on the sport mode - (automatic), the noise/bump were just gone. the car was smooth and did not make a sound.
BP |
03-21-2009, 05:56 PM | #10 |
Rep 984
03-21-2009, 06:06 PM | #11 |
Rep 3,883
Drives: Audi RS Q8
What's 15 degrees between friends?
03-21-2009, 06:09 PM | #12 | |
Rep 288
Here's my TSB: I B 24 03 08 Automatic Transmission September 2008 Technical Service This Service Information bulletin supersedes SI B24 03 08 dated June 2008. designates changes to this revision SUBJECT 335i, 535i with N54 and 6HP19TU - Jolt and Delay when Pulling Away MODEL E90, E92, E93 (335i) with N54 and 6HP19TU from 12/06 up to 09/07 E60, E61 (535i) with N54 and 6HP19TU from 03/07 up to 03/08 SITUATION The customer may complain of a delayed engagement and a harsh jolt when accelerating from a stop. The situation occurs only during the engine warm-up phase (cold engine), and can not be reproduced in the Sport Mode. CAUSE EGS software (unfavorable NIC – Neutral Idle Control calibration) SOLUTION On a customer complaint basis only, check the vehicle's integration level. If the integration level is: * On E9x vehicles – E89X-07-06-520 or lower * On E6x vehicles - E060-07-09-530 or lower Reprogram and recode the complete vehicle with a current Progman version (target levels are E89X-07-09-518 or E060-08-03-510, respectively, for E9x and E6x vehicles). WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. |
03-23-2009, 03:51 PM | #14 |
Rep 75
An update
This problem has gone. dont know how and why, i guess someone else mentioned his car did the same, and that the problem was gone after 24 hours, same thing here. test driven it on cold engine, nothing's wrong, as smooth as butter. i wonder if this is just the nature of this car,system "learning" process ? Anyway, thanks for your advice. I now can say I am a new owner of a BMW and I am LOVING IT !!! BP |
03-23-2009, 05:34 PM | #15 |
Rep 171
I had a similar, but slightly different, experience with my now two-week old 335i X-Drive AT. The first day, taking off from a standstill was smooth, but the 1-2 shift seemed excessively abrupt, and I felt it was something I'd have to have the dealer look at. A few days later, it's smoothed out completely. Maybe there indeed is some initial break-in/adaptation occurring with brand-new automatic transmissions.
03-23-2009, 05:38 PM | #16 |
Rep 13
That's what I think happened to me.
