Headlamp washers
03-20-2009, 07:58 PM | #1 |
Rep 1,107
Headlamp washers
How do the headlamp washers work? The owner's manual states that they will spray at regular and appropriate intervals. Do the headlights have to be on, or is it okay to leave it in the auto setting?
Thanks for the help. |
03-20-2009, 08:09 PM | #2 |
Rep 4,558
They will only come on when the headlights are actually on. It is on the first spray of the windshield washers and I think every 5th time after that, but I could be wrong.
03-20-2009, 08:46 PM | #4 |
Rep 1,107
03-20-2009, 08:47 PM | #5 |
Rep 1,107
03-20-2009, 09:38 PM | #6 | |
Rep 3,883
Drives: Audi RS Q8
PS: I reserve the right to be wrong too. |
03-20-2009, 11:27 PM | #7 |
Rep 1,938
As a rule, the manual is of much help, but when reading it, one often encounters doubletalk statements as you did. Manual for some reason attempts to avoid saying how the spray system works by including the sentence you have quoted. Many BMW owners recognize that the phrasing 'regular and appropriate intervals' is logically irreconcilable, which makes them lose confidence in the manual.
03-21-2009, 12:01 AM | #8 |
Rep 6,805
On earlier cars, the headlight washer will not pop out unless the headlight (Xenons) is on (literally on, regardless of the switch position is in Auto or On)
If you pull the lever long and "further" enough for the windsheild washer fluid, the headlight washers will also pop out to clean your headlights (when the headlight is on) If you don't have xDrive, I don't think the Canadian cars have the headlight washers. They are only dummy covers.
MY07 A22 E90 N52Nxi
03-21-2009, 12:55 AM | #9 |
Rep 5,018
Drives: VALNCYA
When you activate the windshield washer hold it for 2 seconds the xenon washer will eject and operate.
03-21-2009, 01:07 AM | #10 |
Rep 3,883
Drives: Audi RS Q8
Sorry, that's ridiculous. In my experience, the headlight washer comes on the instant the regular spray comes on. There's no need to hold it for any number of seconds.
03-21-2009, 01:24 AM | #11 |
Rep 75
sorry for this noob question, but what is the purpose of the headlight washer? If the fluid heated? If so maybe it benefit those on the east coast when ice form on the headlights? I dunno...
03-21-2009, 02:04 AM | #12 | |
Rep 3,883
Drives: Audi RS Q8
Also, per the manual: The windshield washer nozzles are heated automatically while the engine is running or the ignition is switched on. |
03-21-2009, 02:29 AM | #13 |
BMW, can I have some LSD please?
88
Rep 1,591
I don't know about you guys, but on my previous E46, I had to disconnect the wires to the headlight washer pump. It was very annoying when it sprayed washer fluid every 5th time all over the car when I only wanted to get a little bit of washer fluid to clean the windshield.
I'm glad my current E90 doesn't have these doodads!
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
03-21-2009, 08:54 AM | #15 |
Rep 561
Not sure if the timing is changed from the '07 but it sprays on the first pull of the windshield washer stalk when the headlights are on, then every 4th pull afterwards.
It will spray in twlight mode (angel eyes on)...so the headlights either have to be off with enough daylight while in AUTO mode or the switch is put in OFF position for the headlights washers not to spray.
-Chris
2007 Montego Blue 328xi Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2 |
03-21-2009, 09:00 AM | #16 | |
Rep 358
They do however make great sense for the manufacturers of winter anti freeze windshield solution since in winter I go through a bottle (just under 4l) of the stuff every week. |
03-21-2009, 03:18 PM | #18 |
Rep 1,088
03-21-2009, 04:05 PM | #19 |
Rep 1,107
Thanks, I guess I don't have them because I don't have Xdrive, the price to pay for RWD fun I guess. I just liked them on my previous cars because I drive through salty roads most of the year.
03-21-2009, 04:06 PM | #20 |
Rep 3,883
Drives: Audi RS Q8
If you had ordered the Cold Weather package, you'd have them.
03-21-2009, 04:56 PM | #22 |
Rep 3,883
Drives: Audi RS Q8
Do you have an 09?
