Aiming Headlights According to DOT Specs
03-16-2009, 04:24 PM | #1 |
Rep 177
Hey Guys,
I just dropped my car on coilovers this weekend, and now my headlights are aiming too low (Xenons). I found a bunch of posts in the Suspension section showing where the screw is to adjust them, but I can't find anything that actually shows how to adjust them according to DOT spec, or how to get them to the proper factory level. The only thing I found is the below URL, but that link seems to be broken: http://www.danielsternlighting.com/tech/aim/aim.html Any suggestions on how to adjust these properly? |
03-16-2009, 04:31 PM | #2 |
One cam is enough
130
Rep 6,801
Hmm I did this years ago when I put Euro ellipsoid xenons on my E36 M3. There's plenty of info on bf.c.... Let me see what I can dig up....
EDIT: Here a guy explains it in this thread. I can't remember exactly if this is right. I thought I remember backing up 15 feet for the re-measure. Oh well.... http://forums.bimmerforums.com/forum...+ellipsoid+aim |
03-17-2009, 10:32 AM | #3 | |
Rep 177
Cool thanks. So this is what you were talking about, right?
03-17-2009, 10:34 AM | #4 |
One cam is enough
130
Rep 6,801
Yes that's exactly it. Your beam pattern will look the same. Mine actually was more like __/\_/\ or something along those lines but I'm sure it's fine. There were horizontal and vertical adjustments with those; not sure about the E90/1/2/3...
Follow those steps and you're golden. |
03-17-2009, 10:46 AM | #5 |
n00b
Rep 178
Here's what I used for my e46: http://www.danielsternlighting.com/tech/aim/aim.html
His: 08 E92 335i (sold), 99 Corolla beater car
Hers: 09 Tiguan Previous: 09 e93 328i, 04 WRX, 07 S40, 03 E46 330xi, 04 F4i, 04 EX250 |
06-04-2009, 11:08 PM | #6 |
Rep 2,325
i just give my lights about 1.5 turns counter-clockwise to have it up a little higher, they where way too low from the factory - didn't illuminate far at all.
06-05-2009, 08:06 PM | #8 |
Go Terps!
53
Rep 1,375
Drives: 2009 SSII/FR E92 M3
Good question. Would like to know as well.
06-06-2009, 05:58 AM | #9 |
Rep 3,415
Two suggestions:
Go to Hella's website. They may have the drawing there that comes in their aftermarket headlights that you can use as a guide to aim you xenons. Or, what I do is find a school or building that has a big brick wall and parking lot. Set your car about 15 feet from the wall at night of course, and start aiming the headlights using the vertical adjustment screw. There is a DIY on the procedure. Use the mortar lines on the brick wall to get the lights even in height. Then do some experimentation on where you like the height. The DOT spec is too low. |
06-06-2009, 08:06 AM | #10 |
Rep 2,325
what's the big deal, give it one full turn counter, you will be much happier
i did that on my E92 a couple of days ago and no one flashed back at me, not even the multiple cops I saw at night passing by. |
