Why Do I Have Low Oil Pressure after Oil Change?
03-16-2009, 02:51 PM | #1 |
Rep 20
I changed the oil in my '06 330xi yesterday. There were no problems, everything went smoothly. But now, I have a yellow "Service Info" warning coming up: yellow oil can without the waves under the oil can. The owners manuel says this is a low oil pressure warning. I've been changing the oil on my cars for over 25 years. This is the first time this has happened.
The oil level is ok when I check it, but the word "Inactive" appears beneath the oil level monitor. Nothing else is there, just the oil monitor bar and "Inactive" I did reset the computer after the oil change. So, why am I getting the low oil pressure warning? Any help would be appreciated. Thanks. |
03-16-2009, 08:00 PM | #2 | |
Rep 1,938
This may be unrelated: Changing oil on my motorbike, I had a low oil pressure problem once, when the square gasket on the spin-on filter failed, causing a minor oil leak and major loss of oil pressure. Are you sure that the the two O-rings, which seal the oil filter on the N52 engine, are OK? Can you see any oil seepage from the oil filter assembly? |
03-16-2009, 08:59 PM | #3 |
Rep 648
If it says "Inactive" on the oil level readout, then there is a problem. It's either the oil condition sensor, dme, wiring, or another sensor on the BSD. I would take it to a dealer for diagnosis.
03-16-2009, 09:03 PM | #4 |
Rep 2,707
If the level is correct the only thing I can think of is that there some sort of an obstruction in the oil filter housing that prevent the oil to travel freely. Check the filter and make sure everything is in place correctly. Next step would be a trip to the dealer.
zhpregistry.net - ZHP stats and free classifieds.
03-17-2009, 11:28 AM | #5 |
Rep 20
Thanks for all the responses. I'll pull the oil filter and make sure everything is on properly and re-installed properly. The "Inactive" status on the oil level monitor was there even before the oil change. I probably will have to have a dealer check that out. Thanks again.
03-17-2009, 02:09 PM | #6 | |
Rep 1,938
03-17-2009, 06:51 PM | #7 |
Rep 20
Well, I pulled the oil filter and it and the o-rings were on correctly. I did notice that the very tip of the plastic part that the small green o-ring goes around was chewed up a bit. I don't know if it was like that before I changed the oil or not.
If not, maybe I damaged it somehow when I changed the oil and platic bits got into the oil supply and are partially blocking a hole. No debris anywhere that I could find when I sucked out all the oil in the filter housing, though. I did see a small black bit of something (could have been plastic) on the filter. So, if there is something blocking a hole hopefully it'll work it's way loose and not damage anything (like a bearing!) and end up in the oil pan or filter. Is there something like an oil system flush like there is for radiators? Thanks for your help and interest. |
03-17-2009, 10:19 PM | #8 |
Rep 648
That o-ring is supposed to be replaced at every oil change, a new one comes in the package. If it's chewed up, it might be letting oil past it, causing your problem. Replace that o-ring and see if it helps. Just to clarify, the oil filter package should have an oil filter, crush washer, large black o-ring, and small o-ring.
03-17-2009, 11:13 PM | #9 | |
Rep 3,341
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
03-17-2009, 11:47 PM | #11 |
Rep 1,938
There apparently is, but I've only had it described at a BMW dealership, I've never seen nor used it. Fortunately, SoCalTech responded, and he is a professional, he would know.
03-18-2009, 09:29 AM | #13 |
Rep 20
Thanks for the responses. I did install both new o-rings and new crush washer when I did the oil change. When I pulled the filter yesterday to double-check my work, both o-rings were intact and in their proper place. The part that was somewhat chewed up was the very tip of the platic rod that the green o-ring goes around.
The part I'm referring too is hard to describe (and maybe unique to the xi, but I doubt that) but it looks just like the tip of a phillips-head screw driver. Four ridges in the shape of a plus sign (+), with one of the ridges missing. The green o-ring sits about a quarter inch below this tip. I'm just wondering if a bit of plastic from this tip got into the lubrication system and is blocking the oil flow. If so, I'm wondering if an oil system flush might dislodge it. |
03-22-2009, 09:52 AM | #14 |
Rep 20
Well, this problem seems to have cleared up on its own. For the past two days I've not had the low oil pressure warning. I didn't do anything to try and fix the problem. If there was a bit of plastic or grit in the lubrication system, maybe it's no longer a problem. Maybe the computer just needed a few days to reset itself after the oil change. It did take the computer a few days to register the new oil level that was in the car, so maybe....
Thanks for the help and suggestions. |
