Adaptive light direction
03-11-2009, 10:14 PM | #1 |
Rep 2,653
Hey all, has anyone pulled up to a garage or wall and seen which direction thier Adaptive lamps actually move when turning the wheel? I turned the wheel to the right and both Xenon lamps moved towards the center. One high beam lamp came on, greatly illuminating the area in the direction of the turn (that's the point), but I figured the Xenon lamp on that side would also move in that same direction. It doesn't. Does that seem odd???
03-11-2009, 10:16 PM | #2 |
Been There, Done That.
652
Rep 4,728
The lights don't move to the left significantly as to not blind on coming drivers when you are standing still. When you are moving is when you'll see both headlamps move. If you have a coupe, then your cornering lights will turn on below I think 25.
P.S. One high beam can't come on. It's both or none. And it's not automatic. You have to pull the stalk. |
03-11-2009, 10:17 PM | #3 |
wat
235
Rep 3,406
not the entire headlight moves. im pretty sure they do stay straight and separate lights turn with you. and when you make sharp turns you get that corner light going on like you listed
2012 Toyota Highlander SE - PAST - 2008 e92 335i, 2006 e90 325i |
03-11-2009, 10:23 PM | #4 |
Rep 2,653
I was standing in front of the car with my wife turning the wheel. Both Xenon lamps angle in towards the center, and JUST ONE high beam lamp comes on (same side as the direction your turning). I just think that both Xenons would move towards the direction your turning. Instead, one moves in the opposite direction of the turn.
I'll get a pic of the single high beam tomorrow... it's late on the East Coast. |
03-11-2009, 10:35 PM | #5 |
Rep 1,029
On my '09 E90 the high & low beam is the xenon lights, the other 2 lights are the adaptive lamps, so when I turn the steering wheel you see the Xenons move plus the adaptive lamp turns on on the direction of the steering wheel, if I go in reverse both adaptive lamps will turn on.I know this is new for the '09 E90 not sure for the E92....
But the xenons do turn slightly to the direction of the steering wheel on my car.... good luck!!!
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
03-11-2009, 11:10 PM | #6 | |
652
Rep 4,728
The adaptive headlights aren't the corner illuminating lights. Those are called Cornering lights. The headlights are adaptive. The Bi-Xenons move with the wheel. That's what they mean by adaptive. The cornering lights do not move with the wheel. You perceoption of what the adaptive lights are is completely wrong. |
03-11-2009, 11:14 PM | #7 | |
652
Rep 4,728
P.S. |
03-12-2009, 12:16 AM | #8 | |
Rep 3,883
Drives: Audi RS Q8
03-12-2009, 08:19 AM | #10 | |
Rep 2,653
I did and it does mention the cornering lamp (on page 84 of the E92 manual), which I thought was a high beam. My bad. But while you were so busy roasting me for not , you obviously didn't . My question focused around the fact that I think one of my headlamps wasn't going in what I thought would be the correct direction. I was asking if they both moved in the same direction; when I read my manual, it merely states that "...the light from the headlamp follows the course of the road." At what point does the manual tell me that BOTH headlamps (mind you that is plural, unlike the manuals singular use of the word... ) should move in the direction of the wheel??? |
03-12-2009, 08:27 AM | #11 |
Rep 974
Like I said, drive with the high beams on to find your answer. They will function differently when the car is stopped as another poster has already mentioned.
I get both lights moving side to side if that helps. |
03-12-2009, 08:41 AM | #12 |
Rep 2,653
Thanks Hermes + Beto! Seriously, that was the type of simple, non-sarcastic answer I was looking for. I'll try out the high-beams tonight.
03-12-2009, 11:04 AM | #13 | |
652
Rep 4,728
By the way, The Manuel does have all this information. So again. If I can find it, so can you. |
03-12-2009, 11:06 AM | #14 |
652
Rep 4,728
That had me cracked up for a good while.
03-12-2009, 12:34 PM | #15 | |
Rep 2,653
03-12-2009, 12:45 PM | #16 | |
Rep 3,883
Drives: Audi RS Q8
03-12-2009, 12:56 PM | #17 |
Rep 2,653
That's the exact same thing I quoted earlier in the post which, btw, I also found in 30 seconds of searching. It says nothing about the .5 degrees now does it. I just don't know why some guys find it so hard to provide simple answers to simple questions like Hermes and Beto did.
03-12-2009, 12:58 PM | #18 |
Rep 3,883
Drives: Audi RS Q8
Because some questions are stupid. I can't be held responsible for your missing sense of humor. You should have that thing lojacked or something as it's kind of valuable.
03-12-2009, 01:01 PM | #21 |
Rep 3,883
Drives: Audi RS Q8
Of which manual?
Pre-LCI E90/91 with iDrive? Pre-LCI E90/91 without iDrive? LCI E90/91 with iDrive? LCI E90/91 without iDrive? E92/93 with iDrive? E92/93 without iDrive? Oh, hahahaha, ok. |
