E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > 335i coupe taken to track anyone??
      03-11-2009, 09:35 PM   #1
ac328
ac328's Avatar
145
Drives: 328is, 528e, 335i, X3 M40i
2018 BMW X3 M40i  [10.00]
Hi I am thinking of taking my 08 335i coupe to ThunderHill, but I seeing that lots of people are getting issues. Has anyone else encountered issues while at the track?
AC328
2018 AW G01 X3 M40i
2008 AW E92 335i Coupe
2006 SG E85 Z4 3.0si
1996 AW E36 328is (original owner) 1986 DG E28 528e
      03-11-2009, 09:40 PM   #2
josephr25
Drives: 2008 E92 335i
I drove hella shitty (I am used to go karts, not tracking a car) but my car came out fine. There are a lot of others w/ more experience that track their 335i's around here though.
The only problem I had is my M-sport knob came off when I went into 2nd (Buttonwillow).
      03-11-2009, 09:45 PM   #3
ac328
ac328's Avatar
145
Thanks for your input, did you see the other posting "down for 8 count". I am wondering if he blew the head gasket due to track time.
Also did you use stock wheels?
AC328
2018 AW G01 X3 M40i
      03-11-2009, 09:55 PM   #4
josephr25
Everything on my car is stock except the M-sport hand brake, M-sport shift knob (again I pulled it off while on a slow corner), and an M-sport steering wheel (which I didn't have at the time).
That said, although I drove like a nub (I only really gunned it on the straights) the extremely cold weather (last December) that weekend probably was really good for the engine.
It seems that S4to335 and Satakal are the ones you'll probably want to talk to as I see that they track their 335i's quite often. But the former seems to have several problems w/ his car; track-related or not I am not sure.
Edit: from what I've read, w/ our cars already having a somewhat fragile HPFP, the oil cooler isn't that great for track use either.
      03-12-2009, 12:16 AM   #5
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Just do it and be smart about it. Watch your gauges and if you get higher temps then back off. Short shifting, smooth braking and good lines will keep your car safe.
I have a stock, besides suspension, 335 and have done a 1:59 at Infineon on street tires. I don't have a special oil cooler, intercooler, BOV, catch can, tune or anything that would make my car more durable than one off the lot.
Be smart and your car will be fine.
Caveat: 335 is very fast and it makes you want more when you pass a Ferrari, Z06, GT3...no matter who you pass, drive to what the car allows you to do.
      03-12-2009, 01:51 AM   #6
ac328
ac328's Avatar
145
Were you on runflats!!
AC328
2018 AW G01 X3 M40i
      03-12-2009, 09:28 AM   #7
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Not on run flats. They will slow you down but if that's what you have then drive to those.
Driving to your equipment's capability is one of the best lessons to learn as you move along in HPDEs. Don't overdrive your car. Also, don't complain about it.
PS. I've done both but maybe I'll grow up some day
      03-12-2009, 01:24 PM   #8
Ramos
Ramos's Avatar
Drives: G20 2020 M340
A 6 MT 335 will do much better oil temp wise then a AT 335 on the track since the oil cooler has to cool the transmition oil as well on the AT ... Nuch more likely to overheat with the AT with a stock oil cooler
I have induced Limp twice at Buttonwillow in August and I am not fast at all compared to Satakal and S4....
If you have an auto, get an after market oil cooler for sure
If you have a manual, you should be okay as long as you watch your temps and short shift a little around 6K RPM when things start getting toasty
Tracks are also different, for example on the ROVAL CA speedway, you shouldn't have much of an issue cuz the long oval portion allows the oil temps to drop a bit with more speed and more air flow...
      03-12-2009, 01:37 PM   #9
satakal
satakal's Avatar
95
Drives: e46
fixed it for you
I have induced Limp twice at Buttonwillow in August and I am not fast at all compared to JBass and S4....
      03-12-2009, 01:50 PM   #10
Ramos
Ramos's Avatar
How modest of you
      03-12-2009, 01:54 PM   #11
satakal
satakal's Avatar
95
Drives: e46
fixed this one too
How factual of you
      03-12-2009, 02:20 PM   #12
leftcoastman
Drives: 335i
Minor correction. The COOLANT RADIATOR has to share some space to cool the ATF.
The standalone oil cooler is just for oil, even in a slushbox.
It's the coolant that will hit the magic 242F number and cut boost, quickly followed by limp-a-zoid.....often even if oil is below the 304F magic number.
      03-12-2009, 03:19 PM   #13
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Satakal. That's really nice of you but we've never ridden together and that's a lot to live up to.
      03-12-2009, 03:35 PM   #14
satakal
satakal's Avatar
95
Drives: e46
You maintained a similar pace to an instructor driven C6 z06. That was a fun ride for me in the vette. I was impressed.
      03-12-2009, 04:42 PM   #15
Ramos
Ramos's Avatar
good to know, thanks for the correction
      03-12-2009, 04:44 PM   #16
Ramos
Ramos's Avatar
Satakal and Jbass up on a tree
Where is the good ol' fashion childish "my car is faster than yours" and
"I will eat u for lunch" fun stuff ??
      03-12-2009, 04:48 PM   #17
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
So a stock engine 335 with coilovers and street tires can keep pace with a C6 Z06..... ?
OP, take the car to the track without changes. you probably won't be be able to drive it hard enough to make it overheat for a while.
      03-12-2009, 04:51 PM   #18
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Funny as hell.
      03-12-2009, 04:58 PM   #19
Ramos
Ramos's Avatar
Agree... But eventually as you get better and faster your mod list should follow the following order:
1. Dedicated rims and tires for the track (street tires)
2. Seat time
3. More seat time
4. Maybe an upgraded oil cooler
5. A lot more seat time
6. Some more seat time
7. Upgraded Brakes
8. upgraded supsension
9. A heck of a lot more seat time
10. R compounds
11. You guesses it .. more seat time
12. More suspension upgrades
13. Finally if you are still alive and have $$ left over, speed mods
14. Dedicated track car
What did I miss?
      03-12-2009, 05:13 PM   #20
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
2. Seat time
3. More seat time
What did I miss?
I edited the list for you.
      03-12-2009, 05:16 PM   #21
Ramos
Ramos's Avatar
Tell me about it, I am dying to get a E36 M3 as a track/project car but in this economy and at my skill level, it's hard to justify the purchase
      03-12-2009, 05:18 PM   #22
Ramos
Ramos's Avatar
But wouldn't modding the dedicated track car follow the list I provided?
e90post
