Crap..looks like I am down for an 8 count guys...
02-26-2009, 11:37 PM | #1 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
The car just did the following:
1) low water warning light went on...(amber) 2) within 6 seconds..low water warning light went on (RED) 3) car went into MAJOR limp mode 4) car seems to be significantly OUT of water...with no visible leaking I am thinking the head gasket just went...I immediately pulled over and shut the car down..but my question is...WHY DIDNT THE WARNING LIGHT DISPLAY UNTIL JUST NOW...if the car was low in water..it should have said so...a long long time ago. And this was after I had an inspection of the car prior to a driving event. So, did the shop not check the water level? Maybe...hard to tell. So, I decided not to tow it to a dealership tonight..I am too tired..I already had a very shitty day...didnt want to compound it by towing down to the dealership some 16 miles away..and then getting home about 10:30 or 11pm. I will have roadside assist tow it to the dealership on Saturday morning...what a TOTAL pain in the ass this car has turned out to be. Decided tonight..I will not be getting another 335 when my lease is up next February. Sorry guys..going back to the Audi camp. Steve-out.
Car is now gone .... :-( |
02-27-2009, 12:18 AM | #2 |
Rep 7,789
yea, i don't blame you on going back to audi, almost EVERY HPFP went out on every 335i out there, AUDI's are still amazing cars, but until i experiance BMW's i will not buy an audi or drive one at least, if bmw's reliability turns out to be as big of a pain as you guys describe it then i guess i have to find the NEW car company to get addicted to
02-27-2009, 12:25 AM | #3 | |
Rep 4,380
I am on my FIFTH HPFP...the starter and fuel filter were replaced...brake pad sensor replaced TWICE...the throw out bearing replaced...wastegate actuators replaced...all six coilpacks..all six spark plugs...all six fuel injectors. And a few others...I am DONE.
02-27-2009, 12:31 AM | #4 |
Rep 3,618
Audi's new supercharged 3.0L V6 looks pretty tempting, it would be nice if they offered it in the A4 by the coming model year in lieu of the present NA 3.2L engine.
For me though this is my first and last BMW, I'm going back to Benz after my lease is up at the end of the year. My 31 year old weekend car doesn't even squeak, creak or rattle as much as my 2 1/2 year old bimmer.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
02-27-2009, 12:40 AM | #5 |
Rep 4,726
Umm, did you not try filling it up first before towing it to the dealer? That would tell you at least if it was the head gasket.
Wouldn't be surprised if it's in your oil though. Where you romping on it at the time?
02-27-2009, 12:56 AM | #6 |
Rep 4,380
I will try filling it now...I couldnt when the engine was hot. I was driving normally when it happened.
02-27-2009, 09:26 AM | #7 |
Rep 64
I'd take your oil cap off and see if you oil looks milky gray. On a normal car I'd take out the oil dipstick and smell the oil, and check the sparkplugs to see if one is alot cleaner than the others (coolant basically steam cleans the plug).
I would also expect a headgasket problem bad enough to use that much coolant would cause an overheating issue but without a real water temp gauge, I guess we just rely on the ECU to throw a warning light...I don't even know how hot the coolant has to get to throw the light. Anyone know? On a less positive note, chronic high water temps (e.g. lots of spirited driving with 230+ water temps) can surely lead to headgasket problems (at least in my experience with E36 M3 track cars) |
02-27-2009, 10:42 AM | #8 | |
Rep 4,380
After towing it home..and letting it rest for 1.5 hours..I opened up the coolant reservoir..added about 48 oz of water..and then started it up. It needed all 48 oz. I just let it idle for about 2-3 minutes..shut it down...checked water/coolant level again...no movement. Then I started up the car again...moved it backward...looked for any coolant/water on the ground..and there was NONE. I then turned off the car, checked water level again..it was at the top still. If something is leaking..I sure dont know where it is leaking. BTW, when I first opened the hood after it went limp..I saw excess water around the black coolant reservoir...not a ton...just some. I dont know how that got there. I didnt spill it there.
02-27-2009, 11:26 AM | #9 |
Rep 64
Ok....now I understand. First post mentions "low water warning" so I was assuming you got a low coolant light rather than high water temp.
Here is a link to a thread where two other folks had similar issues that turned out to be a crack in the coolant reservoir http://www.e90post.com/forums/showthread.php?t=176860 Good luck. |
02-27-2009, 11:47 AM | #10 |
Modder Raider
753
Rep 8,633
Drives: M3
I feel for you man!
It really sucks that you've had so many issues.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
02-27-2009, 04:00 PM | #12 | |
Rep 4,380
Lets be really clear here...the vast majority of my modifications would have nothing to do with a coolant reservoir cracking and removing 48 oz of coolant super quickly.
02-27-2009, 06:00 PM | #13 | |
Modder Raider
753
Rep 8,633
Drives: M3
Hopefully you have a friend on the inside. It sounds like you do since I've seen the work that they've done for you.
02-27-2009, 06:01 PM | #14 | |
Rep 4,380
02-27-2009, 09:35 PM | #15 |
Rep 1,050
Steve, I hope it all works out. I wanna talk to you about this, maybe at the HPDE at Infineon? My lease is up in October and need to start thinking about my next car.
Mine hasn't given me problems like a lot of people have experienced. Half shaft broke becasue BMW Dealer refitted it incorrectly, Waste gate rattle was fixed and hasn't come back. Wheel bearing replaced twice. HPFP replaced under campaign not because it failed. Anyway, I was thinking of keeping it if BMW would let me negotiate the buyout way down. I just don't see any alternatives that embody such a perfect combination of attributes: comfort, style, speed, handling, luxury, value. What else has as much of those qualities? The other option is to buy a "track car" and get a DD. Anyway, I hope it works out for you. PS. NA cars seem like my next purchase. Say hello M3 (as long as I get one ebfore BMW inserts a an FI motor). |
02-28-2009, 12:21 PM | #16 |
Rep 4,080
BMW's have history with cracked coolant reservoirs. I just replaced one on the X5, common problem.
03-01-2009, 09:24 PM | #18 |
Rep 1,664
Goodluck on the repair, hopefully its a simple fix.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
03-01-2009, 09:31 PM | #19 |
Rep 4,380
I dont have downpipes, gutted cats, cold air intakes, piggyback ECUs or the like, I just have catback exhaust..and a Dinan tune..that has only been on the car a few months. I would not call my car significantly modified engine-wise.
03-02-2009, 12:16 AM | #20 |
Rep 6,107
That sucks Steve ... I took my car for inspection not too long ago too and guess what ... they didnt check my coolant level too ... kind of lame I think ...
I hope your car will be alright ... are you going to inf. on march 7/8 ? |
03-02-2009, 07:41 AM | #21 |
Rep 4,380
I didnt sign up for that one...I am signed up for March 9th at Laguna...but will only go if my car gets fixed by then.
