Cheap Solution for high Coolant Temps
02-16-2009, 10:36 AM | #1 |
Rep 4,445
Ran water wetter and 2:1 ratio of distilled water/BMW coolant. Temps never rose pass 207F and hovered around 200F. Oil temps are a different story.
Air intake temps are a problem in the high RPM range.
02-16-2009, 01:18 PM | #5 | |
Rep 4,445
Air intake temps would not drop off no matter how the car was driven (110+mph straights), so this may be the power limiting factor. Granted this occurred during 45-50 minute sessions chasing a Carrera S. FYI those NT-01s (255 all around) with some alignment tweaks transform the car's turn in. Great tires. Yep, which is why the power loss is due to something else ---like air intake temps.
02-16-2009, 06:31 PM | #6 |
Rep 4,726
Oh I thought you were LOOKING for a cheap solution and you were thinking that had not worked.
I'll try and remember to bring the computers next event and see what's up. But I'm guessing you're losing timing or boost and the question is why?
02-16-2009, 07:42 PM | #7 |
Rep 4,445
Sounds good.
03-03-2009, 10:55 PM | #8 |
Rep 502
I see you were running a 2:1 ratio of distilled water/BMW coolant, but how many ounces (or how many bottles) of water wetter did you put in?
"WorldsQuickest 335i E93"
SMART-Top /One-Off Opaque Vinyl EYELIDS / 30% TINT / A.C.SCHNITZER Pedals / "M" Tri-Color Wheel w/Paddles / EIBACH Pro-Kit / AKEBONA F. & EBC RED-STUFF R.Dustless Pads / Drilled & Slotted ROTORS / MIRO M6 Reps / MICHELIN PS2's / U.R.Coated DP's / CYBA-QUAD Exhaust Tips / BMS-TUNED... |
03-24-2009, 05:56 PM | #9 |
Whats that smell?
145
Rep 1,790
I'll be the first to admit that I am a complete water wetter noob. Im a little confused, what was the exact amount of each? So you sucked out what was in the tank and left what else was in the system (or was it complete evacuated) then added back the water and the water wetter?
03-24-2009, 07:53 PM | #10 | ||
Rep 4,445
Install the cap on the reservoir. Turn on the ignition, set the heat to maximum and the blower on the lowest setting. Begin by pressing the accelerator pedal to the floor for at least 10 seconds; be sure NOT to start the engine. Release the accelerator pedal and within a moment, the pump can be heard during activation. While the bleed procedure is being performed, inspect for leaks. The procedure can be repeated several times as needed, turning off the ignition off for 5 minutes between each bleed procedure.
03-24-2009, 09:21 PM | #11 |
Riding the knock sensor
2366
Rep 1,586
Drives: 21 X5MC | 23 M4CSL
On track what octane do you run? Also, do you drive with the heater on full? I might do a session in the 335i this Friday and want to be prepared. I have waterwetter in it but I know it's not effective when used with coolant. Basically want to take some BT logs at different boost settings (JB3 maps) running 100 oct. If it behaves in the first session I might drive it more.
03-25-2009, 10:25 AM | #12 | |
Rep 4,445
03-25-2009, 11:47 AM | #13 |
Whats that smell?
145
Rep 1,790
Bubbles, check your PM's
Im still lost as to what you said about evacuating it. If you just suck out the resevoir that leaves everything else in the system. I'm assuming there's a drain somewhere on the radiator and you let it out there as well? Last edited by M3to335; 03-25-2009 at 12:07 PM.. |
03-25-2009, 12:33 PM | #14 |
Rep 1,714
A couple more notes for you guys:
1) I have tried to add WW to the existing coolant mix and recorded zero change in temps on track. WW isn't supposed to change bulk temps anyways, only localized temps. 2) Yes, you can drain the coolant. The plug is under the IC, so you have to remove that first. |
03-25-2009, 01:56 PM | #15 | |
Whats that smell?
145
Rep 1,790
03-25-2009, 02:23 PM | #16 | ||
Rep 4,445
03-25-2009, 04:51 PM | #17 | |
Whats that smell?
145
Rep 1,790
I just looked and there's no way to run the tube any deeper than the bottom of the reservoir tank. There are 2 tight bends in the pipe immediately under the tank. So unless it pulls a vacuum on the system, pulling everything against gravity, the entire radiator and lines are still full of coolant. Would you agree?
Or does that pump actually create a vacuum and pull some out of the system as well? I should be able to grab one of those evacuator pumps from work. Quote:
03-25-2009, 05:59 PM | #20 |
Rep 1,714
No, let's make for simple math and assume the whole system is 2 gallons and he sucked out half the stock coolant mix. (system is actually 2.25 gallons, but math gets harder)
So stock coolant mix is 50/50 (I think). Bottle of WW is 12 oz, roughly 10% of a gallon. He then sucks out a gallon of that stock mix and replaces it with a 70% water / 20% coolant / 10% WW Bubbles-Special-Dinan-is-my-hero-despite-making-me-limp mix. That gives him a final 60% water / 35% coolant / 5% WW mix. If I was doing it, I'd suck the gallon of stock mix out, add the WW and top it off with distilled water. My LCM-Voodoo-Dinan-Killer-Mix would give you 70% water / 25% coolant / 5% WW. So not only would I devour the Dinan guy on the straights, I would also go longer before going limp! |
03-25-2009, 07:24 PM | #21 | |
Whats that smell?
145
Rep 1,790
+1, thats what Im going to do. Replace everything sucked out with WW and Distilled H20. Id like to replace EVERYTHING with distilled H20 and WW but honestly Im not patient enough to pull the IC out to get to the fricken drain plug. That's rediculous if you ask me.
03-25-2009, 08:55 PM | #22 | ||
Rep 4,445
I was concerned with pulling too much fluid out at once and causing the pump to seize. So I erred on the side of caution. When I had the turbos replaced, I'm convinced the tech refilled the I/C with nearly straight coolant. So I suppose diluting with straight distill water won't hurt if your live in a mild climate. Quote:
