Car shakes while turning on(cold)
02-10-2009, 02:48 PM | #1 |
Rep 3,668
hey there folks if i go to turn my car on in the mornings, it idles so rough i actually have to sit and wait for about 2-3 minute until it goes away. ever since this has been happening it takes forever for my oil temp to get hotter...what gives?
Has this happened to anyone? |
02-10-2009, 02:50 PM | #2 | |
former N54 owner
11
Rep 607
+lemon
02-10-2009, 03:00 PM | #3 |
Rep 3,668
i dont get long cracks at all just really rough idle when i say rough idle i dont mean the rpms are jumping up and down...more like at idle it shakes like a mofo!
02-10-2009, 05:05 PM | #5 |
LA Native
14
Rep 294
lots of posts regarding this, its not always the HPFP. Fuel Pump issues are almost always characterized with long cranks at startup. I have the same issue as the OP and no issues with startup, it's from a cold start and the long shaky revs. My car was in for a week and all they came up with was to replace the injectors. Today I started the car and got the same issue throwing the car into limp mode. Turned the car off and then back on and no limp mode. My best guess at this point is the o2 sensors. Can I get the SA and Service Tech to buy off on this? That remains to be seen.
02-25-2009, 09:28 AM | #12 |
Close to bein Bannned
106
Rep 5,068
I just had my HPFP replaced an my car is doing the same thing, doesnt matter if its cold or warm the car vibrates when its idled.
The RPMs dont move, but i can feel a "thumping" under the drivers side seat, and in the shifter.. Never did this before.. |
02-25-2009, 12:19 PM | #13 |
Rep 177
I started noticing the same thing about a week ago. The car still starts up normally, in a timely manner, but while I'm letting the car idle it just seems to be a little jerky. I can actually feel the car shudder a little bit... hopefully it's nothing major.
02-25-2009, 07:31 PM | #14 |
106
Rep 5,068
UPDATE:
I hooked up the BT tool and came up with this, apparently not all is fixed. Cylinder 4 is misfiring... 29D0: 29D0 Misfirings, cylinder 4 Error will cause a warning light Error is currently present Test conditions have been completed Signal or value below threshold Event 1 Odometer 22760kms 14142miles Engine temperature 105.00 °C load value for misfire detection 18.36 % Engine speed 640.00 rpm Lambda integrator group 2 -3.13 % Event 2 Odometer 22784kms 14157miles Engine temperature 99.75 °C load value for misfire detection 14.06 % Engine speed 768.00 rpm Lambda integrator group 2 3.91 % Event 3 Odometer 23024kms 14306miles Engine temperature 98.25 °C load value for misfire detection 20.31 % Engine speed 672.00 rpm Lambda integrator group 2 1.56 % IMO everyone needs to get a BT tool! |
02-25-2009, 07:38 PM | #15 | |
SPRCHRGD E93 M3
12
Rep 271
E93 M3
Modded to perfection. |
02-25-2009, 08:06 PM | #16 |
106
Rep 5,068
I only get a light when i start the car without turning on the engine.
An exclamation point is on the dashboard. Other than that there are no lights anywhere else. |
03-19-2009, 03:12 PM | #18 | |
Rep 1,086
This seems to all have started when I saw a warning light for low engine oil. The warning just appeared on Sunday on my way home from the beach. It wasn't a moderately low (yellow light), it was a re-fill immediately warning which seemed awefully sudden. I went to the dealership first thing Monday morning and explained the situation. They re-filled the oil and I thought the problem would go away...not the case. For the last 4 mornings in a row, I've had to start the car, get limp mode, turn it off, then re-start for the issue to go away Anyone else having a similar problem? Any opinions or suggestions short of going back to the dealer? |
03-19-2009, 03:17 PM | #19 |
Rep 688
My SA said that this problem was because of the valve lifters forming air pockets under the valve, which then go away once the engine is warm. He said BMWNA put out a notice to all the dealers, but can't do anything about the issue. Could this be the same thing?
03-19-2009, 03:21 PM | #20 |
Rep 1,086
I suppose this could be the case, but I essentially know nothing about engine mechanics. If the car can warm-up enough in the 10 seconds between the cold start/limp mode and the second start, then maybe this is the issue?
03-19-2009, 03:23 PM | #21 |
Rep 688
I don't know. I have an appointment with service next Friday for mine. It's making a noise like a spinning top if I accelerate when it's cold. Totally goes away once it's warm.
