      02-07-2009, 11:27 PM   #1
italiantank26
Drives: BMW 128i
2008 BMW 128i  [0.00]
debadging - how to remove glue residue?
I'm thinking about debadging my car tomarow, did some research on this site, and figured that the best way was to use a hair drier, and some dental floss, the only problem is i don't have any goo gone to remove the adhesive glue, does anyone know anything else i can use to remove the glue?
      02-07-2009, 11:40 PM   #2
BSM 135i
BSM 135i's Avatar
Drives: 08' BSM E82
when I put on my shadow emblems there wasn't THAT much risidual adhesive left, your finger nail and some soap and water will probably do the trick. But goo gone isn't that expensive and at least you'll have it on hand if you ever need it
      02-08-2009, 12:16 AM   #3
FOXYCaymanS
_
FOXYCaymanS's Avatar
Drives: Cayman S / Rover
3M adhesive remover also works, it's much cleaner than googone which can leave a greasy feel. BE SURE TO NOT OVERHEAT THE BADGE!!! I'd also wax the area after you debadge. Just a little fyi.
      02-08-2009, 12:49 AM   #4
M3_Dust
Michelin Man
M3_Dust's Avatar
Drives: F10 535i M Sport
I used rubbing alcohol and cotton balls and some cleaner wax after that.
      02-08-2009, 12:55 AM   #5
Chicago1
Drives:
A little 3M rubbing compound on a hand-towel will get all the residue off with about 10 seconds of brisk rubbing.
SGM 135i - M-Sport - Cld Wthr - Blk 'Ette - iPod - HiFi - Grey Poplar - Riss Racing Intake - cp-e Exhaust - DINAN Stage II
      02-08-2009, 01:00 AM   #6
Mega Man
エアーマンが倒せない
Mega Man's Avatar
Drives: 2009 135i
2009 135i  [0.00]
Are there alignment holes that need plugged after the removal?
      02-08-2009, 01:06 AM   #7
Chicago1
Drives:
Nope... they are just held on with basic 2-sided foam tape. Takes 5 minutes, max.
      02-08-2009, 01:56 AM   #8
KeithLM
Proud 1er
KeithLM's Avatar
Drives: Crimson/Coral 135i
I took off the 135i today and put on black ones. It was not real warm and there was no sun, so it was a bit of work. I didn't apply heat because I was using masking tape to mark where the original numbers were and I didn't want to risk messing that up, so it was a real pain getting the adhesive off. Goo-gone didn't do much for me, and so I resorted to some carefully applied WD-40. But I bet heat would have made a difference.
      02-08-2009, 02:47 AM   #9
driftdriven
Drives: BMW 135i
where did you purchase the black emblem?
      02-08-2009, 05:40 AM   #10
bman6074
Drives: 14 M235i and 07 Lotus Exige S
Best thing to use is more tape. Yes i said tape. Packaging tape is best. Just stick the tape to the residue and rub with your fingers to heat it a bit then slowly peel off. once you have the heavy part off, dab at the residue with the packaging tape pulling striaght back (don't peel) in a quick motion. It takes a bit but works everytime. Always use a fresh area on the tape to get best removal of residue.
      02-08-2009, 07:12 AM   #11
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
WD42 and dental floss
      02-08-2009, 09:01 AM   #12
1HungryMan
Drives: 2008 128i
I'm missing something: why do people remove the badge? Anti-status? Aesthetics?
      02-08-2009, 09:38 AM   #13
italiantank26
Drives: BMW 128i
Thanks for all the information guys looking foward to doing this today, hope i don't mess anything up, im going to use a hair drier since its RI weather and we have no sun out, some dental floss, and gonna try a few methods to remove the glue, using some tape and some WD42 soap water and some wax
      02-08-2009, 09:54 AM   #14
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
Just use "Tarminator" spray. It's meant for road tar and bugs but it's safe on painted surfaces. I used that when I debaged my STI. Worked beautifully and cleaned the surface as well.
      02-08-2009, 10:08 AM   #15
BlackjackMulligan
Most interesting Roadster
Drives: '01 Z3.0 Roady;'10 C300 Sport
I'm taking mine off for the nice clean look it provides. The only badge you'll see on the back of mine is the BMW roundel.
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh
      02-08-2009, 10:09 AM   #16
m7ammed
m7ammed's Avatar
Saudi Arabia
210
Drives: 2019 M2 Competition
any pics of debadged cars?
      02-08-2009, 10:37 AM   #17
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Aesthetics mostly. I think it looks much cleaner without a tag on one side of the back. I debadged my last 3 series (it was much more popular to do it back then) and I think I'll debadge my 135i. If I eventually do get an M3, I'll debadge that as well!
      02-08-2009, 10:39 AM   #18
M3_Dust
Michelin Man
M3_Dust's Avatar
      02-08-2009, 11:02 AM   #19
italiantank26
Drives: BMW 128i
Just debadge my car, worked out pretty well, had some trouble removing the glue residue, i used my finger nails, and a sponge, wasn't thinking, and it was definetly not a good idea, dont know why i did that. But after i use some soap wax, and WD40 to finish off it came out good, but i probably need to buy some goo gone to finish it off later.
      02-08-2009, 11:21 AM   #20
jeremyc74
Drives: '08 135i Montego/Terra
Mine:
      02-08-2009, 12:56 PM   #21
KeithLM
Proud 1er
KeithLM's Avatar
bimmian.com Check out the cosmetic forum and you should be able to find some threads on it with pics. The black matches the shadowline trim.
      02-08-2009, 01:59 PM   #22
Robert
Drives: 135i -> is350 -> Tesla M3 perf
3M General Purpose Adhesive Remover is what I used to removed residue.
1addicts
