e93 jerks forward when letting off brakes
02-07-2009, 06:49 PM | #1 |
Rep 247
My 335 e93 will jerk forward when I let off the brakes from a stop. I'll be sitting at the light and when I let off the brakes slowly it feels like they suddenly just let go and the car jerks forward. I have an auto transmission. The thing is it will go away when the car warms up. Anyone else seen or heard of this problem? What was done to remedy it?
02-07-2009, 06:55 PM | #2 |
Rep 7,433
Every E90 has it. It's called brake assist for holding the car on a hill when you take the brakes off, it will hold for a couple of seconds so you can start accelerating.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
02-07-2009, 07:06 PM | #3 |
I'm kind of a bitch
375
Rep 895
I just had to get used to mine and be slower with it. It was hard for me to not scratch my car when backing out of the driveway. I'm getting better now, but at first it would take me 5 minutes just to back out!
E93: Montego/Cream <---- E46 (Coupe): JB/Black <---- E30 (Cabrio): Alpine White/Black
02-07-2009, 07:09 PM | #4 |
Rep 288
02-07-2009, 07:13 PM | #5 |
Rep 7,433
Actually, they do have it.
-Brian
02-07-2009, 07:24 PM | #6 |
Rep 211
02-07-2009, 07:25 PM | #7 |
Rep 949
Welcome - After you adjust your driving to the brakes in the car, it will rarely happen
2008 e92 335i Step | Is Gone - It was fun but not meant to be | M3 - Cancelled | 135 Ordered
02-08-2009, 12:25 AM | #8 | |
Rep 247
This is not brake assist.....my problem happens when the car is cold and goes away after about 10 minutes of driving. WHEN I'M AT A STOP ON FLAT GROUND, I slowly let my foot off the brake. The car will suddenly jerk forward and start rolling practically giving me whiplash. Feels as if someone is giving me a fender bender from behind everytime I let off the brakes. I cant even get the car to slowly ease forward (as is needed in parrallel parking) by letting off the brakes as slowly as I can. Everytime I let go of the brake even slowly the car JUMPS forward. When the car is warm it wont do it. I can easily let my foot off the brakes slowly and the car will start rolling forward while RIDING the brakes. |
02-08-2009, 12:57 AM | #9 | |
Scrumtralecent
Rep 97
On page #4 post #77 a member found a potential solution to it, i will be bringing in my car soon hopefully to have it looked at. I still contend that the symtoms that we are describing are in no way, shape or form a "feature" or "normal" as some have suggested. |
02-08-2009, 03:45 AM | #10 | |
Rep 1,231
One way to tell whether this is fuel supply or gearbox related would be to warm the car up without driving it then see if the problem is still there. If it persists for the usual time after the engine is warm, its transmission. If warming the engine means the problem is gone as soon as you drive, its related to the fuel injection set up. |
02-08-2009, 04:59 AM | #11 |
Rep 10,509
this 'feature' you are talking about is called 'low end torque' and it is not exclusive to german cars. You are making it sound like a manual transmission E90 will not stall if you don't apply throttle when engaging the clutch from a stop, and this is simply not true
02-08-2009, 07:02 AM | #12 | |
Rep 1,231
Obviously the relationship of engine revs to wheel rotation is fixed, depending on the gear ratio you've selected but as long as your car is not mechanically forced to fall below the engine's idle speed, it will continue to move forward with no gas applied and will not stall. In Germany, autobahns are hilly and crowded are drivers are often required to creep forward for extended periods. Before moving to Germany I was used to having to apply gas if I wanted to avoid stalling. This was not neccessary on any car I drove in Germany, including some low torque rentals. In AT, you have to put your foot on the brake to prevent the car moving forward, but similarly, if you take your foot off the brake the car will begin to move forward smoothly and will maintain something like walking speed with engine revs at idle. |
02-08-2009, 08:37 AM | #14 |
Investor Relations
60
Rep 221
I had this fixed on my 335i.
Here's the TSB: I B 24 03 08 Automatic Transmission July 2008 Technical Service This Service Information bulletin supersedes SI B24 03 08 dated June 2008. designates changes to this revision SUBJECT 335i, 535i with N54 and 6HP19TU - Jolt and Delay when Pulling Away MODEL E90, E92, E93 (335i) with N54 and 6HP19TU from 12/06 up to 09/07 E60, E61 (535i) with N54 and 6HP19TU from 03/07 up to 03/08 SITUATION The customer may complain of a delayed engagement and a harsh jolt when accelerating from a stop. The situation occurs only during the engine warm-up phase (cold engine), and can not be reproduced in the Sport Mode. CAUSE EGS software (unfavorable NIC – Neutral Idle Control calibration) SOLUTION On a customer complaint basis only, check the vehicle's integration level. If the integration level is: * On E9x vehicles – E89X-07-06-520 or lower * On E6x vehicles - E060-07-09-530 or lower Reprogram and recode the complete vehicle with a current Progman version (target levels are E89X-07-09-518 or E060-08-03-510, respectively, for E9x and E6x vehicles). WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty.
'18 M3 ZCP | '13 RX 450h | '11 Range Rover Sport | '08 335i | '06 IS250 | '02 330 Dinan 3
02-08-2009, 02:29 PM | #15 |
Rep 288
02-08-2009, 02:32 PM | #16 | |
Rep 247
02-08-2009, 02:59 PM | #17 | |
Rep 201
02-08-2009, 03:02 PM | #18 | |
Rep 732
02-09-2009, 02:46 AM | #19 | |
Rep 1,231
http://www.topbuzz.co.uk/info/iscv/iscv.htm Live and learn! |
02-09-2009, 05:51 AM | #20 |
Rep 1,231
Idle speed via ECU
More sophisticated units ala BMW are controlled by the ECU in conjunction with several sensors. The following provides useful background
http://www.autoshop101.com/forms/h26.pdf You can imagine that a malfunction or inappropriate operation of this unit could very well cause the symptoms described above |
02-09-2009, 12:22 PM | #21 |
Rep 898
Drives: F90 M5
RyanDe680 has it right. It's the NIC calibration and its supposed to be solved by a software update. However, the bulletin that he posted has now been superceeded:
http://www.bmwtis.com/tsb/bulletins/...p/B240308g.htm "The NIC (Neutral Idle Control) feature disengages the torque converter from the transmission when the vehicle is stationary in the Drive position; the service brakes are applied; and the engine is still in the warm-up phase. The NIC function eliminates engine load when vehicle is stopped, reducing fuel consumption." The first bulletin upgraded the Progman to a newer version, which improved the problem slightly but was still there. Apparently the latest software version with the "Converter lockup clutch" retrofit fully fixes the issue, but my dealer won't do it for me because they "can't reproduce the problem", which drives me mad because yesterday I was pulled over by the police saying that my car was rolling back and then pulled away sharply - this is what the transmission does if I am on a hill when the engine is cold, the car rolls back, I overcompensate by adding more throttle and then the gear kicks in and it jolts away.
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
02-09-2009, 12:38 PM | #22 |
Rep 279
I had the same issue for the first couple thousand miles (11/07 build). I wasn't able to replicate it whenever I brought my car in. Hasn't happened since about 3k miles - I'm going on 12k now.
Current:
2007 Subaru WRX STi 2007 Triumph Speed Triple |
