Staggered or Non-Staggered?
02-05-2009, 12:08 PM | #1 |
Rep 83
I run about a dozen track days a year and am going to a dedicated wheel/tire set up. I have been running Toyo R888's (255/35/118 on the rears and 235/40/18 on the fronts) on stock wheels. I have the Dinan Stage 3 suspension set-up (upgraded shocks, springs, struts and camber plates) and run with the traction control off. Going to a non-staggered set-up will help make the car more neutral, but I will have to give up some treadwidth on the rears. Is it worth the loss treadwidth in the rear or should I just adjust tire pressure and keep the staggered set up?
02-05-2009, 01:38 PM | #3 |
Rep 83
Have you run that set-up without any problems? What tire did you use? I want to check the dimensions against the tires I'm considering since there are varitions amoung 255's especially with race type tires such as Hoosiers which run wider because of the straighter sidewall. Thanks.
02-05-2009, 01:47 PM | #5 |
Rep 83
02-05-2009, 03:21 PM | #6 | |
Rep 1,050
SUGGESTED SETUP: 255 Dunlop Direzzas on LTW 17" x 9". Use 10mm spacer in front and 5mm spacer in back. Best handling upgrade for first mod, even if you use the Falkens. I think the Koseis are available in 8.5" which won't support the 9" Dunlops as well. Many threads on Falkens and Dunlops. Search for information. |
02-05-2009, 03:59 PM | #9 |
Rep 1,476
4 door. I don't know of a difference. I *think* I have seen my wheels on a coupe with no issues.
the guys in the other subforum are right with the idea that the front is the limiting factor. But, like I said, 255 are without-issue upfront. http://flickr.com/photos/9070201@N03...7613323193133/ |
02-05-2009, 04:15 PM | #12 |
Rep 83
02-05-2009, 05:33 PM | #15 | |
Rep 1,476
Over my head dude. Watch... here comes LeftCoastMan to say:
02-05-2009, 05:44 PM | #16 |
Rep 10,509
I've read somewhere on this forum that 2doors have less front fender clearance than 4 doors. Not sure if this is true.
I've used Falkens a lot as well, and I don't really notice a difference between RT615 and the stock sport package tires in terms of heat resistance, turn in or grip. I personally would not bother with the cost or trouble to go to a square RT615 setup and continue to use the stock stuff until it was time to go to an R tire But seems like everyone hates the stock tires so.. YMMV |
02-05-2009, 06:04 PM | #17 |
Rep 1,476
I thought the numbers were really close. Koseis + cheap tires is about the same cost as 4 runflats. I'm about to finish off my 2nd, and get started on my 3rd set of $130 tires. $130 v $300 times 4 is a big deal. Especially when you remember that a tire is a "wear component".
I personally like the performance of the runflats. It was very good to me. |
02-05-2009, 06:24 PM | #18 | |
Rep 133
More grip in the back means accelerate earlier and harder, but without LSD, it's just gonna spin the inside wheel anyways. Is that correct? Anyways, I use Kosei K1s with 245 width Hoosiers. Worked without problem. I have stock setup E90.
*Ultimate* mod for the car: a better driver...
02-05-2009, 06:32 PM | #19 |
Rep 133
Satakai:
You really need to try those star specs if you are gonna stay with street tires. We did a back to back test on those two tires, using the same car. Dunlop averaged more than 1 sec faster, and comparing fastest lap times, Dunlop is a whopping 2 seconds faster.
02-05-2009, 08:25 PM | #20 | |
Rep 10,509
02-05-2009, 10:46 PM | #21 | |
Rep 1,714
Your body roll and weight transfer has to be obscene! |
02-05-2009, 11:39 PM | #22 | |
Rep 133
Anyways...I'll probably switch to RA-1s or R888s later, or upgrade suspension, or maybe even getting a dedicated track car, haven't made up my mind yet.
