Is my car overheating?
02-01-2009, 04:04 PM | #1 |
Rep 1,451
I have a 335, and the engine oil temperature on the gauge cluster is passed the middle, probably by a little less than a quarter of an inch, so roughly 240 degrees fahrenheit. For all you other 335 owners, does your car usually run at this temperature?
Thanks, |
02-01-2009, 04:07 PM | #2 |
Rep 140
Drives: Black Sapphire '07 335i Coupe
yeah, should be normal, that is what mine runs at as well.
02-01-2009, 04:10 PM | #4 |
Rep 1,451
Thanks homie...
This is actually my first Turbo car and my first BMW. So I wasn't sure what the temperature should be. I've driven N/A cars my whole life. My last car was an 06 Lexus GS, and the temperature never passed the middle mark. |
02-01-2009, 04:10 PM | #5 |
Rep 1,451
02-01-2009, 07:26 PM | #6 |
Rep 536
do you have a lot of hills or stop and go traffic? the only time mine gets to 250 is if i am in low gears for a long time. if you are just driving on a regular highway in high gears and it is actually passed 250 you may have a problem.
02-01-2009, 07:33 PM | #7 |
Rep 2,090
the 07 models have 210 as the middle for oil temp
08 and up i believe have 250 middle i have the 07 and when i drive normally its usually around 210-220 and sometimes 230 yours is fine.
02-01-2009, 07:49 PM | #8 |
Rep 1,779
Mine stays around 220 when driving very easy.
It gets around 240 when I start to speed it up a bit. When I am really on it and pushing it hard, it almost gets to 250. When it gets to exactly 250, I stop pushing it, but this has only happened once.
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
02-01-2009, 08:23 PM | #9 | |
Rep 1,451
Thanks for all the help guys... I was getting a little paranoid. |
02-01-2009, 10:06 PM | #10 | |
Rep 591
in the winter, my car usually gets to 220-230..... in the summer, 240 all the tme, and sometimes slightly over if i push it for a while..... also, note that most temp gauges on other cars are thermostats, whereas on your bmw it's an oil temp gauge, which is different..... |
02-01-2009, 11:04 PM | #11 |
Rep 3,883
Drives: Audi RS Q8
Yup, normal, keep mashin.
02-01-2009, 11:44 PM | #12 |
Rep 1,451
Good stuff guys... I just drove it for about 50 straight miles and it stayed around 220ish on the highway, in about 30 degree weather and around 230ish on local driving.
02-03-2009, 07:57 AM | #14 |
Rep 812
The change in the oil temp gage (to 250 in the center) occurred with March 2007 production.
02-03-2009, 09:44 AM | #15 |
Rep 1,232
