Forge DV Maintenance
02-01-2009, 01:39 AM | #1 |
Rep 1,993
Hi All,
I removed my Forge DV's before I had my HPFP replaced and some vanos issues rectified as well. When I removed them I gave them a good clean as they had a little blow by oil inside. Anyway am re-installing these this week and am wondering if I should lubricate them at all before I do the install. Thanks in advance, S |
02-01-2009, 02:12 AM | #2 |
Rep 1,654
Drives: AW M3
sorry to be off topic but can you go into detail about the VANOS issues you had? VANOS seems to be the 2009 HPFP
02-01-2009, 02:33 AM | #3 |
Rep 1,993
02-01-2009, 03:00 AM | #4 |
Rep 1,654
Drives: AW M3
sounds like my problem
did you see the actual fault you had or did the techs just do the work? remember what the fault said? (sorry to go off topic) |
02-01-2009, 04:12 AM | #5 | |
Rep 1,230
Pull the DV apart and smear the lube sparingly and thinly using your finger over all the moving parts. Reassemble and reinstall your chosen spring. It's a good idea to service your DV's like this every 12 months or better still, at every oil change. |
02-01-2009, 05:45 AM | #6 |
Rep 1,575
I'm sorry for the offtopic again but whats the side-effects of such problem?
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
02-01-2009, 02:40 PM | #7 | |
Rep 1,993
At the track it limped 5+ times so took it to the dealer the next week and they replaced one of the solenoids. Said if the problem came back then it would most likely be an issue with the camshafts. Limp mode, typically for me it was at the 2nd to 3rd shift @ WOT. |
02-01-2009, 02:42 PM | #8 | |
Rep 1,993
02-01-2009, 03:36 PM | #9 |
Rep 1,575
maintenance for the DVs? I didnt know that...sounds like trouble.If I knew I wouldn't have bought them
02-01-2009, 03:58 PM | #10 | |
Rep 3,004
I am getting my car back from this EXACT same problem...First they replaced my VANOS solenoid...then it was cam shaft ledge, this time they replaced ALL VANOS solenoids, Crank Angle Sensor and the actual Camshaft! I am hoping my random LIMP modes go away! Fingers crossed. The Visible Errors I got were around "CAM SHAFT RETARD" error.. OBDII Apparently there were several "hidden" codes, which were not disclosed by the dealer And to the OP: I had Bailey DV valves on my B5 S4 and I used Mobile 1 Synthetic lube (red color) on the internals... |
02-01-2009, 03:59 PM | #11 |
Rep 7,377
actually thats why i just cancel my order on the Forge DVs.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
02-02-2009, 02:42 AM | #12 | |
Rep 1,230
Like I stated previously apply/smear a very, very thin layer (less is more) so that it is barely visible on the moving piston assembly. Once assembled press on the piston to open and close it a couple of times to make sure it's working smoothly. Then using a cloth, clean of any excess when looking into the valves opening. The reason for using High temp grease is so it stays in place in the DV at all temperatures and not travel into the intake manifold. Having no proper lubricant in the DV's will eventually cause the piston to stick and make the engine run erractically.............so proper lubrication is essential and to that affect, High Temp Grease is on the money. This may help you in the maintenance of the valve and show you how to check it for proper operation and test to see if any leaks are present: Last edited by Sparky66; 02-02-2009 at 03:37 AM.. |
02-02-2009, 03:32 AM | #13 | |
Rep 1,230
This is no harder than cleaning an airfilter or changing the oil in your car. Now heres the part that may interest you: Truth is, most people will never have to open them up at all, as they are quite reliable if left alone but some people like Wopalx who cleaned them out, will have to relube them to restore the original High Temp Grease. The original factory OEM valves were made to run 8psi boost. Once you add in a Tune, race gas, DP's, Dual Cone Air Filters FMIC etc. that increases the boost to 15+ psi, the original DV's may not hold Boost properly at peak load........and for reliability and consistancy of boost spooling and quick boost pressure relief, the Forge DV is the right solution for a engine that makes more power than factory standard. Then again, if you think they are unnecessary because they are working for now, it's all good ....................but once you notice that the car starts showing signs of sporadic turbo lag or reduced power between shifts whilst under load at the expected higher boost targets or you notice boost spikes as a result of the valve not opening properly when lifting off the throttle. ..............it might be time to seek a more robust solution like the Forge DV's. These DV's should not be considered as a performance enhancing product but more like a performance reliability product as you discover more HP/TQ increases. Last edited by Sparky66; 02-02-2009 at 04:00 AM.. |
02-02-2009, 02:59 PM | #14 | |
Rep 1,993
