e90 with iphone question!
01-31-2009, 12:54 PM | #1 |
Rep 437
I bought on iphone and tring to connect this to the car through the usb jack which comes with the product
but it doesn't work with my e90 335i Do i need seperate jack for connection to my car? I do have ipod option from bmw factory give me help! |
01-31-2009, 01:35 PM | #2 |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
You do need to use the cable that came with 6FL and plug in through the accessory jack. I don't have an IPOD (I use an USB flash drive) put others here could give you more info.
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
02-01-2009, 12:22 PM | #5 |
Rep 29
I have the iphone and the ipod/USB adaptor.....it won't work properly if you try to use the usb cable that came with the iphone. You have to use the Y connector that should have come with your car. It has the end that connects to the iphone.....then the Y connector.....one end goes to the aux input jack and the other plugs into the usb port in the car. You will be able to access all your music through your car radio and the iphone will charge, as well. I got the ipod/USB adaptor and my car came with the connector. If you didn't get one, you can probably order one from your dealership...I'm sure it can't be that much.
