12-17-2008, 05:16 PM | #1 |
Rep 86
The Pipe Dream exhaust mod
Here is a mod whose main virtue is its low cost.
It would be interesting to view the internal structure of the muffler to see where passageways between chambers could be opened up and/or shaped pieces introduced to channel the flow. If the goal is to reduce backpresure without rigid sound level constraints, most likely a hobbiest could handle it. There are plenty of stock mufflers out there now with little demand for them. Someone could cut the seam on a few and experiment with the internals until the right combination of mods is found. This would be preferable to making external changes and could turn into a nice little sideline for someone. |
12-19-2008, 09:53 AM | #3 |
Rep 1,609
Why don't you simply replace the muffler with a straight pipe which is more elegant.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
12-19-2008, 09:59 AM | #4 |
Rep 1,101
If that is the result you want just cut out the stock muffler and use a straight pipe in its place. You could also use a Magna flow canister in the place of the stock one. Either of those would look preety cheap but it would get what you want. I figure the stock is a better way to go.
12-19-2008, 05:23 PM | #6 |
drk one
38
Rep 797
Drives: 2008 135i
kinda cool, but i would just cut out the muffler
Jet Black | Coral | HighGlossBlack | Steptronic | Premium | Sport | Comfort | ActiveSteering | Navi | HiFi | HD | iPod | SAT
BMS JB3 v2.0 | BMS DCI | Berk Tech Sport Exhaust | UR * DPs | CoolingMist Meth Kit w/ CMGS | H&R OE Sport Springs | Breyton GTS-R | Dunlop Direzza Sport Z1 Star Specs | GP Thunder 8000K Low Beams/Angel Eyes/Cornering Lights | LED Interior Light Kit | Window Tint | Smoked Tail Lights | Smoked License Plate Cover |
12-19-2008, 11:27 PM | #7 |
Rep 86
Yeah, I certainly wouldn't do this to my own car. The proposed mod was more tongue-in-cheek than serious. Not every idea is a good one, but it is important to throw them out there. Someone may find a seed to build on.
