11-18-2008, 10:31 AM | #1 |
Rep 34
Increase front camber by filing holes.
Is it convenient to file holes on front suspension top after have removed stock pins?
I removed pins, I put the camber at maximum available but I reached only half degree of negative camber. I think that if I file the holes I can reach more camber. Someone did it? How much camber can I reach? Are there some problems such as corrosion or so on….? Thanks |
11-18-2008, 03:26 PM | #3 | |
Rep 863
Our holes are slotted. You'd have to throw some paint on it or else it's exposed metal and will rust.
Easier to just get camber plates. You should be able to get 2 to 3 negative degrees with this. We slotted ours as our camber plates are maxed out and we needed more. Quote:
11-18-2008, 04:55 PM | #4 | |
Supreme Allied Commander
3777
Rep 54,162
Drives: F80 M3
If you are still interested, please send us a PM. |
12-12-2008, 04:26 AM | #6 |
Rep 34
At the end……
Camber plates like K-mac stage 1 are not reliable. Camber plates with uniball are not good for street use. Other camber plate like vorshlag are too expensive. In next days I'll mill the holes by dremel. A friend of my did it and he reached -1,5 degree, enough for my use of the car. |
12-13-2008, 07:09 AM | #11 |
Rep 1,058
And you think changing the camber angle has no effect on other parameters.....
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
12-13-2008, 09:53 AM | #12 |
3777
Rep 54,162
Drives: F80 M3
Only if you have tried t\he lower wishbone links for added camber, better roll center, wider front track, deflection free inner joint instead of the soft rubber bushing found on the stock 135i wishbones. In addition, your strut tower can stay beautiful without not so great looking holes and rust!
12-13-2008, 10:47 AM | #13 |
Rep 10,176
FWIW, I also slotted them by an extra 1/4", which got me another 1 degree of negative camber. I'm at -1.6 deg right now. Used some primer and alpine white paint in the slot, but really, moving it around at all (additionally slotted or not) is going to scrape the paint.
I have KMacs on my 332ti, and I do not like them at all. Basically camber plates are supposed to make it easy to go between camber angles. Since the KMac plates allow for fore and aft, as well as side to side, with the same adjustment bolts, it's extremely easy to do things you had not intended. I am all for decent camber plates, but the KMac stage 1 do not fall into that category, in my opinion, by a long shot. Looking at those M3 wishbone arms, they seems to also be a good alternative, or even in addition to the slots, IMO. It has me thinking about the combination of those and my current setup getting me close to -2.5, for autocross purposes, with the ability to dial out camber easily (for street purposes) as well... |
12-15-2008, 01:46 AM | #15 | |
3777
Rep 54,162
Drives: F80 M3
12-15-2008, 02:15 PM | #16 |
Rep 48
I noticed that the Vorshlag camber plate uses a spherical bearing. Are the Vorshlag units good for combination track and street use? I've used sway bar end-links with spherical rod ends in the past and they were always noisy and in need of tightening (IMHO, not acceptable for a street car that goes autocrossing a couple times a month, but sees daily street service).
12-15-2008, 02:50 PM | #17 | |
Rep 10,176
There's not much to see in a picture. Mikeo, another moderator here, measured negative camber with the alignment pin removed, and got -.6 deg. I did not measure mine in that state, but did measure it with the pin removed and the slot dremeled another 1/4". I am at -1.6 deg right now. My sweet spot for front camber for autocross is around -2.5 deg, which I should be a lot closer to, if I add those M3 sourced lower wishbone arms. They are def on my short list (now that I know they exist) for next season's late winter mods. |
12-17-2008, 09:18 AM | #19 |
3777
Rep 54,162
Drives: F80 M3
12-17-2008, 10:08 AM | #20 |
Rep 776
These parts are presumably longer, increasing the track and increasing the negative camber in the process. If that is the case, they will also reduce fender lip clearance won't they? As this clearance is already an issue requiring modification of the fender liner, won't fitting of wider front wheels or tires become more problematic?
12-17-2008, 11:24 AM | #21 | |
Rep 10,176
01-19-2009, 12:32 PM | #22 |
Rep 1,338
if i'm reading this correctly:
the wishbone kit will put the top of the wheel closer to the strut, thus reducing clearance there, and increasing fender clearance. the same width wheel/tire should fit as without the wisbone kit, but will need slightly higher offsets or thin spacers to clear the strut (assuming minimal spacing from the tire to the strut with stock wishbones. they have no effect on the angle of the strut, just the wheel? sound right? has anyone combined the wishbones with camber plates? how much camber did you get? what wheel/tire/spacer combination did you use in the front? front camber with this car seems like its weak point... my e46 M3 was set at -2.5 for the street and -3.5 for the track. -1 is unacceptable on the track for a car of this weight, with such front tire width restrictions. |
