10-03-2008, 03:21 PM | #1 |
Rep 59
(DUMB) QUESTION ON 135i BRAKES
Hello everyone!!
Dumb question... i know... but have to ask.... Is the standard OEM 135i brakes system the same as the BMW PERFORMANCE BRAKE SYSTEM (pictured below) ?? The shape on the front calipers looks exactly the same.. only the color changes (yellow on the BMW performance / black on the OEM 135i brakes). Anyone...?? Ciao, Carlo
10-03-2008, 04:18 PM | #2 |
Rep 707
They are not the same, I can tell you that. The internal differences, I am not sure of. I would assume it's still a 6 piston caliper, because it does not look nearly big enough to be an 8 piston. The rotors are different as well, but those are quite cheap to upgrade ($100ish per front, there are no performance rear rotors atm). I know the stock calipers are made by Brembo and I would assume these are as well. Maybe someone else has some details on the internals. Certainly not a dumb question though.
-Ben |
10-04-2008, 02:16 AM | #6 |
Rep 59
I like the black calipers from the 135i better...
I wonder if the 135i standard calipers would mount on my 130i hatch "bolts on". Not sure... :iono:
10-04-2008, 08:08 AM | #8 |
Rep 420
Drives: E36 M3 3.2 (321hp)
Itt will fit the hatch also yes. And they are the same as the 135I callippers. I was drooling over a kit at my local dealer last month...
120d, M-sport, H&R springs,Remus Exhaust, 135I kidneys, 18"BMW performance with Toyo T1R.(summer) 17" style 207 with Michelin Xice(winter), 17" M3 replica with Toyo R888 (Track), Hardwired H/K GPS 810. SOLD! Now driving E36 M3 3.2 (321Hp)
Track and Autox |
10-04-2008, 10:54 AM | #10 |
Rep 10,176
The kit is lighter than the stock, because the calipers are drilled and slotted, making them weigh less. The pads are confirmed as the same part number, and the calipers are identical, except for the paint.
10-04-2008, 01:46 PM | #11 | |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Basically, if a 135 owner buys and installs the drilled/slotted rotors and painted his calipers yellow, he'll have the 'performance brake' package? |
10-04-2008, 03:32 PM | #12 |
Rep 10,176
LOL! I meant the rotors. Dunno about you, but I do not think I'd want drilled calipers. :wink:
And I believe you are correct about the paint and rotors. |
10-04-2008, 05:27 PM | #13 | |
Rep 472
How do you know this? Have you fitted to a hatch? Many people have been looking for this answer, but to my knowledge no one has found the answer posted on a thread anywhere. You help is appreciated. Thanks |
10-06-2008, 03:19 AM | #14 |
Rep 1,201
Only reason to purchase the performance brakes would be to keep the temperature down on the track and weight savings. Or just to look bitchin when you go the 1addicts meets.
10-06-2008, 04:49 AM | #15 | |
Rep 420
I also think the e81/87 was listed in the performance catalog...
Track and Autox |
10-06-2008, 11:43 AM | #17 | |
La Flama Blanca
27
Rep 1,545
AMS, Berk Technology, aFe, ER
10-06-2008, 03:21 PM | #18 |
Rep 3,160
They are different.
Brembo High Performance does not use any OEM components from production vehicles, and Brembo OEM does not use an High Performance products for production vehicles. There will be similarities is aesthetics since many of the same engineers and production methods are used, but when you see the products side by side there are many obvious differences. The differences are based on function and purpose of the system. While much of the criteria for quality, longevity and safety is the same between OEM and High performance, the aftermarket products from the High Performance division have an added benefit of being able to go for additional weight savings, firmer pedal feel, better modulation and control more suited to high performance and spirited driving, and ultimately a more performance oriented design. The calipers are lighter and stiffer. They incorporate a short annulus design, while maintaining large surface area and volume. The rotors are 2pc. fully floating. This design is advantageous for weight savings, improved longevity, and prevention of disc deformation. The disc itself actually comes directly from Brembo Racing division, while the hats and hardware are engineered specifically to the aftermarket application. The brake lines are braided stainless steel and come from Goodridge. The pads are suited for high performance street use and come from Ferodo. Every other item is engineered and manufactured by Brembo for the High Performance Division. |
10-06-2008, 03:27 PM | #20 |
Rep 812
If the caliper is different (and therefore better) why do BMW not list it as being available for the 135i - BMW certainly imply the calipers are the same, whilst the discs are clearly different of course.
Now, I can imagine their is a Brembo branded caliper that *is* an upgrade, but I'm yet to be convinced that the BMW performance item is. **********s, can you post photos of the differences?
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
10-06-2008, 03:38 PM | #21 |
Rep 863
I think **********s is referring to the Brembo GT BBK upgrade. That of course is not the same.
If you're already thinking of spending $$$ on the BMW Performance, might want to think about spending a tad more and get the Brembo BBK. Everything on the BBK is better. That and you have tons of brake pad options to go with. |
10-06-2008, 08:55 PM | #22 | |
Rep 1,201
I would love to see how many feet it takes to stop. |
