      07-08-2008, 04:47 PM   #1
jbenington86
Drives: 2015 M235i, 2017 Tundra
2015 M235i  [0.00]
2008 128i  [0.00]
Stock suspension
since we got the gas pressurized shocks should they last longer than hydrolic shocks?
      07-08-2008, 06:47 PM   #2
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
They are hydraulic.
      07-29-2008, 03:22 AM   #3
jdgomez
Drives:
I don't know about the others, but I'm thinking that the gas pressurized shocks last longer than hydraulic shocks.
____________________
Autopartswarehouse.com
      07-29-2008, 05:04 AM   #4
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
Gas pressurised shocks, still have fluid in them (hence they are still hydraulic). Normal shocks absorb the motion by just moving a piston with holes through fluid. Gas pressurised shocks do the same thing, but in addition also have a chamber above/below the fluid that has a moving piston. On one side of the piston is the fluid, the other side a pressurised gas. If the fluid moves hard enough, it pushes up against the second piston, that in turns applies extra pressure against the gas.
The advent of gas pressured shocks was what allowed easy external adjustment, as you can vary the gas pressure to change the shock characteristics.
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      07-29-2008, 06:46 AM   #5
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Shock Absorber (Damper) 101: http://www.monroe.com/tech_support/t...kabsorbers.asp
      07-30-2008, 08:00 PM   #6
rcracer_tx
Drives: BSM 135i
Originally Posted by atr_hugo View Post
Very good read, definitely a great explanation of the benefits and disadvantages of different suspension technologies. :thumbup:
      07-31-2008, 08:46 AM   #7
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Past BMW OE dampers usually maintain their peak functionality for ~25 to 30K miles. After that they pretty much worn out and your handling will be significantly improved by new dampers, either BMW or aftermarket.
1addicts
