      06-08-2008, 02:02 PM   #1
AndyM
AndyM's Avatar
134
Drives:
Let's remove the center console
Tools Required
  • Torx Driver with T-20 Bit
  • 10mm Socket
  • Interior Trim Removal Tools
Removing the pedal and glovebox trim
Begin by removing the trim that is above the pedals. There are 3 T-20 Torx screws (green arrows) and 1 push rivet (black arrow) holding the trim in place.
Next, remove the same trim near the glovebox. It has 1 push rivet and 2 T-20 screws.
I removed these pieces of trim completely, I do not know if it is possible to just remove the push rivets. You do not need to remove the glovebox nor do you need to remove the trim at the bottom of the steering wheel.
Removal of the Center Console
This can be done in no particular order, but I will start at the front and move toward the back of the console.
Begin by removing the shift knob, shift boot and emergency brake boot.
With the Shift Boot removed, remove the trim around the shift lever.
Remove the foam insulation around the base of the shift lever.
After you remove the foam insulation, you will see two 10mm bolts holding down aluminum L-Brackets. Remove them and set them to the side.
Along the passenger side of the console, there is a plastic cover. Move the seat so you have access to the cover and gently pry it off. Take care to not damage the surrounding console, but especially, do not damage the seat. With the cover removed, you will expose a T-20 screw. Remove it.
At the front of the emergency brake boot opening is another 10mm nut. Remove it.
At the back of the console, next to the iPod plug, is another cover. Remove it and remove the 10mm nut. Set both to the side.
Use an Interior Trim Tool to remove the iPod interface by prying it up. On the underside, you will need to disconnect the 3 plugs. Remove the interface and set to the side.
At the back of the armrest is a trim panel. You will need to remove the panel by prying at the indicated spot. The panel has a series of clips holding in place.
With the panel removed, remove the two 10mm nuts at the base of the armrest. There are 2 wiring harnesses you will want to disconnect from the console as well.
Removing the console, for real this time
You now have all the fasteners removed and are ready to remove the console. Before you begin, you will want to pull the emergency brake handle all the way up. All the way. I wrapped the handle in painters tape to prevent any damage as the console is big and awkward. Put the car in 2nd or 4th gear.
To remove the console, lift at the rear as indicated and slide the front back. If you have the emergency brake up enough, you will not come in contact with it.
Removing the Ashtray Trim Panel
To remove the ashtray trim, there are two Torx screws (T-20) that connect the center console to the bottom of the ashtray and the ashtray to the bottom of the ashtray trim. Remove the two T-20 screws:
With the Torx screws removed, you can remove the Ashtray Trim from the center console. At the front of the Ashtray trim, there are 2 “prongs” that extend out and under the HVAC stack. On the underside of each of these “prongs” are two press clips. Squeeze the press clips in and push to separate the “prongs” from the console. You will now be able to remove the Ashtray Trim panel. Take your time and if needed, you should look on the underside of the console for each clip.
Installing the Center Console
Installation is the reverse of removal.
      06-08-2008, 03:14 PM   #2
FreeBMW.net
Drives: 2008 BMW 135i
Very nice Andy! I like the blue... I cant wait to get my CF trim peices from you in the next few weeks....Now I know whats ahead!
      06-08-2008, 03:24 PM   #3
dimeesq
Drives: 135 Vert
Love the blue trim! Fantastic!
[SIGPIC][/SIGPIC]
2008 BMW 135 Vert
Montego Blue
Coral Red
HGB Trim
Cold Weather
Premium
Sport
Comfort Access
IPOD and USB
Satellite Radio
      06-08-2008, 07:52 PM   #4
amdmaxx
My gift Registry: M2
amdmaxx's Avatar
Drives: Future Mowner of Monster
nice
      06-09-2008, 01:04 PM   #5
RoninWheels
Mr. Brand Loyalist
RoninWheels's Avatar
41
Drives: 1M,M2cs
thanks for the DIY andy. also any luck with the CF ashtray trim? all the mounts on mine are the reverse of the original trim. im trying to work with BMW and the local parts dep. on this.
Current: 1M, M2cs
Retired: '08 135i,550GTxDrive, etc.
      06-09-2008, 01:27 PM   #6
AndyM
AndyM's Avatar
134
Drives:
I’ve never seen the CF ashtray trim.
      06-09-2008, 04:55 PM   #7
adc
Drives: 2018 F80 M3 ED
What type of blue is that, Andy? Montego? Leather, surely?
I think we need more pics, it looks good...
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      06-09-2008, 04:57 PM   #8
RobLS
Drives: M3 Coupe
Painter's tape?
      06-09-2008, 04:58 PM   #9
RobLS
Drives: M3 Coupe
Hey the interior color combo matches your avatar now.
      06-09-2008, 06:03 PM   #10
AndyM
AndyM's Avatar
134
Drives:
Montego. When the paint is under direct sunlight the match is very good. I will post pics when I add the leather parts to my site.
      06-09-2008, 06:16 PM   #11
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Yet another fantastic bit of work Andy! We really appreciate all of the DIYs you keep churning out. I added this one to the index as well.
Can't wait to see what you have in store for the trim.
      06-09-2008, 06:28 PM   #12
AndyM
AndyM's Avatar
134
Drives:
Can’t wait to see what you have in store for the trim.
That is the trim. Montego Blue leather.
      06-09-2008, 06:31 PM   #13
larryn
Whoops! I should've known you'd already have something. Looks very neatly done, as always.
      06-09-2008, 07:01 PM   #14
bigmicj
bigmicj's Avatar
Drives: 128i + M240iX
Hey Andy, I can't wait to see what leather parts you offer. I've always been impressed with your leather work.
I'm very close to ordering a boot and shift set from you soon!
Any chance we'll see some Coral Red arm rest covers in the future?
      06-09-2008, 07:14 PM   #15
AndyM
AndyM's Avatar
134
Drives:
      06-10-2008, 02:56 AM   #16
Motorsports_3
E30 Addict
Drives: 2008 135, 1988 325
Thats pretty baller.
      06-10-2008, 07:58 AM   #17
Jumpman
Jumpman's Avatar
19
Drives: .
On the blue trim, does it require the ashtray delete?
      06-10-2008, 08:38 AM   #18
AndyM
AndyM's Avatar
134
Drives:
I did not try to mess with the ashtray as it is useless. I doubt I could cover the lid of the ashtray and have it operate properly.
      06-10-2008, 09:42 AM   #19
joelk
joelk's Avatar
Drives: Space Gray E90 M3
that blue looks really nice. great job!
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT
      09-29-2008, 01:57 PM   #20
MZWIE
Drives: M2
Does the whole center console need to be removed just to replace the ashtray.
Also, do you offer a center console replacement that replaces the drink holders with parts bin?
      09-29-2008, 02:10 PM   #21
AndyM
AndyM's Avatar
134
Drives:
Yes, the console needs to come out to remove the ashtray.
There is not a ‘cupholder delete’ that I know of.
      09-29-2008, 08:03 PM   #22
MZWIE
Drives: M2
I've seen pics of European 1's w/o cup holder.
1addicts
