      05-26-2008, 11:19 PM   #1
stefan
stefan's Avatar
Drives: M2 Comp
Photo request: Front sway bar
Hi guys,
Can anyone post pictures of their front sway bar, either just from under the hood looking down (look near the rad) or under the car with the shroud off?
Thanks !!
///M Power
      05-27-2008, 12:03 AM   #2
morscode
Got Boost?
morscode's Avatar
Drives: 19 x3 m40i
I think I've seen an H&R set
      05-27-2008, 12:05 AM   #3
stefan
stefan's Avatar
Drives: M2 Comp
I'm actually interested in the construction of the existing one.. anyone?
///M Power
      05-27-2008, 01:13 AM   #4
blklacker
blklacker's Avatar
50
Drives: 135i
Originally Posted by stefan View Post
Hi guys,
Thanks !!
Kinda difficult picture to get since the under carriage of the 135i is pretty much sealed. I think I can sneak a pic but it wont be great.
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade
      05-27-2008, 01:38 AM   #5
RobLS
Drives: M3 Coupe
pretty tough. looks like a nice time consuming mod to take care of, but enjoyable none the less.
      05-27-2008, 10:40 AM   #6
stefan
stefan's Avatar
Drives: M2 Comp
Thanks for those.. not looking good. Quite the PITA by the looks of it.
How about one from the top down? There's a space between the block and rad. If you aim the camera down there with some light, you can see it clearly. Are there any notches in it?
///M Power
      05-27-2008, 12:46 PM   #7
blklacker
blklacker's Avatar
50
Drives: 135i
The engine block is quite large they is very little space, I will give it a try later today.
      05-27-2008, 12:51 PM   #8
stefan
stefan's Avatar
Drives: M2 Comp
Thanks blklacker!
///M Power
      05-27-2008, 12:52 PM   #9
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
The OE front bar is hollow construction to save weight according to BMW.
      05-27-2008, 12:59 PM   #10
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Originally Posted by Phiberglass View Post
I'd like to see these too. What options do we have for a sway bar right now. Just BMW performance?
Not positive, but I don't think the BMW Performance suspension includes sway bars. The ones I have seen are H&R and Eibach. They can be seen at Tirerack.
AMS, Berk Technology, aFe, ER
      11-11-2008, 07:02 PM   #11
one-35
one-35's Avatar
20
Drives: BMW e92 M3
Does anyone know if the 128i comes with sway bars? And if so... the same or different than 135i?
I just upgraded to H&R and would like to sell my OEM BMW front sway bar/bushings. Perhaps a 128i owner would be interested (for a good price); the BMW bar is a lot lighter than the H&R (due to hollow construction as mikeo described above).
      11-11-2008, 08:42 PM   #12
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Link to 128i parts and sway diagram part number 31356766286 is 26.5mm
Link to 135i parts and sway diagram part number 31356766286 is 26.5mm and is the same part number.
      11-11-2008, 11:19 PM   #13
one-35
one-35's Avatar
20
Drives: BMW e92 M3
Ahhhhh... but if you look closely, the 135i (and 128i with M Sports Suspension) is actually P/N 31356766288 (ends with 288, not 286)... dia. is same, but I wonder what's different (if anything).
      11-17-2008, 06:14 PM   #14
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
Once you pull the plastic convers off, the front sway is cake to remove/install. I'd say it's definatly doable for the average home garage warrior.
It's the rear that is a $300-400 job to get to.
      11-17-2008, 06:16 PM   #15
BerkTechnology
223
Drives: Fast
PS - HIGHLY recommended that you do both front and rear.
      11-20-2008, 01:04 PM   #16
one-35
one-35's Avatar
20
Drives: BMW e92 M3
Thx! It took my local mechanic/shop 12 MINUTES to remove/change out my front sway bar! ...including lifting car and removing all 18 screws holding the plastic underbody piece. 2 guys with air tools... damn fast!
Maybe they can do the rear in 45 minutes.
      11-20-2008, 01:10 PM   #17
BerkTechnology
223
Drives: Fast
If they're really good, they can do the rear bar in ~1 hour. Took us about that time with two guys.
But definately don't try this one at home.
      11-27-2008, 01:57 PM   #18
spr
Drives: F80 M3; e92 ESS650+ M3
why not- if you have a lift and air tools? Might as well also replace the rear subframe bushings at the same time too-
      12-11-2008, 10:08 AM   #19
RedTRex
Digital Cerebrum
Drives: 05 330ci ZHP
2005 BMW 330ci  [0.00]
I installed Front and Rear Hotchkis sways using only floorjack and jackstands at home. Front took me less than an hour - rear took me 2 hours - I do have air tools.
      12-11-2008, 02:07 PM   #20
spr
Can you provide a little bit more specifics on how you lowered the subframe as well as inserted the sway for tips? Thanks! Good stuff.
1addicts
