      05-17-2008, 05:38 PM   #1
Templedogg
Drives: 135i, Trailblazer SS, 1934 PU
BMW Performance Front Rotors DIY
This is very simple installation and should only take 40 minutes or so to install.
All you will need is:
Jack (optional rubber protector)
10MM Allen socket
6MM Allen socket
17MM Socket
Torque wrench
Bucket
1. Before Pic. Break free your lug nuts with 17MM socket. Do not loosen too much.
2. Jack up the car. I have the sport springs so I needed to find a nice spot in my driveway for enough room. A quick tip to save your jack points looking nice is to either buy a rubber spacer for your jack, or like me just cut the sole off an old shoe...works great! Remove the wheel.
3. Notice the bolts have white paint marks showing the line up points. If they are not marked well enough, mark them better with a Sharpie. Use your 10MM Allen Socket to remove these two bolts.
4. Use a bucket or something to rest the caliper on, do not let it just hang!!!
5. Remove the bolt holding the rotor on with a 6MM Allen socket. (I missed a pic of this during the install, but this pic shows the bolt) Remove the rotor and put the new one on. Tight the 6MM bolt. No need to torque it down a bunch, just make sure it is tight.
7. Put the caliper on and tighten the two 10MM Bolts back and forth until the white marks line up. It is a lot of torque to get them there, but I am not sure the exact amount.
8. Put back on the wheel and snug tighten all lugs in a star pattern. Lower the car and torque the lugs to 88 pounds.
Your done, do the other side and have a beer.
      05-17-2008, 06:03 PM   #2
Ragenikon
Drives:
Hottt, this is def something i'm looking to do and now that i know its that easy i'm game for sure. thanks! great write up
- 135is -
Sedona Red
Aluminum Trim
Black Boston Leather
Cold Weather Pkg
Sports Pkg
Premium Stereo
PCD June 3rd!
"The steering, the feel, the way you can adjust your line through the bend with the throttle. There is no other car made today in this sector of the market that gets even close. If you love driving, this is up there in a class of One."
- Jeremy Clarkson -
      05-17-2008, 06:28 PM   #3
ki__
Drives: 19 M2C 6MT
how much and where u get them?
      05-17-2008, 06:29 PM   #4
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
Did you feel the weight difference when you were holding them?
Dan from united BMW is selling them for $110 each...and they are covered under bmw maintenance!!
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      05-17-2008, 07:39 PM   #5
FreeBMW.net
Drives: 2008 BMW 135i
call me crazy...but i think the rotor are on the wrong side...if i recall correctly the slot should facing the other direction.
      05-17-2008, 08:15 PM   #6
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
Those look SWEET/HOT.
How much total???
      05-17-2008, 09:01 PM   #7
new2the3
new2the3's Avatar
Drives: 2020 X3M Competition
Looks so nice, can you tell any difference is braking?
      05-18-2008, 02:29 AM   #8
Templedogg
Here are some answers.
I paid $105 each from Dan at United, I have only put on 4 miles since installing them, so they feel the same so far.
There is not a seperate right and left rotor, so the slots run different on each side...which is perfectly OK.
I was going to weight them but forgot, maybe the next guy can...but yes them did seem lighter during the install.
My last track day the stock ones temp at 305 degrees after a 20 minute session, I will temp these at my next event June 5th and post the results to see if they run any cooler and or feel different at the track.
      05-18-2008, 03:18 AM   #9
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Saves a couple pounds of weight, plus, they look kool.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      05-18-2008, 03:54 AM   #10
matt
Germany
61
Drives: munichs finest
i hope these wont rust as the oem's does (not the brakes, the thing where the wheels are screwed on)
f*ckin' love my car <3
      05-18-2008, 01:31 PM   #11
ChrisK
ChrisK's Avatar
Drives: '19 M2C
My fronts show up this Tues via Fed-Ex :biggrin:
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      05-19-2008, 08:18 AM   #12
ChrisK
ChrisK's Avatar
Drives: '19 M2C
That would be great info to have. Great DIY!
      05-19-2008, 04:14 PM   #13
Templedogg
Chris, please weight yours when you get them. I can not believe I forgot to weight mine.
      05-19-2008, 07:35 PM   #14
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I weighed them on a UPS approved Toledo scale:
21.42 lbs each (Performance Rotor)
      05-22-2008, 03:05 PM   #15
Texas
Texas's Avatar
Drives: G87 &amp; E88
How about some updated pics? I'd love to see how the rotors look with a few miles on them.
Thx!
      05-22-2008, 06:42 PM   #16
Rye
Drives:
You may want to also add to do a pad bedding procedure to get a good even pad deposit onto the fresh rotors.
      06-19-2008, 08:02 AM   #17
Jack (LA)
Drives:
Chris,
Do you have the weight of the stock rotor that you removed?
      06-19-2008, 09:02 PM   #18
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Unfortunately, I didn't weight the OEM rotor. I will take it to work on Fri and weight it.
*I thought some on the 1addicts did weight the oem rotor, but I can't seem to find it.
      06-20-2008, 12:33 PM   #19
Andres G
4s Club - Are you member?
Drives:
Love this DIY. Thanks!
Anyone have a link to reach Dan at United?
Also, which type of pads are you using? Stick to OEM or any other compound recommended?
Thanks!
      06-20-2008, 12:58 PM   #20
lamini
Drives:
great!
You have less friction surface now.....How does that feel?
You'll be amazed on how those things eat through your brake pads.....but if you have deep pockets.....not a concern at all....eh.
      06-20-2008, 01:53 PM   #21
Templedogg
Thanks!
Nobody really makes pads yet. When they do I will most likely run something else when the stocks are gone.
      06-20-2008, 02:27 PM   #22
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Originally Posted by lamini View Post
great!
Let's keep this civil
1addicts
