E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Android head unit causing dash issues?
      04-22-2024, 02:00 PM   #1
PaddyH
Drives: 2007 E93 335i
Hi Guys, first time poster here. I’ve found a couple of similar posts to this but thought I’d ask my own question.
Recently bought a 2007 E93 335i. The cars been great up until today. I fitted a Chinese Android head unit on the weekend as I wanted CarPlay and it’s worked fine for the past few days. However, today the dash warning lights started playing up. First it was a red ‘car on a lift’ light and a yellow circle with a triangle in the middle and an exclamation mark (DSC module failure). A reset of the head unit seemed to sort this. Then on the next start up I had a load of warning lights and all of the needles were bouncing around. Again, a reset of the head unit seemed to sort this out. Just been out to more problems and it seems the head unit has frozen!
My question is…….. Are these dash issues just a coincidence or could the head unit really be causing them? If so, how?
Thank you,
Paddy
      05-03-2024, 11:05 AM   #2
BRG_N54
BRG_N54's Avatar
Drives: Green '07 & Arctic '08 335i's
2008 BMW 335i  [0.00]
2007 BMW 335i  [0.00]
Your new head unit is causing a greater load on the electrical system than prior. Normally the symptoms you describe are a bad voltage regulator. The regulator could have been going bad prior, but the new component exacerbated the issue.
I would start by checking the car's voltage while running, easiest to do with the secret KOMBI menu. You also might want to check for parasitic drain, which could have also been introduced from your new electronics.
PaddyH3.00
      05-03-2024, 07:58 PM   #3
ctuna
Drives: 325xi 06 wagon MT
If the new stuff is alway's on it will drain the battery .
Or if it prevents the car from going to sleep it will drain
the battery .
PaddyH3.00
      05-05-2024, 10:05 AM   #4
PaddyH
Thanks for the reply’s guys. I will investigate.
BRG_N54314.50
      05-06-2024, 06:46 AM   #5
PaddyH
Ok so when driving the voltage guage tends to sit around 14v-14.2v. There is the occasional fluctuation though. I saw it drop as low as 12.9v momentarily. I will change the voltage regulator and see if that helps.
Thanks again
BRG_N54314.50
      05-17-2024, 12:38 PM   #6
PaddyH
I swapped out the voltage regulator and things are definitely better but not perfect. I ordered the regulator from AUTODOC based on the pic I took of my alternator 0121 715 016. I bought a regulator that AUTODOC said would fit but the serial numbers are different to the one I removed. Is this why things are not ‘perfect’ or is there another problem? I’m thinking I need to take my car to the shop.
e90post
