10-01-2023, 07:00 AM | #1 |
Rep 13
Loose steering (video) - is it normal?
Is it normal for the steering wheel in G20 (M Sport variant) to have such tolerance in the center position when driving ~150km/h?
You can move the steering wheel couple of degrees off center without the car reacting to it. This tolerance is much bigger during hot weather. |
10-01-2023, 12:19 PM | #2 |
Rep 288
I don't think there is any known fix for the steering issue. Micro corrections are constantly needed. It's not the tires or an alignment issue (that's my personal opinion, but some say that an alignment can somewhat help. The problem has been widely widely reported across the entire 3 series. FYI -- Here are some links on this.
1) At 22:35 the guy talks about the steering issue on the M340 x drive. Watch from 22:35 onward... here is the link https://g20.bimmerpost.com/forums/sh....php?t=1774603 2). general discussion https://g20.bimmerpost.com/forums/sh....php?t=1865372 3). another discussion thread https://g20.bimmerpost.com/forums/sh....php?t=1855230 4). The EDMUNDS editor and senior testing manager says: "The steering in this X3 leaves me with mixed feelings. I really enjoy driving around town thanks to its small dimensions, tight turning radius and overall maneuverability. On the highway it's a different story. The steering wheel is numb off-center. So after a short time on a straight road, with the steering wheel pointed dead-ahead, the car drifts slightly. It requires constant, small adjustments to keep the car in the middle of the lane. It happened often enough that I switched from Comfort to Sport mode, thinking the heavier steering setting might help. No such luck." — Mike Schmidt, senior manager, vehicle testing operations... From the same review: "Similar to the base X3, the M40i's steering sometimes succumbs to a heavy-yet-lifeless feel, giving the SUV a wandering sensation that's especially evident while cruising on a highway." Here is the link: https://www.edmunds.com/bmw/x3/2022/...erm-road-test/ |
10-01-2023, 10:02 PM | #3 |
Rep 73
No matter what anyone tells you in the service department, definitely not normal, not for any car, From what I've red here, not all 3 series will have the problem. Anyway, service dept. will probably tell you the play in the wheel is normal because of electronic steering or some other BS. Trade the car or just get used to it. Maybe see if BMW NA will consider swapping it for a new one with no loss to you. Find out who your regional rep is and contact the person.
10-02-2023, 09:35 AM | #4 | |
Rep 15,858
There is one check I'd be making. When stationary and switched off, is the steering loose in that state, as if something is adrift, or just a good tight and 'rubbery' resistance feel? Years back, when we had loose steering, we could physically move the wheel to and fro, with no resistance when stationary, highlighting worn and/or loose parts. BTW, my EPS is very tight in the stationary and off state. Just the feeling I'd expect, that you are initially working against and loading up the rubber suspension bushing. |
10-02-2023, 10:43 AM | #5 | |
drives cars
243
Rep 319
Drives: '23 IS 500, '23 X3
2023 BMW X3 | Phytonic Blue | Black Vernasca Leather | Dark Wood Trim 2023 Lexus IS 500 F Sport Performance | Infrared | Black NuLuxe |
10-02-2023, 03:40 PM | #6 |
Rep 288
I believe the steering issue has been reported across the entire 3 series, including the X3. Still, not all owners have experienced the problem, it seems to be kind of hit or miss.
10-05-2023, 05:59 AM | #10 |
Rep 15,858
Steering problems exist, but does your 'normal' mean there are no issues with the examples which display such traits?
I will never accept loose steering, clunking, or need for constant micro-corrections being within BMW's design intent. It has to associated with manufacture and/or tolerances in the wider steering and suspension system. Essentially a quality control issue. As I posted for the OP, I'd first check if there is loose steering wheel movement, when switched off and stationary. It's a simple problem elimination path. |
10-05-2023, 12:16 PM | #11 |
Rep 288
^. correct! what I meant, was it may be "normal" to find this steering issue problem across the 3 series line of cars, but, of course, it is indeed abnormal to have this kind of steering issue in the first place.
HighlandPete6658.50 |
10-07-2023, 10:42 AM | #13 | |
Rep 73
No surprise there. Of course, it is NOT normal. Get your regional rep involved and ask them to swap out the car, but you could get one that has the same issue again. BMW knows full well about the issue of the wandering steering. |
