07-03-2007, 11:40 AM | #1 |
Santa Fe Concorso
103
Rep 2,984
Let's talk brakes...
The new front brakes for the 135i referred to in the press release sound like they will definitely get the job done. Anyone know anything about this setup?
When people ride in my E36 M3 the first thing they comment on are the great brakes.
07-03-2007, 11:46 AM | #2 |
Zoom Zoom
38
Rep 1,069
We wont know anything until people start taking a look at the car in detail. All I know is that the setup is definitely unique to the 135i. I cant remember the last time BMW offered more than 2 pistons on their brakes.
07-03-2007, 12:07 PM | #3 |
Santa Fe Concorso
103
Rep 2,984
Were the E46 M3 Comp package front brakes 6-piston?
07-03-2007, 02:26 PM | #5 | |
Rep 19
Until specs are released on the 135i replacing the braking components makes no sense.
2006 Mazdaspeed 6 - Liquid Platinum
1999 Jeep Cherokee Sport - 4 Door 5-speed Red |
07-03-2007, 02:52 PM | #6 |
Santa Fe Concorso
103
Rep 2,984
It looks like we'll get serious results from the OE setup to me. if you track it just upgrade the fluid and swap pads at the track.
07-03-2007, 03:06 PM | #7 |
Zoom Zoom
38
Rep 1,069
If I remember correctly, the M3 CS got the CSL's brakes which were nothing more than enlarged, cross-dilled rotors. Which means that it retained the M3's single-piston actuation. Take a look at this picture, and it is clear that those arent even close to 6-piston brakes:
07-03-2007, 04:35 PM | #8 |
Future N54 Owner...
Rep 140
I'm pretty sure it's going to out brake anything in it's class, and is going to set some record with 6 piston calipers and 3200LBs...
Realistically, with the M package, i don't even know if i'll modify the suspension, and I'll modify anything |
07-03-2007, 04:53 PM | #9 |
Rep 908
Another thing to take note of is that the Press release said 6 piston fixed calipers :thumbup:
Vorsprung durch Gas Geben!! 172 of 740 |
07-03-2007, 04:57 PM | #10 |
Santa Fe Concorso
103
Rep 2,984
As opposed to floating? Ed-u-ma-cate me.
07-03-2007, 05:10 PM | #11 |
Rep 908
I'm no expert but a quick, off-the-top-of-my-head comparison would be... Floating = OEM Design, Fixed = BREMBO BBK's :biggrin:
07-03-2007, 05:14 PM | #12 | |
Zoom Zoom
38
Rep 1,069
From Wikipedia:
07-03-2007, 05:18 PM | #13 |
Rep 908
OK, quick look at How Stuff Works leads me to believe that a floating caliper has the piston on the inboard side and as pressure is applied, the inner pad meets the disc first, as the piston extends further, the caliper shifts inboard and the outboard pad "floats" inward and meets the disc.
A fixed caliper is (I think) unmoving and has a piston (or in this case 3) inboard and outboard which presses the pads in towards the disc. Did that make any sense??
07-03-2007, 05:19 PM | #14 |
Rep 908
Crap! All that typing (OK, all that Babble) and MPower beats me to it (and with a better explanation I might add)
07-03-2007, 05:20 PM | #15 | |
Zoom Zoom
38
Rep 1,069
07-03-2007, 05:30 PM | #17 |
Santa Fe Concorso
103
Rep 2,984
They were both very helpful. Thanks, gentlemen.
07-03-2007, 09:49 PM | #18 |
Rep 445
I'd just like to see the 60-0 distance with the 6 piston calipers. Also, Don't forget the rear is twin piston calipers. Mercedes-Benz had a C-class recently that had a 108 foot stopping distance, and I've seen Porsches at 99 feet. I've seen the 335i listed at 114 feet.
Here's hoping that brake setup will be offered on a 128i M-sport. |
07-03-2007, 10:34 PM | #19 |
Rep 146
Nobody appreciates the value of great brakes more than I do, but if they'd just shave a few more pounds off this baby... the trick brakes wouldn't be needed. Or, they could do both! $35K supercar:roundel:
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
07-03-2007, 10:57 PM | #20 | |
Rep 2,750
Drives: 2020 M4 ZCP / 2023 X3 M40i
07-03-2007, 11:46 PM | #21 |
Rep 188
The M-Sport 6-piston brakes are indeed Brembo. This was made clear to us that were in attendance at a BMW employee event in the middle of June.
[SIGPIC][/SIGPIC]
07-03-2007, 11:53 PM | #22 | |
Rep 146
I guess I only take issue with the idea that engaging the ABS is the shortest stopping technique. For many people it may well be, but if the driver can modulate the brakes effectively, keeping the tires right at the threshold of lockup, stopping distances are measurably shorter than what ABS can accomplish. Threshold braking may be more easily and consistently acheived with the multi-piston, fixed caliper system on the 135 coupe. If so, this is a worthwhile improvement and not a marketing gimmick. I think, if nothing else, I've convinced myself.
