Rev for Track Days
01-25-2009, 09:29 PM | #3 | |
Rep 4,445
Every 5-6 tenths of a second. The spikes are throttle blimps I performed with boost. I shocked to see how quickly the temps increase. I wasn't testing the timing yet, just practicing some runs prior to getting the real data. I want to see how the temps impact the timing in real time.
01-26-2009, 07:59 AM | #5 |
Rep 81
01-26-2009, 09:20 AM | #6 | |
Rep 4,445
Ocha, you'll have to update your iphone to 2.2 prior to using this software. Just keep that in mid.
01-26-2009, 09:29 AM | #7 | |
Rep 4,726
Where did you buy the hardware? I thought I saw yours had cables instead of blue tooth? Is the sampling rate adjustable (.5-.6th tenths is a little slow)
Then again it's probably the only logger you can take out on track safely and mount in a visible place on the dash.
01-26-2009, 09:37 AM | #8 | |
Rep 4,445
The cable plugs from the OBD port to the wireless transmitter. I agree about the price, but it's portable. The developers are working on the timing, I've emailed a few suggestions that will be implemented on the new update. They want "car guys" to send in suggestions to improve the product. They are working on reducing the data log intervals now. I'll take a pic of my setup and post it in a bit. With your set up, $100 bucks compared to strapping your laptop in there.
01-26-2009, 12:28 PM | #10 |
Rep 4,726
OBDII specification sensors, basically things that pretty much every car has. In other words throttle probably, yaw probably not.
01-26-2009, 08:51 PM | #12 |
Rep 4,445
Don't fight it....you can't overcome the power of the Rev.
01-26-2009, 09:08 PM | #13 |
Rep 4,726
Yea but I know as soon as the hardware ships some asshole is going to post about how you can use this cable with this Wlan interface to make yourself a $50 hardware piece that works.
In fact I'm pretty sure If I plugged one of my usb or serial OBDII cables in to a Wlan converter it would work. But it's not worth it for me to bother really. Oh BTW my stuff is on the car, you're going to get pulled so hard next Sebring you'll think you're in limp mode.
01-27-2009, 08:16 AM | #14 |
Rep 4,445
I hope so, with my rolly-polly family car.
01-28-2009, 10:45 AM | #15 |
Rep 4,726
Ahahahaha, nice sig change. BTW did you ever check out safe?
http://www.safemotorsports.com/schedule.htm 1st 30 min 1 run group 2nd 30 min another run group, then the next 5 hours of track time is totally open session.
01-28-2009, 09:54 PM | #16 | |
Rep 4,445
I did, but the dates are so far away.
02-02-2009, 06:36 AM | #18 | |
Rep 4,445
I am using a proclip mount here with a tilt swivel mount here and use a power supply tap to the glovebox aux power (BMW adapter $10). It's a bit expensive but very high quality, clean and secure.
