07-02-2023, 08:32 PM | #1 |
Rep 128
Drives: 2023 M2 & 2018 M2
Question about MDM esp on 6MT
I've been testing the JB4 and didn't notice it till later runs but the car will pull throttle out even when pedal is 100%. This isn't traction control it's a consistent amount. For my car it seems to be around 60% throttle when WOT.
After doing some poking around I read that m dynamic mode is designed to keep the turbo spooled so when you are on and off the gas there isn't lag. So based on that I understand the reason for keeping the throttle closed a bit and turbos spinning faster. However, what may be good on a road course may not be ideal on the drag strip. When I turn MDM and DSC off there is less of this issue but it is still present. However I was running M-Traction at 3. Anyone else have an explanation, do any testing or know if this is something that can be tuned out with a custom tune? Do items like the Dinan Throttle Booster override this behavior? Thanks |
07-02-2023, 09:28 PM | #2 |
Rep 3,016
Drives: A Family Sedan
Your post is very confusing.
Let’s try to break it down. You said you’re getting throttle cut, based on what data? You said it’s not because of traction control, but you indicate you have traction control on. Can you try with it off? Also, you said that you turn MDM and Traction Control to 3. I’m confused, so to clarify, you mean at different times, right? Since it’s impossible (and incongruent) to have them at the same time. MDM is traction control from 4 to 7, computer determined. |
cmgbk752633.00 |
07-02-2023, 09:57 PM | #3 |
Rep 128
I should’ve included the link to the thread of my JB4 testing. In that thread there is a spreadsheet with data from JB4 logs.
https://g87.bimmerpost.com/forums/sh....php?t=2030423 When I said it wasn’t traction control that’s what I meant. Not the system but rather the applying of traction control. Conditions aren’t such that there would need to be traction control system intervention. This is throttle being pulled out consistently at speed. Spreadsheet is of 4th gear. MDM is needed for launch control so I’ve been testing with it on. but in 4th gear not sure what it would need to do in a straight line. However as I mentioned I did turn off MDM and DSC and had m traction control set at 3 on another test. This improved the situation but still pulls out throttle at speeds. Instead of pull back to 60% it was 70-80. I have yet to log DSC off and M traction at 0. But it is on my to-do. I have about 9 WOT 4th gear tests ranging from JB4 disabled to map 5. I also tested efficient and sport plus engine settings. My question is about MDM specifically. Is it designed to keep the turbos spooled up so that on / off throttle conditions don’t result in lag? And does it do this by reducing throttle opening and over spooling the turbos?
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, JB4, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro IG: Follow ME: genXg87 |
M2siast5943.00 |
07-02-2023, 10:27 PM | #4 | |
Rep 3,016
While I understand and agree traction control shouldn’t intervene in higher gears/speeds, it’s best to take it out of the equation first. Let us know what happens with TC off. I’ve never heard the claim MDM does anything with engine mapping to spool turbos and not move the car, not sure how it’d do that other than opening the wastegate, which shouldn’t affect “throttle” (understanding these cars don’t use the throttle at all since it’s always 100% open, and valvetronic does the rest). But I’m no expert. I understand MDM only allows some yaw and wheel spin, nothing more, nothing less. |
GenXG87180.00 |
07-03-2023, 09:03 AM | #5 | |
Rep 128
Understood about the valvetronic. However, there is still something happening. You can see there is a boost differential from sensor 1 and sensor 2 on the spreadsheet. I'm still getting my head around these engines and where everything is at how it works, so I'm not sure where the 2 readings are coming from. But, I have observed and logged the boost difference and it's correlation to the reported throttle. If the JB4 is targeting 25 psi, sensor 1 will be close to that, while sensor 2 may have a 4-5 psi reduction when the throttle shows 60%. Is there a blow-off or diverter on the intake stream? I could see that impacting the boost reading in two places on the intake side. |
07-03-2023, 09:05 AM | #6 | |
Rep 3,016
I was going to suggest the DME is understanding the deviation from the JB4 and trying to protect the engine. What does Burger tuning have to say? |
07-03-2023, 09:24 AM | #7 | |
Rep 128
I've confirmed that it has the same behavior with the JB4 disabled. I've also tested Map 1 - 5, and it does the same thing pretty consistently. Waiting to run the tank down and go back to 93 octane only to rule out that there is anything happening there. |
M2siast5943.00 |
07-03-2023, 09:26 AM | #8 | |
Rep 3,016
GenXG87180.00 |
07-03-2023, 03:47 PM | #9 |
Rep 258
What wheel speed are you at in 4th at 6000 rpm?
I really doubt traction control is limiting throttle in those case, makes no sense. I also cannot imagine you are hitting 155 mph limit in 4th Seems something is limiting boost I’m not big on piggybacks because they intercept signals to fool the ecu. I’m not sure I’d keep at the same thing without any tuning changes as the ECU is limiting you for some reason Easy enough to verify not TC, just disable it, M trac at 0
2023 M2
2014 Triumph Trophy |
07-03-2023, 04:43 PM | #10 |
Rep 128
Oh man that would be the ultimate conspiracy theory. But would be a great explanation too.
M2siast5943.00 |
07-03-2023, 04:45 PM | #11 | |
Rep 128
Also tested with JB4 disabled. I’m beginning to believe this is as intended but just not documented. Waiting to see some other G87 6MT logs in the wild. The car still runs hard but would rather get the boost and not work the turbos as hard.
07-11-2023, 05:18 AM | #12 |
Rep 962
Drives: G87 M2, G20 330d, Brabus Smart
It's my understanding that only Sport and Sport Plus throttle settings will affect the behavior of the turbos (anticipatory spooling if you will). But that was on F8X, not sure if that's been changed on the G8X series.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
GenXG87180.00 |
07-11-2023, 07:05 AM | #13 |
Rep 128
There is definitely different behavior between efficient and sport/ sport+ with higher boost on the JB4. It actually had a surge effect on efficient and logs showed it bouncing from about 60-100 throttle. On sport it pulls the throttle but car is smooth
DBV784.50 |
07-30-2023, 05:27 PM | #14 |
Rep 2,368
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Turn that DSC crap off and drive with your right foot.
Pass me if you can.
08-04-2023, 09:20 AM | #15 | |
Rep 1,189
Really I wouldn't worry about the turbos. Or if you worry then stay out of the throttle. But even then I suspect there is some boost being made under some conditions. I've not bothered to data log my M2 but with my Porsche Turbo and its in dash boost gauge even encountering a bit of up grade at freeway speed would have the boost climb to 0.2 bar. "Maximum" boost under normal circumstances was 0.7 bar. Wouldn't surprise me if the M2 engine makes boost some boost even if one isn't hard on the throttle. |
