Something really weird with the alarm
01-18-2009, 07:39 PM | #1 |
Rep 110
Ok before the car wash everything was fine, and when i unlock the car it will beep and locking the car beeps again.
but after I washed my car and drive it back to the garage and lock it, it wouldnt beep?! I did that 5 times consecutively and it doesn't beep it just locks without any beeping sound. Anyone know whats going on?? Is BMW not waterproof? |
01-18-2009, 08:30 PM | #2 |
unstratified
Rep 162
Hold the trunk button on the remote down for several seconds; the panic feature will confirm that the siren is still functional. It's located in the left rear wheel well, though I always try to rinse them fairly thoroughly and haven't had any issues.
Of course it wouldn't hurt to double-check that audible confirmation is still enabled in the locking menu... |
01-18-2009, 08:37 PM | #3 |
Rep 110
Ok thanks man I tried and the siren works, but what is located in the left rear wheel?
01-18-2009, 08:53 PM | #5 |
Rep 110
01-18-2009, 09:02 PM | #6 |
Rep 7,433
physical siren unit should look like a megahorn/bullhorn. square and hollow with a cone inside of it.
the left wheel well is the whole entire opening where the front left (drivers) side wheel is.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-18-2009, 09:08 PM | #7 |
Rep 110
I see thanks but I am just asking about the unlock/ lock chirp what does that have to do with the wheel well and the siren unit??
01-18-2009, 09:13 PM | #8 |
unstratified
Rep 162
I believe the chirp comes from the alarm siren, but I could be mistaken.
There's a drawing in the installation instructions attachment in this DIY thread, though if it went off when you tried the panic it's probably fine. The option for audible confirmation depends on whether you have iDrive; if you do it's on the same screen as where you select if you want the lights to flash on lock/unlock. Not sure about non-iDrive models. I had to take mine back to be recoded as the audible options were missing after the alarm install. At least that's the way it worked on '07s. Good luck. |
01-18-2009, 09:13 PM | #9 | |
Rep 5,271
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
01-18-2009, 09:15 PM | #10 |
Rep 634
Usually, if the alarm doesn't "chirp", it's because there is something that is still open. Make sure all the doors are securely shut; also, the fuel door, trunk and hood may be the culprits.
Usually, when I lock the car and the alarm doesn't chirp, it's either the trunk or the fuel door that's open and getting in the way of the system arming itself. ("madmd", above, posted at the same time I did - hope this isn't too redundant.) |
01-18-2009, 09:19 PM | #11 | |
Rep 110
However when i lock it the lock does clunk and it is locked. |
01-18-2009, 09:31 PM | #13 |
Rep 110
OMG guys i found out what was unshut! it was the trunk, i guess when i was blasting my trunk with the hose reel, its too powerful and the water that rushes accidently opened the trunk,
now it works fine, thanks fellas! |
01-19-2009, 02:48 AM | #14 |
Rep 7,433
dude, you don't need a high pressure fire hose to wash your car. that's actually really bad for it... be gentle one time.
-Brian
