Am I prewired for SAT radio?
01-18-2009, 06:20 PM | #1 |
Rep 464
I just got the car yesterday. I am not sure if it is prewired or not.
Sharkfin on the roof, the following connections under the trunk. |
01-18-2009, 06:30 PM | #2 |
Rep 2,213
Im curious myself. My wife just got a new trailblazer and it has Sat radio and I like it. Would like to put it in mine but don't want to pay for install. If this is pre-wired, I could do it pretty easily myself.
Current: 07 335i e90 Previous: 09 Acura TSX PWP Tech Previous: 07 335i e90 with L.E.T. Flash |
01-18-2009, 07:02 PM | #3 |
Rep 1,088
All 3 series in the US are prewired with the SAT antenna in the sharkfin. One of those connectors is the SAT antenna. If I remember correctly, it is the black one with the dual port. Just plug your SAT radio antenna cable in one and see if it works; if not, then try the other one.
01-19-2009, 07:50 AM | #4 |
Rep 339
Probably. The pic above looks like the bundle for the TCU (assist + bluetooth ) module. The Sat radio bundle is in the same location. it is 1 fiber connection and one antenna connection.
To install: 1) get the right sat radio module for your VIN + mounting bracket 2) install module in trunk (search DYI on this forum for PDF) 3) configure MOST fiber loop (same DYI) 4) go to dealer for programming to include the module. |
01-19-2009, 11:46 PM | #5 |
Rep 464
So I am not prewired. I have searched and read several posts.
Has anyone actually spent the money and time to add the proper harnessing and updated roof antenna? I doubt it. I am thinking that I would need the following: - roof antenna inner receiver (exterior painted portion to remain) - antenna cable from sharkfin to receiver - MOST fiber cable to connection block behind seat bolster - electrical connection from distribution panel (no idea where it is) - typical SAT receiver and installation bracket Ideas?? Thoughts?? |
01-21-2009, 07:21 AM | #6 |
Rep 339
wow - if your car is pre wired for the TCU but not the sat radio this is a first for me after reading the forums before I did my retrofit.
is your head unit a hifi pro or business? If the wiring is indeed missing then this may become cost prohibitive. The $500 sat module is bad enough. (less used if you can find a used one for your car) Try starting at realoem.com, enter your VIN, and browse the parts lists. With the correct parts you can check getbmwparts and pellicanparts for ball park pricing. In addition to the harness (the power lead is in the black most connector by the way) I don't know how to tell if your shark fin has the antenna setup in it. Tricky. |
01-21-2009, 10:45 PM | #7 |
Rep 464
It is a Canadian spec 2006 car, with a 11/2005 build. I don't think that Sirius could be "legally" licensed in Canada back then.
As part of the premium package it was prewired for telephone. I have the Logic 7 sound system and have ordered a Sirius Starmate 5 that I will be installing in the sunglass tray. I am going to epoxy the base unit in place in a fashion that the unit can be removed and the cover can be closed. Not going OEM and retrofitting the Sirius unit, harnessing, and antenna (Sharkfin doesn't have Sirius if you have do not have prewire) will allow me to purchase mudflaps, floor mats, sunglass tray, blacklines, and euro switch. Thanks for the info, but I know realoem.com quite well from my 2 BMW motorcycles. |
