launching problem with DCT E92 335i
01-17-2009, 09:55 PM | #1 |
Rep 147
Not sure if many of you are aware about it, but the new DCT E92 335i does not allow us to brake boost as usual. Experiments that i've tried with my DCT 335i.
1) DTC-On DSC-Off / Gear "D" / Accelerate until right before WOT http://www.youtube.com/watch?v=7UMfzuZoeC4 2) DSC-On / Gear "D" / Accelerate until right before WOT Same as above 3) DSC-On / Gear "M1" / Accelerate until right before WOT Same 4) DCT-On DSC-Off / Gear "M/S" / Sports Mode / WOT = Launch Control In this mode, Launch control is activated and launches pretty quickly for a STOCK DCT 335i. However, after JB3, Procede, or any other upgrades, Launch Control is pretty useless as the car has too much power for the wheels to grip and its pretty much spinning all the way. Also, we cant fiddle with the rpm as it will drop back down to around 900rpm after 0.5 secs of stepping on the accelerator. So, anyone out there with a solution to launch a tuned 335i ? Cheers, Mark |
01-19-2009, 07:26 PM | #2 |
Rep 4,484
So let me get this straight:
If you try to put one foot on the brake and one on the accelerator and bring revs up any higher than about 1200 rpms DCT goes into a protected mode and drops the revs back down to idle? And the only way to bring the revs up higher is to initiate launch control? However, with a tune on the car, and initiating launch control the launch control basically does not work and allows the tires to spin uselessly? And any attempt to "alter" the launch control revs (meaning not flooring the throttle to bring the revs down a bit lower than what launch control automatically brings it up to) and within 1/2 second returns the car to idle. Did I get that correct? If so, wow, good to know, guess I wouldn't be paying the extra couple grand for DCT then on my next BMW but rather stick with the tried and true 6AT. Or, hopefully the tuners will figure away around the DCT launch control program too and allow you to launch the car under lower revs or at whatever revs YOU choose, not the program. Good luck |
01-22-2009, 01:40 AM | #4 | |
Supreme Allied Commander
3841
Rep 54,348
Drives: F80 M3
01-22-2009, 02:43 PM | #6 |
3841
Rep 54,348
Drives: F80 M3
01-22-2009, 04:49 PM | #7 |
Rep 4,484
On a side note, no doubt a true LSD will help.
But keep in mind, only the very early 335i's really spin just one tire. As of March 2007 build they started the e-LSD in the cars. It's no TRUE LSD, but without a doubt it helps and I've noticed that especially when going perfectly straight, you will often spin both tires with the e-LSD too. But often one still spins a bit more than the other, so a true LSD will help a bit. However, I don't think it would be enough. What he needs is to be able to lower the revs in launch control mode so the extra power of the tune can be controlled a bit more and the car isn't launching like if it had stock power still. |
