03-14-2023, 05:20 PM | #1 |
Rep 36
Drives: 2018 BMW 530e M sport
Quick Question Regarding 530e whilst in for maintenence
Quick question as my car is currently at the service center- I have the pre-LCI 9.2kwh battery, from a 0% charge I am only getting 6kwh until battery is full. I asked BMW to run a diagnostic which they stated was $189. Service tech came back and stated the tech suggested they test the HV battery (which I thought they were doing in the first place) which is $419. Does that seem reasonable? And if the diagnostic was originally quoted at $189 why are the coming back saying $419? Am I crazy??
04-04-2023, 11:43 AM | #2 |
Rep 4
Hey fellow pre-lci 530e owner here. I would say 6 kwh is spot on for the pack. They always allow for additional storage for keeping the electrics in the car operational when fully depleted. There is also around a 20% hold back for degration over the packs lifetime to keep range consistent. You will never be able to fully deplete the pack and charge the full 9.2kwh. So usable battery is about 6.5-7 kwh. If you don't have any warnings on the dash or I drive screen you should be good to go.
Volasko705.00 johnnyp42019.50 |
04-04-2023, 02:41 PM | #3 | |
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
johnnyp42019.50 |
04-06-2023, 02:28 PM | #4 | |
Rep 2,946
Drives: 2020 BMW 530xe
BMW needs to clarify this stuff.
How can there be a charge to test the battery when it is under warranty? Remember the battery has an 8Y/80K mile warranty (10Y/100K miles in CARB states)... My warranty booklet says it shouldn't be a paid "diagnostic"... Additionally, what did the report say. "Good" as in it holds a charge? What about degradation as that could also lead to having it replaced as has been done on the forum for SteveinArizona Quote:
The car's HV system and electronics can operate off the ICE motor with it acting as a generator. It can produce more charging current than you can with the 16A @ 240V the car allows. In my testing once you drop the car below a threshold amount (< 5%) it will use the ICE to power the HV system and aggressively charge the battery up to about 10% then go back to normal. This ensures you always have some HV battery on top to use "eBoost" as that requires both the ICE and HV motor to work together (so the ICE can't be dragged by charging the HV system). You can drain the battery the most by running the climate control system with the car on, but parked and you can monitor charge and energy use when the car drops enough to flip over to the ICE and back. The climate control in the car can't operate off the ICE, but it doesn't miss a beat and the energy view shows the charge occurring then the ICE flips off after a minute or two. I used to think the same though until my extensive testing. If I had access to a dyno it would be interesting to see what the car reported if you went WOT until the HV battery was flat. Almost impossible in real world though to create a situation where regeneration can't capture some energy and the ICE doesn't have excess capacity to top you up between hard acceleration pushes. Last edited by LogicalApex; 04-06-2023 at 02:37 PM.. Reason: Added warranty snippet. |
Volasko705.00 |
