V3, JB3, and cold start safety
01-07-2009, 01:23 PM | #1 | |
Rep 56
I have some questions about the implications of this post:
http://www.e90post.com/forums/showpo...&postcount=212 Here's an excerpt, the emphasis is mine: Quote:
01-07-2009, 01:32 PM | #2 | ||||
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
01-07-2009, 01:39 PM | #3 |
Rep 2,841
What really strikes me is that this cold temp boost protection seems to be built into the stock engines safety features.
Why is it being presented as a safety feature of the other tune unless they are trying to imply that this feature is somehow disabled by the way the Proceded operates??? |
01-07-2009, 01:42 PM | #4 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
01-07-2009, 01:53 PM | #5 | |||
Rep 56
Thanks for the response, Shiv. More questions:
Are you saying it's not safe to try with my V3 or my JB3? Even though boost pressure is reduced when the oil's cold, that the tunes will likely both run the turbos too hard? |
01-07-2009, 02:00 PM | #6 | ||||
1743
Rep 17,960
Drives: A Lot
Shiv Last edited by OpenFlash; 01-07-2009 at 02:38 PM.. |
01-07-2009, 02:34 PM | #7 |
Rep 911
Hi shiv,
I asked this question in another thread also, but would it not be a nice feature on the procede to have a kind o M-style like rev limiter? Even with the engine already providing a turbo limiter.... I think this should not be to harsh to implement as a user adjustable feature? Two params: A min temp param and a upper rev limit param Which would make it possible to have the care run max x revs when the car's oil is not yet above temp y. Although not sure you can manipulate the gear shifting on a AT car.... just my 2 cents. ;-)
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
01-07-2009, 02:36 PM | #8 | |
Rep 10,587
give it a shot and get back to us. Seriously though, dont do it, no point. Your motor ->
01-07-2009, 02:41 PM | #9 | |
1743
Rep 17,960
Drives: A Lot
Shiv Last edited by OpenFlash; 01-07-2009 at 03:39 PM.. |
01-07-2009, 03:38 PM | #10 |
Rep 5,780
01-07-2009, 03:53 PM | #12 | ||
Rep 56
Thanks again for the response. Forgive me if I seem dense, but I still have questions.
For example: "At oil temperatures less than XXX deg F, the stock ECU limits boost to XXpsi. This causes the PROCede to limit boost to XXpsi." It sounds like you've never tested this, and you're (perhaps understandably) not inclined to do so. What worries me, though, is that the tunes may in fact run boost higher than the stock warm oil max boost on cold oil. Quote:
Yes, I agree; which is why I'd hoped the tuners knew the answers... Last edited by doofus2; 01-07-2009 at 04:11 PM.. |
01-07-2009, 04:02 PM | #13 | |
1743
Rep 17,960
Drives: A Lot
We are offsetting the boost target and the DC required to achieve that target. The offset amount % remains constant despite engine temp. So, in basic terms, you will see more boost than stock when your engine is cold. But not as much as you will see when your engine is fully warm. But in the case where boost target is 0 (ie, wastegate DC is 0%), the PROcede will run 0 boost. 0% times anything is 0%. Shiv |
01-07-2009, 04:09 PM | #14 |
Rep 54
If you have a stock car, you could drive it out the garage & boost it.
Not such a great idea. Whatever boost the stock car allows, the tuned cars will allow that boost + X. So if the stock one boosts 7psi when cold, maybe the tuned ones will boost 11psi. Doesn't really matter. Running with no lube, it makes no difference if its 7 or 11psi. Hell, even 0psi is not good. |
01-07-2009, 04:12 PM | #15 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
01-07-2009, 04:36 PM | #16 | |
Rep 56
01-07-2009, 04:41 PM | #17 | |
1743
Rep 17,960
Drives: A Lot
Shiv |
01-07-2009, 04:53 PM | #18 | |
Rep 911
I know and I find myself pretty disciplined in not reving above 2,5k rpms when the engine is cold, but in a day to day car, you now and then hit the road and find out, that you started just a bit to enthiousiastic. :-) But your explanation is very clear, anyway if you find yourself a free rainy sunday, and you are really out of new great ideas...
01-07-2009, 04:56 PM | #19 |
442
Rep 18,331
Why would anyone push their cars when it still cold, I know for myself, I always wait until the oil temps reach at least 160 before I even push it...For those who like to push it immediately from a cold start, then u need to change your ways of treating the car!!!
01-07-2009, 05:29 PM | #20 |
Rep 911
I think no one pushes his car her on the forum, but my personal experience is that sometimes, while phoning or whatever, you find yourself making 3 - 3,5 k reving for a moment, while I prefer to stay below the 2,5 before my car is heated up to 200 ...
also very usefull if a third person, son, wife drives the car.....
01-07-2009, 09:18 PM | #21 | |
Rep 56
My point: both tuners have previously claimed or implied to preserve this safety feature of the stock programming. I'd like to understand how real these claims are. JB3 claim post: http://www.e90post.com/forums/showpo...&postcount=212 V3 implication post: http://www.e90post.com/forums/showpo...&postcount=214 The responses from Shiv in this thread lead me to conclude that this safety feature is somewhat compromised in the current V3. We haven't heard from the JB3 folks yet. |
01-07-2009, 09:21 PM | #22 |
1743
Rep 17,960
Drives: A Lot
Don't you have one? Stick it in and give it a shot. BTW, I've received three PMs from JB3 users confirming that they still see over 10psi when the car is cold, 15 when it is up to temp. Which is expected based upon the boost control strategy used by all these tunes. Without some sort of oil/water temp input going into the piggyback, there is no way to limit boost to stock level. All one can do is preserve the % boost reduction employed by the factory computer. But if we are doubling boost, the reduced boost level with a cold engine is also doubled.
Shiv |
