good ideas for 335xi drag setup?
01-08-2023, 09:38 PM | #1 |
Rep 13
Hello all, I got a 335xi AUTO and im going top mount single turbo, and my end goal is to hit 10 seconds inna 1/4 mile… i feel like i have all the necessary upgrades to the engine etc… just dont know what to do for my drivetrain..
So far I plan on running X-delete and a drag wheel setup in the back And once the 6hp21 starts showing signs that its slipping, i plan on going with the PD clutch kit, Nizpro shafts.. But i was wandering if anyone here has any better suggestions, or any more information on PD and Nizpro Thanks |
01-08-2023, 11:23 PM | #2 | |
Rep 230
01-09-2023, 11:38 AM | #4 |
Chief Executive
303
Rep 2,889
Drives: 2008 335xi 6spd Coupe
Not much you can do about the front diff. It's a bear to replace, and there really aren't a lot of options to improve it. It's actually a decent diff, just not so much when you get into big tq numbers.
01-09-2023, 10:01 PM | #6 |
Rep 9,209
Ratios are same for rwd and xDrive automatic, and same for rwd and xDrive manual. LSD not really needed. Good suspension setup, diff lockdown, 15” or 16” slick tires in rear…. What engine mod do you have?
01-10-2023, 06:37 AM | #7 |
Chief Executive
303
Rep 2,889
If you want 10 seconds, the all-wheel drive is going to be a huge help because of the improved 60 ft times. Stick with it until it breaks and then decide what to do.
01-10-2023, 07:01 AM | #8 | |
Rep 3,731
As far as the transmission goes...it's cheaper to do the HP28 conversion vs building the HP21.....and it's much stronger than the HP21.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
01-10-2023, 09:35 PM | #9 |
Rep 13
Thanks for the replies guys!
I would like to run Xdrive, but i always hear people say that the t-case wont last long at all, and id rather not break it… And i should do a 6hp28 swap? What about the 8HP transmissions? And info/costs on them? Any good “how to’s” on how to do these kinda swaps? My engine mods: Note, im from Ontario where E85 is basically not acheivable so im trying my best to get the most out of 94 oct. -Speed tech Top mount with a GTX 3576R - 7.5 FMIC -helix overdrive -index 12’s -single walbro 535 -CSF radiator -Mossel man thermostat -BM transmission cooler -will be getting custom tune from CD919 - XHP stg 3 - BC racing coilovers - alot of other little things like catch can, PCV, charge pipe etc etc. Most of these mods are not installed as im building the car atm. If i go RWD i have a 15inch brake conversion kit on the way, and weld wheels and MICKEY THOMPSON ET STREET RADIAL TIRES. Again, id love the AWD for drag, but hard launches will definitely eat away at the T-case very fast.. right? |
01-11-2023, 06:56 AM | #10 | |
Rep 3,731
Are you planning on dragging the car every weekend? Or just every now and then? What kind of power do you think you will be making? If your goal is to just run 10's, I don't think you have to worry about breaking the transfer case....but I'm no expert.
01-11-2023, 08:52 AM | #11 |
Rep 13
But don’t you think when I launch the car, all that stress on the front diff and transfer case will cause them to break? I heard the rear diff is stronger so it can handle it abit more..
My power goal is around 650whp and no i will not be drag racing every weekend, |
01-11-2023, 08:59 AM | #12 |
Rep 498
It’s gonna depend how you drive if you take it easy it should take it for a while if your super abusive it won’t last I had a guy who would blow up front diffs and axles like it was a hobby. 650hp is hard on the front drive train if you plan on launching it a lot. E85 isn’t hard to get in Ontario I have a guy who will come drop you a barrel but it’s about $2.80 a litre e98. You can also do port meth if you don’t wanna mess with ethanol but I’ve never been a big fan of meth. If it’s not setup properly I’ve seen a few fires and popped motors
01-11-2023, 09:30 AM | #13 | |
Rep 3,731
In the end, you never really know what's going to break until it does.
01-11-2023, 09:35 AM | #14 |
Rep 13
Yea so I basically just gotta get my car all finished up, drag it in AWD and see what time i get, and do the same with a RWD setup.
Its just that i see wayyyy more people run RWD setups then the XI setups, so thats why i wanna do the same, cuz they are obviously doing it for a reason right? And yes you can buy E85 in barrels, but ill probably do that later on, as its still gonna be my daily and i wanna daily it on just 94.. |
01-11-2023, 10:36 AM | #15 |
Rep 3,731
Without running at least an E40 fuel mix....you are going to have a hard time running 10's. These motors really need a high ethanol content fuel mix to get the octane up so you can run more boost and timing. Most people seem to be running mid 11's on straight pump gas.
I could be wrong, but I think the main reason people do the x-delete is so they can have a little more fun driving the car.......sliding the back end out around corners, doing burnouts, etc......AWD is quicker, but some people would rather just burn their tires off 😁 |
01-12-2023, 01:25 PM | #16 | |
Rep 940
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
01-12-2023, 05:12 PM | #17 |
Rep 3,731
Yes, the x-drive is heavier...but doing the x-delete tune doesn't make it any lighter...it just puts all the power to the rear wheels.
With any type of decent power.....and x-drive is going to launch a hell of a lot harder from a dig on the street vs a RWD car.... except maybe for a well prepped track. Last edited by iqraceworks; 01-12-2023 at 06:12 PM.. |
AWD Addict302.50 |
01-18-2023, 03:50 PM | #19 | |
Rep 315
I would DIE first before I would EVER swap to an automatic transmission... I won't own a car with an automatic. It's d eal killer, which sadly means I won't be getting another corvette.... I do like those, but... nope.
2010 335XI, Carillo Steel rods, JE pistons, Closed Deck, Stage 4 race heads, 6mt, Pure Stage 2 High Flows, B58 Coils, VRSF|Vu Brothers (Ft Worth, TX)|JSRTuning,
https://youtube.com/channel/UC_kL3RvFSGv9QmTVt6787gg |
AWD Addict302.50 |
01-23-2023, 11:58 AM | #20 |
Driving cars and riding bikes really fast
285
Rep 1,002
LS1 swap, automatic trans, Ford 9" rear end. Easy solution.
These are my stupid thoughts.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
01-23-2023, 01:13 PM | #21 |
Rep 3,731
Jaronbwall284.50 |
