Parrot 3000 evolution + parrot multican in UK
01-04-2009, 06:02 AM | #1 |
Rep 135
I've done a search on this and got a little confused.......
If I decide to get the parrot 3000 evolution by itself (no multican), do I have to also buy an additional iso cable or something similar to connect it to my professional non-logic7 non-idrive system? If I bought it WITH the multican, do I still need to buy an extra iso cable, or do all the cables I need come with the parrot multican adaptor? Does multican stop you using the steering wheel buttons for skipping cd tracks/radio etc? Do ALL the e90's work with the multican system (there are different interfaces to choose from, but I'm guessing some of these are for older model 3 series...?) Mine is a 55 plate. Also, does anyone know how long the cable is between the controller and the electrics box of the parrot 3000? If I get it, I'm thinking of mounting the controller on the panel just rear of the front coutesy/map reading lights on the roof panel. This panel is blank on mine apart from a couple of air vents as I have no sun roof so it seems a good place to put it.... Thanks in advance.... Last edited by DAN; 01-04-2009 at 06:18 PM.. |
01-08-2009, 07:30 PM | #2 |
Rep 135
Perhaps someone at least knows the model names of the adaptor harness that I need?
Bmw02tel or BMW06tel? http://www.justcarkits.co.uk/acatalog/BMW.html The 06 model says it has an ignition sense with it.... do I need this? Help! |
01-15-2009, 02:41 PM | #3 |
Rep 2,811
Drives: Jaguar XE P250 HSE
Dan, if you ask this question in the UK sub-forum, you should get a better answer as specifications, adaptors, etc. vary quite markedly between the two countries.
I have a Parrot 3100 and if it is similar, it comes with cables to mute the standard stereo speakers but a connect2 cable would be needed to allow the phone button to work on the steering wheel. It's quite expensive for the sake of one button and is a 'mare to squeeze into the space behind the head unit which already is stuffed because of the Parrot cables. |
01-19-2009, 01:47 PM | #4 |
Rep 732
if it helps, my parrot CK3200 was installed with two not used ISO connectors and god knows how much coiled up wiring. I have removed everything unused from the parrot connector (tiny screwdriver and lifted the pins out).
03-19-2009, 01:39 AM | #5 |
Rep 236
You can use the Connects2 Par006 adaptor for parrot 3000 evo. It is plug in install.
Look at www.connects2.com |
