Can I splice into existing microphone for aftermarket heardunit?
10-24-2022, 03:12 PM | #1 |
Rep 16
I just got the eonon Q65Pro for my 2007 E92 335i.
It comes with a shitty/ugly microphone -- I want to see if I can use the existing microphone in the car. I've not been able to figure out where the wire terminates for the mic, and if anyone has been able to use the existing microphone with an aftermarket headunit. |
10-24-2022, 05:51 PM | #2 |
Rep 13,119
the microphone is attached to the TCU or Mulf 2 hi in the early
model years. The following link may help. https://www.e90post.com/forums/showthread.php?t=1452541 |
10-24-2022, 06:13 PM | #3 |
Rep 249
I did. I spliced into the mic at the TCU connector in the trunk (since I was running a video cable for the reverse camera from trunk to head unit anyway). In my case the mic was at pins 1(+) 19(-) of the 54 pin connector. (see below).
It worked for a few months -- and then died. Bad OEM mic? Bad splice? Short/open in the wiring somewhere? who knows? Rather than trying to fix it, I installed a new mic from Amazon in the OEM location and ran the wire directly to the head unit down the A Pillar (where I located the GPS antenna). I used hot glue to attach the mic to the overhead console (inside the console). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 TCU-----------------------Combox Pin---Description-----------Pin---Description 1----Mic(pos)--------------25----Mic(pos) 4----AUX-GND-------------10----AUX-GND 15---Crash Sig.-------------7----Crash Sig. 17---30 Power+ 5A---------2----30 Power+ 5A 18---30 Power+ 10A--------1----30 Power+ 10A 19---MIC(neg)------------12-----MIC(neg) 21---MIC Shield-----------11-----MIC Shield 23---Shield---------------22-----Shield 31---SOS sig.f Button-----18-----SOS sig.f Button 33---Wakeup-------------15-----Wakeup 36---31 GROUND(neg)-----14----31 GROUND(neg) 37---emerg. Speak.(pos)--21----emerg. Speak.(pos) 38---emerg. Speak.(neg)--20----emerg. Speak.(neg) 50---emerg. butt LED-----17----emerg. butt LED 54---GROUND- |
10-25-2022, 06:43 AM | #4 | |
Rep 16
How was the sound quality with the own mic and the Amazon mic? |
10-25-2022, 08:44 AM | #5 |
Rep 249
I found opening up the A-Pillar quite easy -- one screw and pull it off. I did wind up replacing one of the plastic clips as it broke as I used the palm of my hand to snap the A-Pillar back in place.
But this is the best place for the GPS antenna -- so it was coming off in any case. Getting the overhead console out is a little trickier -- but remove the sunshade clips and you can stick your fingers under the headliner and push on the tab holding the console in. As to mic quality -- I really can't say as I'm never on the other end of the phone. I haven't had any complaints. |
10-25-2022, 03:31 PM | #6 | |
Rep 16
I put the GPS antenna on the front corner of the dash. Where is your GPS antenna? I routed a USB cable for a dashcam - and glad I removed the pillar trim to do so. I had previously routed power for my V1 and the cable had crossed over the airbag -- if it had gone off, it would have made the V1 into a projectile. I was able to zip tie it out of the way. |
09-24-2023, 05:28 PM | #7 |
Rep 2
where on the head unit did you plug in the mic?
Is there a place on the wiring harness, and to confirm it was the head unit, not the back of the screen.
Newbie questions. Thanks |
Tags |
console, microphone |
