09-23-2022, 12:20 PM | #1 |
Rep 1,559
Where's All The Dinan Sport Reviews
$230 for 40 HP and 50 TQ from a 20 minute install I thought I'd find lots of reviews, but nada.
Am I missing something? https://www.dinancars.com/products/s...arts/D440-0047 |
09-23-2022, 12:30 PM | #2 |
Rep 281
It's basically a JB+ with bluetooth control. If you only have access to 91 octane I would probably go for Dinantronics X or JB4. Personally experienced a lot of jerkiness with the single sensor versions. Might be better on 93 or E30.
2022 G42 M240i xDrive TM/TR
Past: 2019 F32 430i MG, 2015 F30 328i AW |
XC3LLR82062.50 |
09-23-2022, 12:43 PM | #3 |
Rep 1,559
I think it was AutoID that had a JB4 on their M240 and took it off, saying it was not very smooth. What is it with the piggyback tuners that cause jerkiness?
09-25-2022, 03:38 PM | #4 | |
Rep 281
09-26-2022, 01:19 PM | #5 |
Rep 320
Did they? I saw Jack and Nathan both race it on OG (Nathan most recently about 6 weeks ago), and the JB4 was still on it then. They hit 0-60mph in 3.02s and the 1/4 in 11.347s @ 121.36mph in that last race. That was sans DP, just JB4, intake and CB exhaust.
09-26-2022, 04:03 PM | #6 | |
Rep 1,559
09-26-2022, 08:52 PM | #7 | ||
Rep 281
M240SLC392.50 |
09-27-2022, 12:58 PM | #8 | |
Rep 320
10-03-2022, 09:08 AM | #9 | |
Joint Chiefs of Staff
24271
Rep 190,959
You need to invest in more advanced piggybacks if you want a smoother power delivery.
Redbeemer88.00 |
10-03-2022, 09:33 AM | #10 |
Rep 1,559
When you say "smoother power delivery", does that mean the Dinan Sport and JB+ are erratic with a loss of OEM smoothness?
10-03-2022, 10:58 AM | #11 | |
24271
Rep 190,959
In some cases, if the OEM boost is high, the total PSI becomes too aggressive. Your DME will protect your engine by reducing timing, which results in less power and more jerky power delivery.
11-08-2022, 08:12 PM | #12 |
Enthusiast
291
Rep 287
Drives: 2022 230i M Sport
I like
I got one, albeit for my 230. Of course, it is the same box. I don't experience jerkiness and there's a clear power increase. However, the power boost is all related to getting the turbo spooled up first where this thing has any effect.
For those who don't know, all it does is trick the computer that boost is lower, so the engine adds boost. There are just the two leads you have to "interrupt." I will likely upgrade later, but it is cheap, works well, and no [known] issues (famous last words, right?). I do recommend this device for any G42 driver. |
XC3LLR82062.50 |
11-09-2022, 10:31 AM | #13 |
Rep 751
I spoke to Jack at AutoID last week, they're currently running the Jb4 on Map 5 with catless DP and eventuri intake with no issues.
Unless your looking to run the adaptive maps within JB4 or run logs there's no advantage in terms of smoothness having a JB4 over the JB+. |
11-09-2022, 12:23 PM | #14 | |
Rep 1,559
335i E92176.50 |
11-09-2022, 12:36 PM | #15 | |
Rep 267
My current B58 is staying stock. I love how well the power delivery is tuned from factory. |
11-09-2022, 01:35 PM | #16 | |
Rep 35
11-09-2022, 03:32 PM | #17 |
Rep 1,559
Regarding the JB4 the division of Maps 2/3 vs. Maps 4/5 is crazy. I've read where people say only run 4 or 5 on the new B58 (after verifying logs with BMS), and others say only Map 2 would run properly, even after working with BMS extensively on Map 4 or 5 logs.
335i E92176.50 |
11-11-2022, 08:55 AM | #18 | |
24271
Rep 190,959
These cars run high boost, and data logging is a must, in my opinion, to see which map works for your car best. If the customer does not wish to datalog or owns a tuner that does not have this feature, I recommend going the safer route. The extra 5-10 is not worth it, in my opinion.
XC3LLR82062.50 |
11-11-2022, 09:46 AM | #19 | |
Rep 1,559
11-11-2022, 09:51 AM | #20 |
24271
Rep 190,959
Its safe to run other piggybacks, but don't use their most aggressive maps. Keep the boost at + 3PSI, and you should be good.
335i E92176.50 |
11-11-2022, 09:54 AM | #21 |
Rep 1,559
11-11-2022, 10:03 AM | #22 |
24271
Rep 190,959
I'm not too sure, you'll need to check with BMS directly
