E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - OEM Rear Deck Spoiler Lip (official instructions)
      07-07-2005, 11:05 AM   #1
Jason
Jason's Avatar
Drives: F80 M3
Arrow DIY - OEM Rear Deck Spoiler Lip (official instructions)
Click the following link for official instructions (in PDF) on installing the OEM Rear Deck Spoiler Lip.
Rear Deck Spoiler Lip Install Instructions
P.S. The glue / adhesive you see in instructions is called Betalink-K1 (BMW part Number 82-69-9-408-866). It retails for 12.75 + tax ... and comes in a complete set with sand paper, glue, cleaner, applicator. Thanks to member "Tape" for this information.
      10-22-2005, 07:52 AM   #2
ase2dais
//Mdicted
ase2dais's Avatar
Drives: a Cop Magnet
Official e90post's OEM Rear Spoiler DIY
I like to share the DIY step-by-step photos that I took when I installed my spoiler the other day. It has all important visual information and also lessons I learned that I wrote in the photos comment block.
I like to thank Jason from Tischer BMW MD who provided me the complementary Beta-link adhesive and a great deal. I almost walk off the dealership with just the spoiler package, thinking thats all i needed.
      11-21-2005, 09:58 PM   #3
ase2dais
//Mdicted
ase2dais's Avatar
part nos. of he OEM spoiler you need to order from the dealership:
1. e90 (only) Rear Deck Spoilers OEM P/N:
primed paint required:
p/n 51 71 0 396 344
Black Saphire
p/n 51 71 0 398 220
Sparkling Graphite
p/n 51 71 0 398 222
Titanium Silver
p/n 51 71 0 398 224
Non-Metalic Black
p/n 51 71 0 398 730
2. Glue/adhesive
      04-02-2006, 05:36 PM   #4
ase2dais
//Mdicted
ase2dais's Avatar
bump
for those folks who heard about edges working its way off, the key is
1. putting alot of betalink glue at left/right corner edges
2. taping it after for cure
3. homecdepot clamp them too
4. a 6 hrs cure time at weather temp of 60-90F
NOTE: DIY Step-by-Step E90 Spoiler Install for Dummies
http://www.bimmerfest.com/photos/sho...y.php?cat=3145
notes from jwarcd :
- The spoiler I got did not fit the curve of the trunk exactly and had to be slightly bent when installing to match the trunk. Not a big deal, but makes is a little harder to install.
- wear laytex gloves, the adhesive is pretty messy.
- clean the trunk edge and the back of the spoiler really well with the BetaClean solvent that came with the 3M BetaLink adhesive.
- lightly sand the back of the spoiler to give the adhesive something to grab onto.
- Now it's time to install the spoiler. BTW, don't peel off the protective backing on the tape on the spoiler until after you have installed it. (Once it touches the car it's on for good!) How the heck do I do that you are thinking? :-) Before you install it peel off about 1" of the tape backing and bend it back so that it sticks out towards the front of the car.
- Now, Put the 3M adhesive on the spoiler. Place the spoiler on the car and while you are pressing on the spoiler pull the tape backing towards the front of the car.
- Use the blue painters masking tap to hold the spoiler in place while the 3M BetaLink adhesive dries. The blue tape is easier to remove, and doesn't leave much residue behind. I also used small spring claps to hold the ends of the spoiler tightly to the trunk since it wanted to spring up a little.
- Clean up the the extra adhesive with the 3M BetaClean cleaner that came with the adhesive.
- I missed a little adhesive that was under the masking tape and was able to remove it the next day with a little BetaClean and the platic tool that came with the adhesive. You just have to be patient and carefully scrape it.
- BTW the adhesive doesn't come with the spoiler, it was about $15 at the dealer.
      04-02-2006, 05:53 PM   #5
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
thank you. plan to add spoiler this may... my b-day present
"Teach the ignorant. Ignore the stupid."
      04-02-2006, 07:10 PM   #6
bavarian19
bavarian19's Avatar
Drives: Car
My spoiler should be coming in on Tuesday this week. Ill have to arrange for it to be painted while I am away on vacation...
Ill do this DIY and many more when I return. After that, Im calling a mod hiatus for a long long time...
      04-02-2006, 10:11 PM   #7
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
Liar! And I heard Michael Jackson has never had plastic surgery...
you're addicted to DIY.... admit it.
      04-03-2006, 09:16 PM   #8
bavarian19
bavarian19's Avatar
Drives: Car
OK... maybe strut bar, but thats it
      04-28-2006, 12:19 PM   #9
bavarian19
bavarian19's Avatar
Drives: Car
Originally Posted by ase2dais
I'll put money on this bet, Deal ?
Spoiler and splitters going on this weekend and next week respectively... Then no mods...
Im going cold turkey... Lets see how long it lasts...
      05-01-2006, 04:28 PM   #10
bavarian19
bavarian19's Avatar
Drives: Car
Ive got more packing tape on my car now than Ive ever seen used... Heck, it even looks good with the tape on
      09-08-2006, 03:08 PM   #11
Boondoggler
Boondoggler's Avatar
72
Drives: 2023 G01 LCI X3 M40i
After completing the install I had a few issues with the removal of some of the betalink and the glue from the duct tape I used. I used the betalink solvent and used a cheap microfiber towel and ended up with a bunch of small swirl marks and scratches on the trunk and spoiler.
I was easily able to remove them using Zaino Z-PC, but would highly suggest two things to others who will be performing this install:
1) Use blue painters tape instead of duct tape as it will leave almost no glue residue.
2) When cleaning up any extra betalink that gets on the car, make sure you use the same high quality towels you'd use in the washing and waxing process.
I should have known better in reference to issue 2, but since I didn't, I thought I'd share my experience so others won't make the same mistake.
My Garage | Phytonic Blue | Black Sensatec | Carbon Fiber Trim | Parking | Premium | Remote | Wireless | Harmon Kardon | 19" 887M Bi-color Midnight Grey
      09-14-2006, 10:10 PM   #12
ase2dais
//Mdicted
ase2dais's Avatar
I find using a bag cotton balls soak with betalink link cleaning solvents (comes with betalink kit) works best cleaning up excess Betalink glue
      09-15-2006, 03:25 PM   #13
Boondoggler
72
I found that cotton balls were taking a long time to get some of the larger excess globs of betalink off, that's why I went to a betalink solvent soaked rag. It would have been fine if I'd used a good quality towel, but that was my mistake. You're right in that with enough patience, the cotton balls would have been fine.
      11-17-2006, 11:07 PM   #14
ase2dais
//Mdicted
ase2dais's Avatar
Ive covered the area near the Spoiler with tape, when I temporarily intalled the spoiler and mark it.
Marking it and covering exposed area gives a very good indication of where it should be once you install it with the glue later.
Covering the exposed area near the spoiler, will save you time cleaning up later by just pulling the tape with excess glue.
      10-28-2007, 09:38 AM   #15
ase2dais
//Mdicted
ase2dais's Avatar
Ive been asked time after time how my spoiler install has been holding up with betalink, some even asked photos.
Well, I figure I post it here for everyone to see thats its doing well after 2yrs and in all climate condition. The e90 is not garage and in a four season State.
btw I have no experience removing installed spoiler, but I believe Longtran had experience removing them. PM him for more info.
photos taken today Oct 27/07 hope it helps
      10-30-2007, 08:45 AM   #16
dubber1
dubber1's Avatar
Drives: 2017 430i Cabrio
2007 335xi  [0.00]
Great DIY. I just installed my spoiler last night. I have a small amount of the adhesive to remove that squished out, but other than that it looks great.
2017 430i xDrive Cabriolet
Retired: 2007 335xi Sapphire/Terra Premium
Retired: 2006 325i, Premium
      11-08-2007, 05:08 PM   #17
ejazbmw
blahhh
ejazbmw's Avatar
302
Drives: 2014 M235I
what about for us cf guys? I'm a bit confused because i think the clamp would crack the cf.
      02-16-2008, 11:24 AM   #18
Jerseystyle1
Boris the Blade
Jerseystyle1's Avatar
Drives: Montego Blue 335i Sedan
Anybody?
I agree. I just received my CF spoiler, but I'm worried about this as well.
Allan
Montego Blue 335i Sedan w/Navi/Magnetic Black NISMO 350Z #831/76' Mini 1100 "SPECIAL" Export
      03-05-2008, 02:06 PM   #19
wuufer001
wuufer001's Avatar
Taiwan
375
Drives: 2006 E90 M/T
2006 325i  [9.34]
i got a oem cf rep. it only came with double sided tapes. will it work?
      03-05-2008, 05:27 PM   #20
ase2dais
//Mdicted
ase2dais's Avatar
the ones Ive used are not actually heavy clamps but alligator clips guys. CF are heavy duty, why would it crack?
      03-09-2008, 08:50 PM   #21
Volkswagen1200
Drives: BMW E91 318d SE
I have the same question - two rows of double sided tape have been applied at the factory and the spoiler has not came with any glue.
1. Will the two rows of double sided tape be enough
2. If I do have to use glue where do I put it since there is only a small area between the two rows of tape to put the glue.
      04-25-2008, 12:57 PM   #22
ase2dais
//Mdicted
ase2dais's Avatar
1. doubtful
2, see illustration 17 from the photo DIY, DO NOT APPLY GLUE AT EDGES
also:
http://www.bimmerfest.com/photos/sli...=6186&cat=3145
e90post
