Racing Helmets
12-04-2008, 11:49 AM | #1 |
Skittles, OT OG
2337
Rep 649
Racing Helmets
Since it is winter up here in Ohio, im going to start gathering everything I need to attend my first track session in the spring. I know I need a helmet, but I dont know where to buy them or what to look for? Also, are there any other things that I must have to race?
Thanks in advance! |
12-04-2008, 12:03 PM | #2 | |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
You can order a helmet online for a pretty decent price, but I really recommend finding a local shop to at least try them on, as there are differences.
Also, what you need will really depend on what you are doing. Most HPDE schools will allow you to use a motorcycle helmet, as long as it is Snell 2000 or Snell 2005. I copied this from my local BMW CCA's website: Quote:
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
12-04-2008, 11:38 PM | #3 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
Racers Wholesale has a lot...so does Pyrotect. I personally am gonna get an M2 Pro next. I have a Pyrotect now..and had a M2 before.
Car is now gone .... :-( |
12-06-2008, 03:16 PM | #4 |
Samtaro!
123
Rep 2,601
Its best to try them on for size and comfort. I'm glad I did, because I ended up with a different size than the one I intended to purchase!
12-09-2008, 09:43 AM | #5 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
I ended up getting the HJC Si-12. It is a VERY light weight helment and very comfortable with excellent ventilation. It is SA2005 compliant as well.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
12-09-2008, 12:57 PM | #6 |
Rep 184
I have a similar HJC AR10 that I bought 6 months ago, but it doesn't have that fancy ram air intake for the head It's fairly light also.
2007 335i Coupe
Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package |
12-09-2008, 01:10 PM | #7 |
137
Rep 2,372
Is a full face helmet better than an open face one? I'm wondering about airbags going off and the additional heat inside the helmet.....
Scott
12-09-2008, 01:39 PM | #8 | |
878
Rep 3,699
I run with my visor up most of the time. Heat wasn't an issue. I have good air flow with this helmet and you have to run with the windows open anyway.
12-09-2008, 04:45 PM | #9 |
Rep 184
The airbag issue may be true, but some events require you to have a full face helmet.
2007 335i Coupe
12-09-2008, 04:53 PM | #10 | |
Rep 241
fyi: most scca events have loaner's. so you can try both and see what you are comfortable with before you buy. (if you could wait until then) if had to do it all over again i would get an open face just for comfort. |
12-10-2008, 08:38 PM | #11 |
Rep 8,745
I went with open face for the following reasons:
- I wear glasses - Don't need to scream my head off for instructor to hear me (when not using microphone or whatever you call it) - When using microphones easier to install even after helmet on! Which reminds me, I need to get a set of microphones for next season, cos not all instructors have them.
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
12-10-2008, 08:53 PM | #12 | |
Rep 4,445
12-11-2008, 08:09 AM | #14 |
Rep 337
You may want to consider a full face helmet for the added protection OR if you get a ride at the track in an open car (Lotus 7, Radical SR3, etc.). Also consider an "SA" rated helmet as many clubs are insisting on that rating.
I use a Simpson Speedway Shark (www.TeamSimpson.com). Feff |
12-11-2008, 02:09 PM | #16 |
Rep 4,380
My fat head doesnt fit in Arai helmets...I am probably getting an Bell M2 Pro next time..wide eyelet for my glasses..and relatively light..closed face...(I dont like open faced)..and I have a chatterbox for talking..so sound is not an issue.
12-11-2008, 07:56 PM | #18 | |
Rep 8,745
So the chatterbox is in the helmet? All you need to do is put helmet on, then put glasses?
12-12-2008, 07:14 PM | #19 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
I would highly recommend a full face SA helmet for the added protection and just in case the club does not allow you on the track with a motorcycle helmet.
Wear the helmet you chose around the store (along with any glasses, ear plugs, balaclava or whatever you will be wearing) for a while to see if you develop a head ache or any discomfort. General rule of thumb is while wearing the helmet you should not be able to chew gum without biting your cheeks. I'm assuming this is the same chatterbox S4to335 is referring to? If so it can be mounted on the helmet or anywhere inside the car/your pocket. http://www.kneedraggers.com/details/...2--621315.html |
12-12-2008, 07:49 PM | #20 | |
Samtaro!
123
Rep 2,601
I went with open face for lighter weight, comfort, easier communication with instructor, better visibility, and lower cost! .
12-13-2008, 01:17 AM | #21 | |
Rep 8,745
Thanks
12-14-2008, 03:42 PM | #22 |
Skittles, OT OG
2337
Rep 649
Thanks a lot guys! I just realized than Summit Racing is only about 25-30 minutes away from my house. So Im going to take a ride up there sometime since Im on break now. Ill let you know what I see/get.
