E92 pre LCI headlight issue
02-06-2022, 01:18 PM | #1 |
Rep 1
about 4 months ago I took my e92 through a drive-thru car wash (not a touchless one) and after I came out of the car wash my driver-side headlight bulb wasn't working and I got a dash light for an adaptive headlight error.
Using my common sense I was able to figure out that water had probably gotten into the headlight or into the adaptive headlight module or something along those lines. Would I have to replace the ballast or the headlight bulb to fix my issue of one working light? I would assume I have to replace the ballast but I just want to make sure before I spend the money on it. Also, the adaptive headlight warning is extremely annoying and I just want to get rid of it. Is there a way to code it out or disable it so that I don't have to see that stupid warning every time I drive my car? What is the easiest or cheapest way to get rid of it? |
02-06-2022, 01:33 PM | #2 |
Rep 4,323
It could be either the bulb or ballast.
You can swap the bulb or ballast from the passenger side to the driver side to see which piece turns the light on. You can code out the adaptive error with ncsexpert. Cheapest option, but you do need a kdcan cable. You can also use bimmergeeks protools app. You need a cable, an android device and need to purchase the coding option in the app. I think it’s like $80 |
