11-23-2021, 08:49 PM | #1 |
Rep 1,117
RARE USA/Canada NBT EVO LATEST VERSION HW 4.1
Rare USA/Canada NBT EVO HeadUnit With USA HD Radio and SiriusXM Chips, unlike ECE versions with DAB and no HD Radio Chips. Works with F Series Models 1,2,3 and 4 including M2,M3 and M4 Search extensively to find this particular late model HU with HW 4.1. Purchased this to upgrade family BMW unit but a deer had other ideas. Because of chip shortage, anyone who’s searched knows all NBT EVO HUs are very rare now. HW 4.1 is very latest. There are no higher Hardware Revisions of this unit. Most units advertised as “iDrive6” are usually HW 2.x or HW 3.x units. Seller does not point out Hardware Version for obvious reasons. HW 4.1 is latest (and last) and very rare as they were only introduced in BMW F2x/F3x vehicles mid 2018 models. The 2016 HW 2.x units were memory limited (2GB) and CarPlay often crashes. Many remote features were not available with the 2.x hardware. It can only run ID-6 “lite”for CarPlay. The 2017 HW 3.x had more memory (4GB) but the 2018+ HW 4.1 had the latest technology and remote features. The mid 2018+ HW 4.x had the latest tech and hardware you can find in this unit, but as F30/F31 were in their last year, much harder to source. G Series G2x/G8x went with a different non-compatible HU so this is the most up to date OEM tech you can fit in your F Series. You cannot get any better than this if wanting to upgrade/update your NBT EVO unit. If you want all the remote functions for your 2016 NBT EVO this HU does that (and sell off your older NBT EVO to someone to recoup some costs). Or retrofit entire unit into older NBT model for the newer hardware and features. Also have access to a working transferable ATM if you want to retrofit entire setup including Connect Drive with full remote features. Latest firmware assure it works with VoLTE post February 2022 3G USA shutdown. Better to email than post below as the info above will most likely generate a lot of questions not concerning this sale that should be asked in other sections and not the classifieds. etcm4kcy5k9r@opayq.com Thanks Last edited by YASBBYM3; 03-24-2022 at 11:07 PM.. |
11-24-2021, 04:12 PM | #3 | |
Rep 1,117
A WLAN antenna can be purchased at any BMW Parts seller or Amazon for $25 or less. If any interest in the HeadUnit, please use the email above in the main post. |
12-15-2021, 08:18 AM | #5 | ||
Rep 426
12-23-2021, 11:01 PM | #6 | |||
Rep 1,117
More details as to different configurations in f80 thread https://f80.bimmerpost.com/forums/sh....php?t=1878542 |
07-05-2023, 10:11 AM | #12 |
Rep 1,117
Those are found from factory on the older RAM limited HW 2.x units. A few sellers have aftermarket added to newer units but charge up to $1500 for the units with that modification. Also, many of the units the mod is being done to are the ECE, not USA units, which leaves several key USA Chips/Services out of the unit. I prefer to add in a factory ATM retrofit if upgrading from a pre 2016 NBT instead of adding a GPS Port. If using CarPlay, most use Waze or Google for GPS Navigation anyway. Another cheaper option is to buy a device that inserts the car’s GPS signal into the NBT EVO unit without cutting into the HU.
07-08-2023, 10:06 PM | #14 |
Rep 1,117
07-09-2023, 01:51 AM | #15 |
Rep 51
Drives: 2015 535i xDrive
Would this work on an F10? If so, what other parts would be required to retrofit the headunit?
07-09-2023, 02:22 AM | #16 | |
Rep 1,117
As for what else you would need for a complete retrofit, it really depends on the details of what F10 you have and what options your vehicle already has. If you want to email me your VIN and/or other specs, along with what you want at minimum, I can give you a more complete answer as well as where to obtain the other parts cheaply. |
Herofmine412.50 |
07-09-2023, 12:36 PM | #18 |
Rep 1,117
Yes this can be retrofitted into a 2013 328i with HU_ENTRYNAV. However you’d need a new controller that works over kcan2, a handwriting module if that was wanted, and rewiring for those as well. There might also be be some wiring changes needed where the unit plugs into the chassis harness, depending on what you wish to accomplish.
07-10-2023, 11:16 AM | #19 | |
Rep 77
Anyway, enough ranting. Thanks for letting me know. I am going to do some research and see if this is feasible. |
07-10-2023, 02:04 PM | #20 | |
Rep 816
I am selling a kit it interested fyi. |
