Levels of Wheels inside Wheel Arches
11-17-2008, 04:35 PM | #1 |
Rep 131
Hello again
I'm back . . . with more problems This time its the wheels inside the arches, I know I mention it here and there in other peoples posts but I thought I'd throw it into its own post. My back right wheel sits practically touching the inside of the wheel arch whereas the back left wheel has a bit of space between it and the wheel arch. I will upload a picture or two soon, any ideas, does everyone's back wheels look pretty even when the car is on level ground ? I'm running on the 19" M-Sport jobs, if you didn't already know that by now |
11-17-2008, 06:34 PM | #2 |
Rep 2,811
Drives: Jaguar XE P250 HSE
The height of the wheels is measured from the bottom of the rim to the underside of the wheel arch. Anything less than 10mm is, apparently normal.
It's happened to me and I got palmed off with that. Not really the dealer's fault, they are carrying out BMW instructions. |
11-18-2008, 11:14 AM | #3 | |
Rep 445
Could be the ground you are sitting on, the land is rarely prectly horizontal. I had 13mm difference on my Golf (lots of measurements taken is various locations), went into VW they said it was 3.5mm (laser check on the ramps) which was within the 7mm tolerance. Its really hard to tell unless you can get it on very flat ground, exact same pressure in both tyres and then measure from an exact spot (upper most) on the rim, or even better from the exact centre of the wheel.
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past..... 2011 [61] Abarth 500, Funk White, Leather, H&R 2007 [57] 320d M-Sport Touring Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on..... |
11-18-2008, 01:11 PM | #5 |
gone ... but i will be back !
62
Rep 1,183
your not alone in noticing this , im pretty obcessed with it as well recently. Im sure the car sits strangely at the back doesnt seem to be affected by ground level etc. I hadnt thought about the fuel tank , i would of thought it would have been fairly central though for their 50:50 weight distribution BMW are allways banging on about in their brochures.
Hmmm
E92 335D / QUAIFE LSD / EIBACH / DIMISA / REMAP / 19" HAMANN EDITION RACE REPS ... USUALLY WITH A HEALTHY SPLATTERING OF GOOD OLD YORKSHIRE MUD ... |
11-18-2008, 05:15 PM | #6 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
I agree (again) Chris - Mine defo is lower on one side than the other and fuel seems to make little difference (always empty as the missus drives it a lot lately )
Not measured it as I know it will bug me if I do |
11-19-2008, 01:45 PM | #8 |
Rep 3,154
mine was at Berry chiswick the other day for this exact symptom! I noticed it when getting the allingment done at feltham tyre centre, whats weird is that over time the difference seems to level out! leave car for an hour an the difference in mine is less than 10mm difference between them, being 3cm before. Well unless its an illusion and the dealer has palmed me off
