Performance difference between these to wheels
10-28-2008, 07:10 AM | #1 |
she likes the flavor......
85
Rep 1,622
what is the difference between these two performance wise
Advan RS 18x8.5 +32 and 18x9.5 +35 and 18x8.5 +32 and 18x9.5 +25 and what would the best tire size to get for the 18x8.5 +32 and 18x9.5 +35?
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. Last edited by BlueLion; 10-28-2008 at 07:55 AM.. |
10-28-2008, 08:40 AM | #2 |
Rep 1,476
all-out performance says... stuff the widest tire possible in there. But... I hear black wheels are faster than any other color.
Edit: http://www.ls1gto.com/forums/showthread.php?t=226079 Last edited by satakal; 10-28-2008 at 08:43 AM.. Reason: link added |
10-28-2008, 09:31 AM | #3 | |
Rep 1,714
Black wheels are the fastest...ONLY if you put the red time attack ring on it. |
10-28-2008, 10:26 AM | #4 | |
85
Rep 1,622
thanks for the link....i finally now understand what the offset number mean
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
10-28-2008, 10:27 AM | #5 | |
85
Rep 1,622
i like the jokes guys, but i need an answer too
10-28-2008, 10:34 AM | #6 |
Rep 325
You want the 35 offset for the rear on a coupe.
25 offset would stick out a little too much and cause rubbing if you drop. 235/35/18 front 265/30/18 rear you could run 245's in the front and 275's in the back if you want. |
10-28-2008, 11:13 AM | #7 | |
85
Rep 1,622
thanks....what would be better handling wise.... 235/265 or 245/275....im not a serious autoxer but i do go out 5-7 time a year. or is it just for looks?
10-28-2008, 09:29 PM | #9 |
Gearing
86
Rep 3,965
I'm pretty sure you'll want to run the same wheel size all the way around to zero out the understear. Stuff as large a wheel as you can (255s if your dropped).
If at first you don't succeed ...
10-28-2008, 10:08 PM | #10 |
Rep 1,456
Drives: 2008 E92 335i
"Yeah; well, my interior is better."
10-29-2008, 07:59 AM | #11 | |||
85
Rep 1,622
thanks for the info, lets sort it out:
so 255's would fit in the front with no rubbing? i was planning on going with 235/265. Am i better off 255/255? Quote:
10-29-2008, 09:47 AM | #12 |
Rep 1,714
I'd do the former. Don't think you want to widen the rear track and induce MORE understeer.
Regarding stagger, I run 255/255 on track and 225/255 on the street. The car tramlines a bit more with the 255/255 setup, so not sure I'd run that on the street. Hope that helps. |
10-29-2008, 10:32 AM | #13 | |
85
Rep 1,622
i dont want to put a tire on that would compromise or induce and negative effect with my tire choice stock is 225/255 i was thinking 235/265....using the logic that more tire is better but i don't want to add more understeer now i dont know what to do but keep the info coming.....i asked the question here because i wanted to hear from people that actually drive their car and know whats going on
10-29-2008, 10:50 AM | #14 |
Rep 1,476
leftcoastman runs the 255 fronts on a 17" wheel. as do I.
I think this is a world of compromises. If you want to have good looking city wheels, you'll pay a bit of a penalty on the track. If you want good performing track wheels, they'll look goofy on the street. obviously 235/265 is better than 225/255. But, thats 10mm more front and back. /yawn. I don't think thats far enough away from stock to be very noticable. |
10-29-2008, 11:10 AM | #15 |
Rep 1,714
If you're just going to have one set of wheels/tires, I'd compromise at 235/255. Reduces understeer a bit...but isn't tramline-city on the streets.
10-29-2008, 11:32 AM | #16 | |
85
Rep 1,622
what affect does having wider tires in front have?
10-29-2008, 11:41 AM | #17 |
Rep 1,476
http://www.e90post.com/forums/showthread.php?t=180844
whole thread especially post #6 strange who topics come in waves. Last month was heel-toe'ing. |
10-29-2008, 04:50 PM | #18 |
85
Rep 1,622
thanks for all the help guys
10-30-2008, 01:41 AM | #19 | |
Rep 3,432
As for the tires I would just go with 235/265 since your car is 90% street driven. It's not too bad from my autox experience, but then I also have H&R sway bars front and rear. I wouldn't go 235/255 since you probably can't tell the difference, and the front will be taller than the rear in overall diameter. |
10-30-2008, 08:22 PM | #20 |
85
Rep 1,622
decided on
18x8.5 +32 and 18x9.5 +35 with Dunlop Z1 star spec 235/40/18 and 265/35/18 tires.
