Modified Accelerator Pedal for Heel/Toe Shifts
10-22-2008, 02:16 PM | #1 |
Rep 83
Most people that use a "heel/toe" technique to downshift actually rotate their foot from side to side instead of actually using their heel. The problem with the 335i accelerator pedal is that it is a little too narrow to do this really well if you are hard braking at the time (like at the track). I have seen some aftermarket accelerator pedals that widen out about a half inch on the left side of the pedal to make this easier. BMW tells me that they do not have an option to do this and that you can't replace just the pedal because it is part of a unit that includes a plunger and sensor unit. He suggested I might be able to get a metal fabricator to make a plate that would bolt on to the existing pedal. Has anyone either replaced the pedal unit or done something like this?
10-22-2008, 02:40 PM | #2 | |
Rep 1,714
Get shoes with a wide toe box. It should help. But hell, I heel-toe on the street...using my dress shoes, lol. |
10-22-2008, 03:41 PM | #4 | |
Supreme Allied Commander
3843
Rep 54,362
Drives: F80 M3
10-22-2008, 03:52 PM | #5 | |
Rep 83
10-22-2008, 04:24 PM | #6 | |
Rep 1,714
Bigger brakes generally require you to press HARDER to get the same braking force. You get more consistent braking, but you have to press harder, all else equal. But you are doing it right. Better to slip off the throttle blip rather than slip off the brake. I really just rotate my ankle and never have trouble blipping. Check out youtube. There are some cool videos that demonstrate it better than I can describe. |
10-22-2008, 04:41 PM | #7 |
Rep 83
Guys, for anyone that is interested, I just found a web site, www.ultimatepedals.com, that carries high quality metal pedals to replace OEM. They have three options for the 335i, one of which does exactly what I want - it increases the left side of the accelerator pedal by 3/4 of an inch. Their accelerator pedal attaches over the existing pedal with self tapping screws and the brake and clutch pedals attach to the underlying sheet metal (after removing the OEM rubber covers). They look really great.
10-22-2008, 05:10 PM | #8 |
Rep 10,509
10-22-2008, 05:12 PM | #9 |
Rep 10,509
10-23-2008, 08:37 AM | #10 | |
Rep 10,587
10-23-2008, 11:22 AM | #11 |
Rep 1,714
eeech, that would make me nervous. To economize on movements, I generally try to keep my heel near the same location when braking and accelerating. Not sure I'd be comfortable late braking down from 150mph when I'm worried about accidentally hitting the gas.
By keeping my heel in the same general location, the transition from braking to getting back on gas is as smooth and quick as possible. My Traqmate data indicates that when I move the ball of my foot too much during braking, I can't get the same consistency in that brake-throttle transition. Additionally, it's very very obvious that it takes longer to transition, at least based on my data. I really like the stock pedal setup, at least for performance driving. |
10-24-2008, 12:18 PM | #12 |
Rep 8,745
Our HPDEs (BMW or Audi) required that you use shoes with laces!!!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
