A/C. Heat.
02-19-2021, 08:42 AM | #3 |
Rep 301
You can buy a can of R134 with the gauge built in at any auto parts store. Add slowly and if the ac begins to cool, you in fact are low on refrigerant. If low on 134 though, you more than likely have a leak in the ac system.
02-19-2021, 10:32 PM | #4 | |
Rep 4,066
That can be confirmed using INPA which shows Flap Position of EACH of the EIGHT (8) Flap Motors. I'll attach two different INPA screens to next post, showing (1) "0%" Mixed Air Flap position on both sides when Full Cooling is requested, and (2) "80%" Mixed Air Flap position on both sides when T-Stats set to 24C and outside Temp is 3C (Heating mode). So NO air going through heater core on Full Cold, and 80% through heater core in stated heat mode. You might try pressing "MAX" button in center of Left T-stat, and see if that prevents intermittent flap position change. Also check and see if air temperature is same from vents on BOTH sides. Please let us know what you find, George |
